    SketchyPhysics - New Grip System for Cars ! !
    16 Posts 6 Posters 3.3k Views 6 Watching
      MrDailyBlah
      Ever built a sketchyphysics car? And theres no grip on the ground? Well never fear, 'cos MrDailyBlah is here....(!) 😍 (!)
      I recently fiddled around with the raytest function, and i thought i could incorporate it in to the sim...
      A floor in sketchyphysics is perfectly smooth...it doesnt create friction like a normal surface would. To create more grip, the most obvious solution is to apply negative thrust to the car's body or suspension, but this collapsed the wheel hinges. ❓ ❗ 😒
      I tried to use magnetism as a solution, and i found that if i could use the raytest function, i could find a point under each wheel on the floor, to each of which i can teleport a magnetic object, attracting the wheels to the floor and creating grip without collapsing the car... πŸ€“ πŸ˜„ πŸ‘
      That was it in a nutshell... here's the code i used -
      # paste the following into the floor
      onstart{
      # a way to simplify Sketchup.active_model.raytest
      def newRay(p,d)
      ray=Sketchup.active_model.raytest(p,d)
      return ray
      # then i copied the following script 2 each wheel
      ontick{
      t=[0,0,-1]
      ray1=newRay(position,t)
      ray2=newRay(ray1[0],t)
      s=@simulation.findBody("sphere...") # the magnetic object; theres a unique one 4 each wheel
      s.teleport ray2[0] if (ray2!=nil) and (s!=nil)
      heres a demo of the script
      P.S. make sure u know how it works befor u copy it... ( πŸ˜• )
      • iichiversiiI Offline
        iichiversii
        This is great, nice feature, thanks
        Bring on the Rain...
          mptak
          What a nice Holiday present. Can't wait to try it...(once I understand it (:)).
            Don East
            Where did you put this script?
            Don
            http://sketchupbydawn.blogspot.com/
              MrDailyBlah
              Don
              u need to put it in the "scripted" section of the Sketchyphysics UI (neither the "ontick" or "ontouch" section would work...)
              • H Offline
                hobbnob
                Hehe not a bad idea, but you could just have put push([0,0,-1]) in the ontick field of the wheel, does exactly the same thing πŸ˜„
                (little extra note, if you want to have the vehicle turn on it's side/upside down and still have it work, then encase your steering block around the drive joint (either hinge or motor dependign on your preference) and they won't collapse)
                My WIP Thread:Here
                  MrDailyBlah
                  uh..well.. push([0,0,-1]) creates a violent vibration in the wheels.. so its not that simple.. 😞 ❗
                  p.s. i looked in ControllerCommands.rb and found the push()method is the same as $sketchyPhysicsToolInstance.pushBody(), which creates the vibration i talked about... 😒
                  • H Offline
                    hobbnob
                    I haven't had that problem in the 4 years I've been using sketchyphysics, you sure you've got your wheels geom and ontick interval set up correctly?
                    My WIP Thread:Here
                      MrDailyBlah
                      sure as pants man.. ❓ ❗ 😲
                      • ashscottA Offline
                        ashscott
                        Yeah I have the same issue with Hobbnobbs micro script - I am building a walking machine - the fluctuation which is somehow included in hobbnobs micro script causes my machine do hover and float around slowly.
                        When I implement MrDailyBlah's I get the kind of traction for my machine's feet that I was looking for. Can increase traction by changing the value'-1' in the part of the script that goes in the wheel to '-2'. Nice work
                        I've got no idea where the vibration is coming from - funnily enough, the other two variables marked '0' in hobbnobs script control push in a certain direction. You can make your machine/vehicles hover in certain directions using these variables.
                        Just some stuff I do with Sketchup.
                        • ashscottA Offline
                          ashscott
                          I've added a little complexity that is causing this script to crash SP when I try to run it.
                          As far as I can tell it has something to do with the raytest function - potentailly related to the issue described on this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=30558
                          I have tested it in SU7 as well but am getting the same issue - basically the model explodes, the POV zooms way out and all I can find left in the model is a bunch of endpoints (like on the end of a tapemeasure guide......can anyone shed some light?
                          Ash
                            MrDailyBlah
                            Ash
                            that's right sir...
                            i used raytest to find the point where the wheels touch the floor, then i teleport magnets to them to attract the wheels... πŸ€“
                            • ashscottA Offline
                              ashscott
                              But Raytest has a tendency to cause SU to flip out - know of a workaround or why I am having the symptoms described?
                                MrDailyBlah
                                uh... 😲 nooo...
                                u'd better consult pros like Wacov.. πŸ˜•
                                • ashscottA Offline
                                  ashscott
                                  So you're not getting the issues I described two posts ago.....?
                                  I seem to get it no matter how I run it (apparently the raytest issue was clashing with SU8 but I can't even get it working right in SU7)
                                    MrDailyBlah
                                    try reinstalling sketchup or SP or sumthing πŸ˜• ...
