    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 152.1k Views 43 Watching
      Alvinhobbes
      Hello all.
      This is my first post in this forum. I'm a total noob in both 3d and rendering. I'm using the free Maxwell Render Plugin and trying to figure it out. Please forgive if I'm missing obvious things.
      When I render a solid, either if I give it a Glass Type, or apply a glass MXM downloaded from Maxwell Resources, it will cast the same shadow as an opaque object. Also, some of the MXMs won't behave as expected. Particularly emitters (magma lamp, fluorescent bulb). Are these limitations of the free plugin, or am I missing some tweak?
      Right now I don't have access to the MXed, since I'm running on OSX 10.5.8
      Thanks in advence!
      • jason_marantoJ Offline
        jason_maranto
        If you are referring to the shadow as seen through he glass itself then this is a well known issue -- you can read more about it here: http://www.maxwellrender.com/forum/viewtopic.php?p=340525 The end result is that you should use AGS for most things, and if you do use real glass choose your lighting carefully.
        The Maxwell resources website is a mixed bag -- alot of the materials are from a previous version of Maxwell and don't always convert well, but more than that many are meant to be used on very specific geometry.
        In most cases if you are having issues with MXM materials the best solution is to recreate the material using the plugin and the textures that came with the MXM -- in the case of emitter materials this will be pretty easy by using either the Emitter character or the HDR Image character.
        Usually the most problematic materials are displacement-based materials and without MXED it is impossible to edit them so re-creating them in the plugin would really be your only option.
        Best,
        Jason.
          sojourner
          Hey, just saw this thread and tried to go to maxell render's website. It seems to be gone. Did they go out of business?
            jason_maranto
            I just checked http://www.maxwellrender.com/ and everything seems fine -- it could be you tried when there were some server issues.
            Best,
            Jason.
              jason_maranto
              I have begun to upload the Maxwell & Arroway sets here: http://www.maxwellrender.com/forum/viewtopic.php?f=107&t=38528
              Best,
              Jason.
              • utilerU Offline
                utiler
                Way cool, Jason...! Let us know when its done!!
                BTW, this is spooky.
                oooooo...... ๐Ÿ˜ฎ ๐Ÿ˜‰
                Just Curious...
                  jason_maranto
                  The entire line of Arroway textures has been converted into MXMs and corresponding SketchUp linked materials (775 SKM materials over 8 sets), you can download these materials here:
                  These will work in the Stand-Alone(pay & free versions) and the Full Render Suite versions of the Maxwell plugin, all you need to do is have the textures and follow my instructions.
                  Best,
                  Jason.
                  • utilerU Offline
                    utiler
                    That would have a been a HUGE job, Jason!!!! Very much appreciated....
                    Just Curious...
                    • RichardR Offline
                      Richard
                      [attachment=0:1l5fn5uk]<!-- ia0 -->2012-04-19_0843.png<!-- ia0 -->[/attachment:1l5fn5uk]
                      That ain't spooky - maybe only that they say "the best"!
                      BUILTBRAND.COM.AU
                      • utilerU Offline
                        utiler
                        And again!!!!!!! ๐Ÿคฃ ๐Ÿคฃ
                        Just Curious...
                          MMM717
                          I've posted previously on the forum re my motel project that's I've been modeling with Sketchup 8 (free version). The motel is completed, but I now need to render. Note this 'build' is my very first project, though I'm very pleased with the results, except for it looking too jagged as I go further away from the image (when getting a wide view of things), hence the need for rendering.
                          From what I can tell so far, Maxwell (as a plugin to use within Sketchup) seems to be an excellent solution for my needs, with a few concerns:
                          I've read "out there" that some rendering programs have issues in dealing with components. Due to the nature of my design, I needed to use components throughout as it is quite detailed, and it would have been a nightmare to redo things each time from scratch (for instance, my railings on the balconies). Does Maxwell have any drawbacks with rendering Sketchup models with components - hurting their 'look', etc.? That's very important here.
                          I consider the motel finished, aside from polishing it so that I can make it look "photorealistic" and take away any sort of the jagged appearance that comes out when pulling back (distance wise) on the image (as noted above). I'm not looking to do anymore construction/building within the rendering program. All my colors, etc. are as I want them, though I wouldn't mind adding some subtle cement/concrete texture to the sections that need it (though they are already "painted" in the color I want these to be), and possibly proper "finish" to any paints as they would exist in real life. Neither of these are of utmost importance, but working with my existing colors, photo images (I've used cropped sections of pictures, such as stones, etc. to "paint" parts of the model) is.
                          I've read that Maxwell only works in metric. I've built up the motel in feet/inches, as that's how my mind has been trained to work. Considering the above paragraphs, is this even an issue given that I don't need to further "build" anything in rendering?
                          I'm sure that as a novice I'm asking stuff that may be a given, but before I go ahead an learn to use Maxwell, I wanted to be sure that I'll make a good choice. If not, does anyone here recommend another (free!) plugin?
                          Thanks in advance...
                          Martin
                            jason_maranto
                            Components are not an issue, Maxwell handles them very nicely.
                            Likewise working in metric is really not as much of an issue since you are staying within SketchUp -- you can generally just hit render and tweak until you get what you need (materials being the place where you will likely spend the most time).
                            Best,
                            Jason.
                              MMM717
                              Great, thanks Jason.
                              Given the above, do you recommend something else instead of Maxwell?
                                jason_maranto
                                I'm probably not the right person to ask about that -- I paid full price for the Maxwell Render Suite, so to me the stand-alone plugin is a great deal.
                                Best,
                                Jason.
                                  MMM717
                                  I understand...for my purposes, doing this just as a one-off for my own project, I can't invest in a paid version if a very good render plug-in (for my needs) exists. My concern is making the best choice among those.
                                  • RichardR Offline
                                    Richard
                                    Mate the paid version of the standalone (not the suite) is very cheap! Though if you still want a free plugin, I doubt you will find one with the shear ease of use and certainly no where near the results. Most free render apps are free as they can't sell them. In Maxwell's case they have just put limits on the available features!
                                    BUILTBRAND.COM.AU
                                      MMM717
                                      I agree. I'm sure it's a great value. At the same time, at least coming to this world for the first time, I've been very impressed with what is provided for free. It's a great program, even if waiting for rendering to occur can sometimes be like waiting for paint to dry. That's probably at least partly due to my computer though.
                                      I am having a problem with rendering one of my materials. The file looks like this, before any changes within Sketchup or Maxwell:
                                      http://i1143.photobucket.com/albums/n631/MartinMelucci/Flagstone_chop_crop.jpg
                                      I tried a bunch of different material types for this and ended up on SSS, but I don't know that this is ideal either. Within Sketchup (before rendering) I remember making just minor adjustments to the file (maybe adding just a touch of saturation), which kept the basic look but brought out just a bit of the color within the stones (the goal for these is to still stay basically white for the stones themselves, plus the color of the fill seen between the stones). I also set the dimensions in Sketchup for the material to 2' 6" wide and 1' 9 7/16" high, which made the stones look the size I want them. In Maxwell, I have the SSS material type set to:
                                      7% roughness
                                      7cm thickness
                                      402.23 density
                                      -28.49% asymmetry
                                      0 change to saturation
                                      +5.75 brightness
                                      +7.25 contrast
                                      no inversion
                                      From a darkness/lightness standpoint, it looks OK (the above adjustments basically have helped with that more than anything else), but I'm not easily making the stone texture visible. I once ran a render with the resolution all the way up to 800 pixels and a high stitch level, and I don't remember being able to make out the stones in any useful way until the stitch level crept up to at least 10 or 11 IIRC, and that was at a somewhat close distance to one of the objects using this material (the project is a moderate sized motel). Pull away from things (as I will have to for some shots), and I'm seeing more of a textured off white than anything, which is not the goal. Part of the design is to be able to see these as stones.
                                      Any suggestions re material type to better render the above? Settings/adjustments to help at least get things "in the ballpark"? Something that I should be doing but I haven't (or vice versa)? Anything else?
                                      Thanks again in advance. This forum has been quite helpful with my few questions so far... ๐Ÿ˜„
                                      • pbacotP Offline
                                        I'm no expert but I am trialing Maxwell as well. I tried the texture you put up and got a pretty good stone look with just "automatic" setting at 97% roughness (default setting) the bump is at 100 and looks pretty nice... I notice the texture is not tiling seamlessly.
                                        So maybe that will help until the experts arrive.
                                          MMM717
                                          Thanks.
                                          Stupid question - I haven't done anything with bump so far (and might be what I need to get this to look OK). When I click on the "bump" button, it shows a setting as a default with -100 saturation, leaving the image black and white. What am I supposed to do with bump? If this is in the manual pdf, let me know - I don't want you to type something unnecessarily...
                                            MMM717
                                            Thanks. I'm trying adjusting the bump strength. It didn't seem to help with using automatic/default, and I'm waiting on a render with the SSS settings noted above and will see how that goes.
                                            I don't see any controls that say displacement. Is displacement the min/max settings? I haven't altered those at all from default...
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
