    File.dirname(__FILE__) returns nil?
    5 Posts 3 Posters 945 Views 3 Watching
    • W Offline
      Whaat
      Thread title says the problem. I received a support email and it seems as though this code is returning nil on his system. Has anyone experienced this and figured out why?
      Thanks.
        Is it inside a compiled rbs file or a rb file.
        If it's used inside a rbs it might refer to the wrong 'variable', as its not then specific to that loading file.
        What is the exact context ?
        • W Offline
          Whaat
          It's in an RB file (I believe you have it πŸ˜„ ) that is located in the plugins/sketchuv folder:
          The code inside the file is:
          Sketchup.load(File.join(File.dirname(__FILE__),"sketchuv.rbs"))
          and the user is getting this error when SketchUp loads:
          Error Loading File sketchuv_load.rb
          (eval):3076:in `join': can't convert nil into String
          I have since found out that the user is using SU8.1 and OSX 10 (not too helpful info)
          • Dan RathbunD Offline
            Dan Rathbun
            I don't think that is the line with the error.
            Check in "sketchuv.rbs", around line 3075 (give or take a few lines,) for a join statement.
            You need to note the line number, in the file that loads "sketchuv_load.rb" add 1 (for the 1 line in "sketchuv_load.rb",) then subtract that number of lines from the 3076 reported in the Sketchup.load error. That will give you a better idea of the number of lines into the rbs file, where the error should be.
            I'm not here much anymore.
            • W Offline
              Whaat
              Weird, now the user says the problem is not occurring anymore without any explanation. Lovely! πŸ˜’
              Sorry for wasting your time Dan,TiG. Thanks for the help!
