    Newbie question - execute jar file in ruby
    16 Posts 3 Posters 3.8k Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      oldDir = Dir.getwd
      Dir.chdir('C;/some/path/to/the/correct/dir')
      output = nil
      output = `Model2GCode.jar #{ARGSTRING}`
      delay = 0.5
      tid = UI.start_timer( delay, true ) {
        if output
          UI.stop_timer(tid)
          Dir.chdir(oldDir)
      I'm not here much anymore.
      • N Offline
        niccah
        @dan rathbun said:
        oldDir = Dir.getwd
        > output = nil
        > delay = 0.5
        >   if output
        >     UI.stop_timer(tid)
        >     Dir.chdir(oldDir)
        >   end
        Oh thank you very much. Now, I just get an error like this: "Error: #<Errno::ENOEXEC: Exec format error - Model2GCode.jar", but I think that's a problem of my jar file!
        Thanks a lot for your help!
          As long as you are not passing any arguments to the jar file, then
          Dir.chdir('C:/some/path/to/the/correct/dir') UI.openURL('Model2GCode.jar')
          or perhaps if you pass the FULL path
          UI.openURL('file:/'+path2jar')
          will work...
          • N Offline
            niccah
            Dir.chdir('C:/some/path/to/the/correct/dir') UI.openURL('Model2GCode.jar')... UI.openURL('file:/'+path2jar')
            Unfortunately not - I want to send some information to the jar file. But UI.openURL() is a nice function too - I will keep it in my mind! Thank you!
            I have a further question:
            This java file can take serveral minutes to execute. So it would be nice, if I can get some signals from the java code to be sure, everything is okay.
            Does the following idea work?
            • after each step in the Java code, it should be send a short message to ruby
            • I can be sure, that every step of the java code should not be longer than 10 seconds
            • if I get no new messages after 10 seconds, I will cancle the ruby code
            If you think, it is an good idea to do this in such a way, than I don't know exactly, how I can "control" the messages of the Java code.
            If I write: output = Model2GCode.jar #{ARGSTRING}
            and the Java code send every seconds a message - gets the output "longer" and "longer"? Or will the Java code "overwrite" the "old" output?
            I hope, you know what I mean? It's hard for me to write what I am thinking πŸ˜„
            Thank you very much for your help!
              I use the UI.openURL() method with 'jar' files... BUT they are written to read their arguments from an 'ini' file written by the Ruby side. That way I can adjust what is read in, and not get tangled in passing data directly...
              If you have to wait until it's done processing... You could have the jar code simply delete its 'ini' file when it's finished doing its main stuff, and use something like
              sleep(0.2);wait=0.0 while File.exist?(inipath) sleep(0.2) wait+=0.2 break if wait >= 60.0 end#while
              where 'inipath' is the path read by the jar and you set wait's 'time-out' to whatever is sensible - here it's 1 minute - this is in case the jar fails and the 'ini' file never gets deleted...
                Dan Rathbun
                try:
                output =java Model2GCode.jar #{ARGSTRING}``
                  That's almost it... but it needs a -jar flag to execute the .jar file...
                  Use Dir.chdir() to the jar file's folder folder then use
                  output =java -jar Model2GCode.jar #{ARGSTRING}``
                  [Works for me...]
                    Dan Rathbun
                    FYI the switches for java.exe (probably also javaw.exe)
                    Usage; java [-options] class [args...]
                               (to execute a class)
                       or  java [-options] -jar jarfile [args...]
                               (to execute a jar file)
                    where options include;
                        -client       to select the "client" VM
                        -server       to select the "server" VM
                        -hotspot      is a synonym for the "client" VM  [deprecated]
                                      The default VM is client.
                        -cp <class search path of directories and zip/jar files>
                        -classpath <class search path of directories and zip/jar files>
                                      A ; separated list of directories, JAR archives,
                                      and ZIP archives to search for class files.
                        -D<name>=<value>
                                      set a system property
                        -verbose[;class|gc|jni]
                                      enable verbose output
                        -version      print product version and exit
                        -version;<value>
                                      require the specified version to run
                        -showversion  print product version and continue
                        -jre-restrict-search | -jre-no-restrict-search
                                      include/exclude user private JREs in the version search
                        -? -help      print this help message
                        -X            print help on non-standard options
                        -ea[;<packagename>...|;<classname>]
                        -enableassertions[;<packagename>...|;<classname>]
                                      enable assertions
                        -da[;<packagename>...|;<classname>]
                        -disableassertions[;<packagename>...|;<classname>]
                                      disable assertions
                        -esa | -enablesystemassertions
                                      enable system assertions
                        -dsa | -disablesystemassertions
                                      disable system assertions
                        -agentlib;<libname>[=<options>]
                                      load native agent library <libname>, e.g. -agentlib;hprof
                                        see also, -agentlib;jdwp=help and -agentlib;hprof=help
                        -agentpath;<pathname>[=<options>]
                                      load native agent library by full pathname
                        -javaagent;<jarpath>[=<options>]
                                      load Java programming language agent, see java.lang.instrument
                        -splash;<imagepath>
                                      show splash screen with specified image
                    πŸ’­
                    • N Offline
                      niccah
                      You are the best!
                      With the help of your tips I could solve the "Exec format error"! Thanks your very very much!
                      The next problem: πŸ˜†
                      I wrote two very easy jar files:
                      1th version: just: System.out.println("Hello world!"); => but with the following code, I get a false.
                      output = nil
                      output = `java -jar Model2GCode.jar #{ARGSTRING}`
                      result=$?.success?
                      2nd version: Thread.sleep(10000); => I get a false too.
                      When I start the jar file outside of sketchup, everything is fine.
                      Do you have an idea, what can I do? I'm not sure, if it is an problem of Sketchup, Ruby or Java...
                      Thanks you for all your help!
                        Dan Rathbun
                        $? is nil when Sketchup first starts.
                        After a subprocess runs it may be set to a integer value, for the exit status.
                        The method name success? is not an instance method of either NilClass nor Integer (nor it's subclasses, such as Fixnum.)
                        You should test the output reference (since you first set it to nil, which Ruby will eval as false in a conditional statement.)
                        output = nil
                        if not output
                          if $? != nil || $? != 0
                            puts("The error code returned was; #{$?.to_s}")
                          else
                            puts("No error code was returned.")
                        else
                          # do something with the output string
                        You cannot call Thread.sleep() as it is a private instance method of the Thread class (and raises a NoMethodError exception.)
                        Use the global method sleep() (which is inherited from module Kernel,) instead.
                        Warning.. using sleep() can cause "whiteout" (Windows can put the SketchUp application into "ghost-window mode".)
                        • N Offline
                          niccah
                          Thanks Dan Rathbun!!
                          By using your method - I get an empty output.
                          output = nil
                          if not output
                            else
                          else
                            UI.messagebox output
                          I see the UI.messagebox, but it is empty.
                          My Java code is just a
                          As I read in some forums, the "output" of the java application should be the "System.out.println"'s. So, I'm confused, why it doesn't work?!
                            Dan Rathbun
                            Yes I tried it also, and got no output.
                            I tried in in a command shell and got java errors.
                            Sorry I cannot help you with java.
                            Why use java when SketchUp uses Ruby ??
                              Java won't print to the Ruby/SUp messagebox how does it know it.
                              Use an Alert in the Java code...
                              http://www.java2s.com/Code/JavaAPI/javax.microedition.lcdui/Alert.htm
                              • N Offline
                                niccah
                                I'm coding a plugin for Sketchup to get a GCode for a CNC milling maschine for a 3D Model. So, multithreading would be very nice to accelerate the calculating. The ruby version of Sketchup doesn't support something like that. So I try to use an external Java application for the main calculations.
                                  Dan Rathbun
                                  Hmmm... OK. Yes, actually it's Ruby 1.8.x itself that uses "green threads" instead of native threads.
                                  You might have more luck using a OLE interface to the java.
                                  See: [Plugin Library] Win32API and Win32OLE so files
                                  and: WIN32OLE rdoc
