    Newbie question - execute jar file in ruby
    16 Posts 3 Posters 4.0k Views 3 Watching
    • N
      niccah
      Hey!
      I think it is a very basic question, but I can't solve it.
      I would like to execute a jar file in Sketchups ruby.
      My serveral experiments:
      output = Model2GCode #{ARGSTRING} => no such file found
      output = Model2GCode.jar #{ARGSTRING} => no such file found
      output = Model2GCode -jar #{ARGSTRING} => no such file found
      I think I have to give them the right folder. (the jar file is in the same folder as the rb file).
      Do you have any ideas?
      Thank you very much for your help!
      • Dan RathbunD
        Dan Rathbun
        oldDir = Dir.getwd
        Dir.chdir('C;/some/path/to/the/correct/dir')
        output = nil
        output = `Model2GCode.jar #{ARGSTRING}`
        delay = 0.5
        tid = UI.start_timer( delay, true ) {
          if output
            UI.stop_timer(tid)
            Dir.chdir(oldDir)
        I'm not here much anymore.
        • N
          niccah
          @dan rathbun said:
          oldDir = Dir.getwd
          > output = nil
          > delay = 0.5
          >   if output
          >     UI.stop_timer(tid)
          >     Dir.chdir(oldDir)
          >   end
          Oh thank you very much. Now, I just get an error like this: "Error: #<Errno::ENOEXEC: Exec format error - Model2GCode.jar", but I think that's a problem of my jar file!
          Thanks a lot for your help!
            As long as you are not passing any arguments to the jar file, then
            Dir.chdir('C:/some/path/to/the/correct/dir') UI.openURL('Model2GCode.jar')
            or perhaps if you pass the FULL path
            UI.openURL('file:/'+path2jar')
            will work...
            • N
              niccah
              Dir.chdir('C:/some/path/to/the/correct/dir') UI.openURL('Model2GCode.jar')... UI.openURL('file:/'+path2jar')
              Unfortunately not - I want to send some information to the jar file. But UI.openURL() is a nice function too - I will keep it in my mind! Thank you!
              I have a further question:
              This java file can take serveral minutes to execute. So it would be nice, if I can get some signals from the java code to be sure, everything is okay.
              Does the following idea work?
              • after each step in the Java code, it should be send a short message to ruby
              • I can be sure, that every step of the java code should not be longer than 10 seconds
              • if I get no new messages after 10 seconds, I will cancle the ruby code
              If you think, it is an good idea to do this in such a way, than I don't know exactly, how I can "control" the messages of the Java code.
              If I write: output = Model2GCode.jar #{ARGSTRING}
              and the Java code send every seconds a message - gets the output "longer" and "longer"? Or will the Java code "overwrite" the "old" output?
              I hope, you know what I mean? It's hard for me to write what I am thinking πŸ˜„
                I use the UI.openURL() method with 'jar' files... BUT they are written to read their arguments from an 'ini' file written by the Ruby side. That way I can adjust what is read in, and not get tangled in passing data directly...
                If you have to wait until it's done processing... You could have the jar code simply delete its 'ini' file when it's finished doing its main stuff, and use something like
                sleep(0.2);wait=0.0 while File.exist?(inipath) sleep(0.2) wait+=0.2 break if wait >= 60.0 end#while
                where 'inipath' is the path read by the jar and you set wait's 'time-out' to whatever is sensible - here it's 1 minute - this is in case the jar fails and the 'ini' file never gets deleted...
                • Dan RathbunD
                  Dan Rathbun
                  try:
                  output =java Model2GCode.jar #{ARGSTRING}``
                    That's almost it... but it needs a -jar flag to execute the .jar file...
                    Use Dir.chdir() to the jar file's folder folder then use
                    output =java -jar Model2GCode.jar #{ARGSTRING}``
                    [Works for me...]
                    • Dan RathbunD
                      Dan Rathbun
                      FYI the switches for java.exe (probably also javaw.exe)
                      Usage; java [-options] class [args...]
                                 (to execute a class)
                         or  java [-options] -jar jarfile [args...]
                                 (to execute a jar file)
                      where options include;
                          -client       to select the "client" VM
                          -server       to select the "server" VM
                          -hotspot      is a synonym for the "client" VM  [deprecated]
                                        The default VM is client.
                          -cp <class search path of directories and zip/jar files>
                          -classpath <class search path of directories and zip/jar files>
                                        A ; separated list of directories, JAR archives,
                                        and ZIP archives to search for class files.
                          -D<name>=<value>
                                        set a system property
                          -verbose[;class|gc|jni]
                                        enable verbose output
                          -version      print product version and exit
                          -version;<value>
                                        require the specified version to run
                          -showversion  print product version and continue
                          -jre-restrict-search | -jre-no-restrict-search
                                        include/exclude user private JREs in the version search
                          -? -help      print this help message
                          -X            print help on non-standard options
                          -ea[;<packagename>...|;<classname>]
                          -enableassertions[;<packagename>...|;<classname>]
                                        enable assertions
                          -da[;<packagename>...|;<classname>]
                          -disableassertions[;<packagename>...|;<classname>]
                                        disable assertions
                          -esa | -enablesystemassertions
                                        enable system assertions
                          -dsa | -disablesystemassertions
                                        disable system assertions
                          -agentlib;<libname>[=<options>]
                                        load native agent library <libname>, e.g. -agentlib;hprof
                                          see also, -agentlib;jdwp=help and -agentlib;hprof=help
                          -agentpath;<pathname>[=<options>]
                                        load native agent library by full pathname
                          -javaagent;<jarpath>[=<options>]
                                        load Java programming language agent, see java.lang.instrument
                          -splash;<imagepath>
                                        show splash screen with specified image
                      πŸ’­
                      • N
                        niccah
                        You are the best!
                        With the help of your tips I could solve the "Exec format error"! Thanks your very very much!
                        The next problem: πŸ˜†
                        I wrote two very easy jar files:
                        1th version: just: System.out.println("Hello world!"); => but with the following code, I get a false.
                        output = nil
                        output = `java -jar Model2GCode.jar #{ARGSTRING}`
                        result=$?.success?
                        2nd version: Thread.sleep(10000); => I get a false too.
                        When I start the jar file outside of sketchup, everything is fine.
                        Do you have an idea, what can I do? I'm not sure, if it is an problem of Sketchup, Ruby or Java...
                        Thanks you for all your help!
                        • Dan RathbunD
                          Dan Rathbun
                          $? is nil when Sketchup first starts.
                          After a subprocess runs it may be set to a integer value, for the exit status.
                          The method name success? is not an instance method of either NilClass nor Integer (nor it's subclasses, such as Fixnum.)
                          You should test the output reference (since you first set it to nil, which Ruby will eval as false in a conditional statement.)
                          output = nil
                          if not output
                            if $? != nil || $? != 0
                              puts("The error code returned was; #{$?.to_s}")
                            else
                              puts("No error code was returned.")
                          else
                            # do something with the output string
                          You cannot call Thread.sleep() as it is a private instance method of the Thread class (and raises a NoMethodError exception.)
                          Use the global method sleep() (which is inherited from module Kernel,) instead.
                          Warning.. using sleep() can cause "whiteout" (Windows can put the SketchUp application into "ghost-window mode".)
                          • N
                            niccah
                            Thanks Dan Rathbun!!
                            By using your method - I get an empty output.
                            output = nil
                            if not output
                              else
                            else
                              UI.messagebox output
                            I see the UI.messagebox, but it is empty.
                            My Java code is just a
                            As I read in some forums, the "output" of the java application should be the "System.out.println"'s. So, I'm confused, why it doesn't work?!
                            • Dan RathbunD
                              Dan Rathbun
                              Yes I tried it also, and got no output.
                              I tried in in a command shell and got java errors.
                              Sorry I cannot help you with java.
                              Why use java when SketchUp uses Ruby ??
                                Java won't print to the Ruby/SUp messagebox how does it know it.
                                Use an Alert in the Java code...
                                http://www.java2s.com/Code/JavaAPI/javax.microedition.lcdui/Alert.htm
                                • N
                                  niccah
                                  I'm coding a plugin for Sketchup to get a GCode for a CNC milling maschine for a 3D Model. So, multithreading would be very nice to accelerate the calculating. The ruby version of Sketchup doesn't support something like that. So I try to use an external Java application for the main calculations.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Hmmm... OK. Yes, actually it's Ruby 1.8.x itself that uses "green threads" instead of native threads.
                                    You might have more luck using a OLE interface to the java.
                                    See: [Plugin Library] Win32API and Win32OLE so files
                                    and: WIN32OLE rdoc
