    Sketchup to Blender workflow?
    7 Posts 5 Posters 2.0k Views 5 Watching
    • H Offline
      HFM
      Any of you guys have some experience with exporting big models from Sketchup to Blender?
      I tried exporting a model of a building with its surroundings [map of 110 x 170 meters]
      as .stl, but in Blender that leaves you with a model that is too big to zoom out properly.
      Scaling down the model afterwards will make it 'disappear'
      I wan't to see how I can integrate Blender in my work-process with Cycles, but this is
      stopping me from doing that.
        Try with Collada dae format
        • mitcorbM Offline
          mitcorb
          A matter of side interest to you, perhaps, is that the main name in Blender is Ton Roosendaal, from the Netherlands. I think I spelled his last name correctly.
            Lobster
            Does it help if you change the viewport clipping options in Blender, on the N panel i tnink?
            • H Offline
              HFM
              I started with that, but for some reason it only shows one component in blender
              I cannot see your option in the N panel, maybe this screenshot illustrates my problem.
              • andybotA Offline
                andybot
                you can zoom to an object that's selected by using the numpad "." key - this will set your clipping to that object.
                As for export, have you tried TIG's object exporter?
                Another thing is that with a lot of repetitive components, a seemingly small SU file can quickly get big. Try instancing those components in Blender where possible.
                -Andy
                • H Offline
                  HFM
                  Ah finally 'found' my model. Setting clip to a large amount and pressing numpad . did the trick, thanks guys!
