    Construction site sign
    11 Posts 4 Posters 1.7k Views 4 Watching
    • cottyC
      cotty
      A friend will buy the house in the attached photo. His friends (I am one of them) want to surprise him (and his future neighbors) with a construction sign in his front yard (ca 2x1,5m). I have done a "reconstruction" and would be happy to get some feedback. The picture for the poster should be attractive but pretentious... 😄
      Original house
      Version 1
      Version 2
      my SketchUp gallery
      • cottyC
        cotty
        Here is a detail view with the original resolution...
        Detail view
        my SketchUp gallery
        • mitcorbM
          mitcorb
          Maybe you could say "Future Home Of..." So long as your neighbors and any building officials know it's a joke 😉
          • cottyC
            cotty
            Is there a way to export a large image without the aspect ratio from the screen? I know that there is a maximum of 9999 pixels in one direction, but the second dimension depends on the screen resolution, e.g.
            I try to get an output with e.g. 8000x8000 px ...
            my SketchUp gallery
            • jeff hammondJ
              [attachment=1:21aa2h2v]<!-- ia1 -->image_export.jpg<!-- ia1 -->[/attachment:21aa2h2v]
              on mac, you just break the link then export at any dimensions you want.. it will crop the viewport from the middle
              [attachment=0:21aa2h2v]<!-- ia0 -->screen1.jpg<!-- ia0 -->[/attachment:21aa2h2v]
              apparently, that's not an option on windows but, i don't think your aspect ratio is locked to the screen's ratio.. i think it's locked to the actual sketchup window..
              try resizing your window to where it's near square then export at larger than 8000 px… crop to a true 8k x 8k square afterwards..
              • GaieusG
                You can try the cubic pano out plugin.
                http://rhin.crai.archi.fr/rld/plugin_details.php?id=91
                It add those grey bands on the sizes that crop the output. Get it to generate scenes with a small output first then go to the scene you want to export and crank up the resolution there.
                • cottyC
                  cotty
                  @gaieus said:
                  You can try the cubic pano out plugin. It add those grey bands on the sizes that crop the output.
                  I have tried the plugin but I think there are two problems regarding this aim:
                  • the angle of view is changed to 90° so the direct output of the plugin looks distorted
                  • a manual export from one of the created scenes even with the gray bands visible uses the sketchup window aspect ratio nevertheless
                  i think it's locked to the actual sketchup window...
                  You are right, it is the sketchup window (I never noticed because I have installed so much plugins that I never change my window size to something smaller than maximum 😕 ) and your solution does it...
                  Back to the shown images:
                  Which of the shown perspective would you expect on a construction site sign? Do you think another style can look more professional?
                  my SketchUp gallery
                  • jeff hammondJ
                    I think you'd more likely see the 2nd version on a site sign.
                    the converging verticals on ver1 are a little too extreme.
                    I might try a version with a more muted sky as well because that blue, when painted large, is going to overpower the rest of the image.
                    of course, this is all personal opinion etc.. I don't think there are any rules per se when it comes to this stuff..
                    • GaieusG
                      How about Kerkythea export then? There you can set whatever aspect ratio you want. Size is just a matter of memory but they have a 64 bit version now.
                      • cottyC
                        cotty
                        I think I will stick to the NPR version because I don't want to adapt the materials for rendering...
                        I will try that and show some results when it is done. Every opinion is very welcome, especially if it is personal 😛
                        my SketchUp gallery
                        • cottyC
                          cotty
                          little update...
                          Version 3
                          my SketchUp gallery
