    [Plugin] Honeycomber
    91 Posts 21 Posters 65.2k Views 21 Watching
      SUFractal
      I can't tell from your screenshot if the Plugins folder is in the the 'root' [Macintosh HD] library path, where it should be; or say an incorrect User path...
      Assuming it's in the right place... can you be more specific about about what's 'crashing' and how this manifests itself...
      Does Sketchup star without errors?
      Does the Extension appear in the Preferences dialog?
      If you deactivate it and restart does the Tools menu item vanish, and does the toolbar vanish?
      If you activate it do you get a Tools menu item and a toolbar?
      If you activate the toolbar does it appear as expected?
      Open the Ruby Console.
      If you make a simple 4" cube [e.g. make a square and PushPull it up 4"] and make it into a group [Entity Info will show it as 'solid' when it's selected] and run the tool from the toolbar what happens?
      Does a dialog appear?
      If you accept the default values and press OK, what happens?
      Are there any error messages? [either in the Console or in a message-box]
      If errors what do they say - exactly - ?
      What happens to the cube-group?
      etc...
      With a little more logic applied to the testing/reporting we can track the issue and fix it...
      [Oxer - are you listening too?]
      PS: On a completely separate side note... I see you have 'toggleWindows.rb' installed in your Plugins folder - that's a PC only script; since MACs don't have Outliner crash issues, and that script uses .so files incompatible with a MAC anyway ?
        SUFractal
        @tig said:
        SUFractal
        etc...
        TIG:
        I have the plugin installed in the correct location ... as I have all of my countless other plugins. I am in full understanding of where plugins are req'd to be located on Macs. I've gotten rid of the 'toggleWindows.rb' script (didn't realize that was PC only at the time I suppose).
        When I attempt to operate the plugin with even a simple cube:
        A dialogue box appears asking for parameters.
        The cube switches to X-ray mode immediately.
        Using the default settings, the console window says" TIG::Honeycomber: Perforating.
        After waiting as long as 15 minutes, nothing "happens" to the simple cube.
        If at any time during the console message (or even after 15 minutes) I even slightly move the mouse/cursor, the message in the status window disappears.
        The 'symptoms' I am describing sound very similar to juanjo's.
          SUFractal
          You'd only need to wait 15 minutes if doing an incredibly complex object with thousands of perforations...
          So, it seems that it runs, but produces no result?
          Does it 'crash' ?
          Does it 'hang' ?
          What 'Console message[s]' ?
          There should be none, only Status-bar messages saying what's being done and some incrementing '...' or ',,,' etc.
          You should actually see the perforators being added, then subtracted in turn as the view refreshes as it goes...
          Can you post your cube size, and a screenshot of the dialog settings you used...
          It it completes with no changes, then it suggests that the perforations were bigger than the object so it remains unchanged.
          If you use 'Shell' > 0 [at a fraction of the cube's dims] do you at least get a simple shell added ?
          This is a mystery ๐Ÿ˜•
            SUFractal
            @tig said:
            SUFractal
            Does it 'crash' ?
            Does it 'hang' ?
            I meant status window, not console, sorry.
            Using a 12' x 12' x 12' cube and the default parameters (see screenshot), I click 'OK', the status window changes to "Tig::Honeycomber:Perforating", and then it "hangs/doesn't do anything else/whatever" ... nothing 'happens' to the cube.
            I then tried a shell setting in the Parameters window of 12" (and all other settings at 12") and it generated a shell and 'cube within a cube'.
            I get no prompts for structure, comb, or foam (or anything) beyond that.
            • OxerO
              Oxer
              Hi again, again... TIG ๐Ÿ˜„
              See images below
              1. I select the Cubo (Solid Group) push the plugin icon and it appears the Setting Window.
              2. I press Aceptar (OK) and nothing happens, see the Error Ruby Console.
                Oxer[and probably SUFractal in the absence of a Console error report from him...]
                The reason the 'Shell' part works is that the basic shell is added before any raytesting starts [it still fails BUT then the shell is there], but with no shell specified the raytesting starts early-on - before any new geometry is added at all.
                From the error messages I can see the error is that your setup seems to think that the model.raytest is expecting a Float [number] not a Point3d as it is getting.
                In fact it has to be that
                model.raytest([**point**, vector], true)
                which is of course exactly what the code in line #599 does.
                rayt=@model.raytest([zcent, Z_AXIS], true)
                where 'zcent' is clearly defined as a point [as it ought to be],
                the Z_AXIS is clearly a vector, and 'true' is simply saying 'ignore hidden objects'.
                So... I can but deduce that another third-party script is ill-advisedly redefining the model.raytest() method ๐Ÿ˜•
                Though God knows why...
                To see if the error occurs outside of my tool's code, please do the following and report back...
                Use an empty SKP.
                Switch Axes 'on'.
                Make ~1m radius circle, based flat on the ground [Z/Blue=0], centered on the origin [crossing of XYZ/RGB axes].
                Now open the Ruby Console.
                Then copy/paste +<enter> this line of code
                Sketchup.active_model.raytest([Geom;;Point3d.new(0,0,-1),Z_AXIS],true)
                You should get a result something like this [although the face's 'reference' will vary].
                [Point3d(0, 0, 0), [#<Sketchup::Face:0x11aba8e0>]]
                If it succeeds then I can't immediately see why it'd work in the Ruby Console and not my code... ๐Ÿ˜ฒ
                If you get an error similar to the one you've posted we know the built-in model.raytest() method has been broken.
                If there is an error could you try to 'grep' [i.e. 'search' through files for certain text inside them] through the files in the 'Plugins' folder, and its subfolders [and also in the 'Tools' folder], for the text ' def raytest'.
                If you find a file please report back.
                If you disable that file does the model.raytest() 'test' work now ??? ๐Ÿ˜’
                • OxerO
                  Oxer
                  I have done it that you have said, this is the result TIG.
                    Oxer
                    Thanks! ๐Ÿ˜ฎ
                    Now we know that it's has nothing to do with my tool.
                    Rather, the built-in model.raytest() method is broken.
                    Can you try to find the ' def raytest' text in Plugins etc as I explained...
                    There has to be something redefining it.
                    If its inside a compiled .rbs we won't find it, BUT it might be a .rb and we get lucky...
                    We can do mass disablement testing, BUT that's a last resort... ๐Ÿ˜•
                    When we find out what's messing with your system we can 'fix' it...
                      SUFractal
                      Your issue is just the same as Oxer's !
                      It is not my tool... but something broken in the core methods: almost certainly by a 'rogue' script...
                      Can you try the steps I set out for Oxer over the last few posts...
                      Hopefully we can resolve this...
                        SUFractal
                        Use an empty SKP.
                        Switch Axes 'on'.
                        I get this ruby console 'result' when trying your suggestion to Oxer.
                        Sketchup.active_model.raytest([Geom::Point3d.new(0,0,-1),Z_AXIS],true)
                        Error: #<TypeError: (eval):61:in `raytest': can't convert Geom::Point3d into Float>
                        (eval):61
                        (eval):61
                        By the way ... I do not see 'def raytest' in my plugins folder anywhere. Using the "Find" function, I do not 'def raytest' anywhere on my computer.
                          SUFractal
                          @tig said:
                          SUFractal
                          I did just try that ... no luck.
                          • OxerO
                            Oxer
                            I have found these rb files with "raytest" word in the plugin folder only the simple_rays.rb file contains "def raytest2" this is the text:
                            def raytest2 ray
                            hit = false
                            entities = self.entities
                            entities.each { |face|
                            if face.kind_of?(Sketchup::Face) and face.classify_point(ray[0]) > 4
                            plane = [face.vertices[0].position, face.normal]
                            intersection = Geom.intersect_line_plane(ray, plane)
                            if intersection and face.classify_point(intersection) < 8
                            hit = true
                            break
                            I have probed to unistall this file but the Honeycomber plugin does not work.
                            Some .rb files that include "raytest" word.
                            I'll continue search for
                              SUFractal
                              OK, I misread your post ๐Ÿ˜•
                              Some 'search-tools' [like the built-in one on PCs] don't look inside all files and miss .rb ones - so on a PC I'd use 'BareGrep' that looks in ALL files.
                              Did you include subfolders inside Plugins ?
                              If you do a 'find' search for say ' module TIG' what do you get?
                              I know you'll get at least one 'hit' from the above text, as it's in my tool's file [in the subfolder]... If it includes it we know that the ' def raytest' is not defined in readable code [.rb], but it might still be inside an unreadable [compiled] '.rbs' file.
                              If we are sure the problem is not arising from a particular .rb file, we can then use a 'disable/enable-by-halves' approach, to zoom in on the culprit...
                              I'll walk you both through this if method, if we have to...
                              ๐Ÿ˜’
                                Oxer
                                The def raytest**2** is excluded as we are interested in just ' raytest'.
                                The listed scripts USE ' raytest', but do not re-define it...
                                Did the search include subfolders ?
                                My suggested method in the last post will confirm if subfolders are getting searched, if it finds the tool's .rb in its subfolder.
                                Once we have exhausted these possibilities we can consider the 'disabling' options.
                                • OxerO
                                  Oxer
                                  Yes, i confirm you that the search includes subfolders.
                                  I have found other plugin with "def raytest" it's manifold.rb but i have uninstalled it and Honeycombre continues off.
                                  I don't undestand the code ruby but i think the problem isn't in the conflict with others plugins.
                                  Sorry TIG, i can't help you of the other form.
                                    SUFractal
                                    @tig said:
                                    Oxer
                                    The only plugin/script file (including searching within folders) that contains 'raytest' (or 'def raytest') in its contents that I can find ... is your script 'TIG-Honeycomber.rb'.
                                    Same to be said for 'module TIG' .... only in your script 'TIG-Honeycomber.rb'.
                                      It's not a 'conflict'.
                                      Some 'rogue' scripts rewrite native built-in class/methods rather than making a separate process.
                                      Model.raytest takes an argument consisting of an array of a point and a vector
                                      [point,vector], this determines where the 'ray' starts and the direction it is cast.
                                      There is a second optional argument telling it to ignore/include 'hidden' objects in the testing...
                                      So my code's
                                      rayt=model.raytest([point,vector],true)
                                      should work.
                                      The error says it's expecting a 'Float' [number] NOT a 'Point3d' occurs irrespective of how the raytest is run. The Ruby Console method shows this.
                                      If you removed my TIG-Honeycomber_loader.rb its other file won't load and when you restart Sketchup I prepared to bet cash that you'll get the same Ruby Console error when doing a raytest.
                                      So it's NOT my code.
                                      Something else is messing with the correct operation of model.raytest() ๐Ÿ˜’
                                      Here's how to track it down to a specific file.
                                      Make a temporary folder called 'Disabled'.
                                      Sort the files in the Plugins folder by type [i.e. extension name].
                                      Disable around half of those files that end in .rb/.rbs [i.e. move them into 'Disabled' folder] - note how we include the .rb files, because a .rb might be loading a .rbs from a subfolder, although we have eliminated them as the direct culprits.
                                      Restart Sketchup and test for the 'raytest' error again [the SKP with the circle and the one liner in the Console is probably the easiest, and you get the result instantly too].
                                      You'll have one of two results.
                                      1. There is no error.
                                      2. The error recurs.
                                        Let's assume 1. you now know the problem file is in the set left in the 'Disabled' folder.
                                        Move around half of the files from Disabled in to Plugins.
                                        Repeat the 'raytest' testing again.
                                        Once again you have one of the two results - if 1. repeat until you have one file left in 'Disabled'.
                                        That should be the culprit, double check by returning it and seeing if the 'raytest' error recurs. If it's 2. following the reverse procedure outlined below.***
                                        Move it out again if/when it does.
                                        If it's a .rb file it will [probably] be loading a .rbs from a subfolder.
                                        Let me know what it the tool is.
                                        Alternatively let's assume it's initial 2. [error recurs]*** - this time move files in the opposite direction.
                                        Take about half of the .rb/.rbs from Plugins and put them back in Disabled.
                                        When re-tested if the error recurs the problem file is still in Plugins, move half out again until you get the culprit.
                                        If the retest succeeds then the problem file is amongst those have you just moved into Disabled; move half back etc until you zoom-in on the culprit.
                                      The alternative method is this [note that it will on average take the same amount of time, BUT it could give a much faster OR much slower result].
                                      This method is that you move the files one by one from Disabled into Plugins and retest each time.
                                      When it fails the file you just moved in is the culprit.
                                      IF we find no culprit inside Plugins or its subfolder, then we could look at files inside Tools BUT it's unlikely.
                                      If the error recurs will ALL plugins disabled then the fault is in Sketchup itself...
                                      A reinstall or repair might fix it, but I really suspect a 'rogue' script is the culprit.
                                      ๐Ÿ˜ฒ
                                        SUFractal
                                        So my code's
                                        should work.
                                        ๐Ÿ˜ฒ
                                        I've removed all plugin scripts to a separate folder (outside of plugins) ... a few at a time ... to leave only the Honeycomber script. Same issues. ๐Ÿ˜ž
                                        • OxerO
                                          Oxer
                                          I have moved all plugins and all tools (except sketchup.rb, extensions.rb & langhandler.rb) to "DISABLED FOLDERS" and i have tested SKP with the circle and the line in the Console, this is the result:
                                            OK.
                                            Stop the testing!
                                            ๐Ÿ˜ฒ
                                            Can I have exact details of your Sketchup version and your OS.
                                            [both Oxer AND SUFractal].
                                            Something is seriously adrift !!!
                                            I need to speak with the powers-that-be at Google to resolve this - it appears to be a basic error in that specific Sketchup installation...
                                            The model.raytest() is not working as specified...
                                            • 2 / 5
