    [REQ]Explode Groups/Components selected
    6 Posts 3 Posters 2.8k Views 3 Watching
      Wanted explode on all levels Groups & Components selected
      Exist a total explosion of all groups components (selected or not) of the Model by Rick Wilson at Smustard
      Too powerfull πŸ˜„
      Exist Exloder at the Ruby Depot but seems don't work! 😞
      So...
        This code Explodes all Selected Groups/Instances [including all nested Groups/Instances inside these, down through all levels of nesting...]
        Usage: in the Ruby Console type TIG.exploderizer + <enter>
        Paste the code into a file called "TIG-exploderizer.rb" in the Plugins folder and restart Sketchup.
        require 'sketchup.rb'
        module TIG
            def TIG.exploderizer()
                model=Sketchup.active_model
                ss=model.selection
                return nil unless ss[0]
                toex=ss.to_a.find_all{|e|e.class==Sketchup;;Group or e.class==Sketchup;;ComponentInstance}
                more=true
                done=[]
                while more
                  len=toex.length
                  toex.clone.each{|e|
                    next if done.include?(e)
                    tarr=[]
                    tarr=e.entities.to_a if e.class==Sketchup;;Group
                    tarr=e.definition.entities.to_a if e.class==Sketchup;;ComponentInstance
                    tarr.each{|ee|
                      toex << ee if ee.class==Sketchup;;Group or ee.class==Sketchup;;ComponentInstance
                    done << e
                    done.uniq!
                  toex.uniq!
                  more=false if toex.length==len
                model.start_operation("TIG.exploderizer")
                  toex.uniq.reverse.each{|e|e.explode if e.valid?}
                  puts "Exploded #{toex.length} Groups/Instances."
                model.commit_operation
        Note: it will Explode any inner Groups/Instances inside a Component Definition even if it is outside of the Selection, if there is an Instance of it in the Selection.
        EDIT: fixed glitch with component entities...
          Bravo! 😎
          Works like a charm! πŸ‘
          TIG The Terminatorizer! 😎
          • sdmitchS
            sdmitch
            Isn't
            tarr=e.entities.to_a if e.class==Sketchup::Group or e.class==Sketchup::ComponentInstance
            only true for groups? Wouldn't it need to be e.definition.entities for components?
            http://sdmitch.blogspot.com/
              You are right - I rattled it off too quickly !
              Well spotted... β˜€
              I've adjusted the original code to suit...
              Pilou... please re-copy/paste...
                Sure!
                Terminatorizer the Return! πŸ˜‰
