    Model outlines
    5 Posts 3 Posters 264 Views 3 Watching
    • V Offline
      Vicspa
      Hello everybody again, I just downloaded a table with chairs from the warehouse, but I can't figure out how to show it in outline form, when I hit the outlines in the styles palate the whole thing dissapears.
      Thanks goes to "Basic Works"
      • bazB Offline
        baz
        Suggest you attach the Skp.
        • V Offline
          Vicspa
          The Skp file is too large to insert, so here is the link, http://sketchup.google.com/3dwarehouse/details?mid=cde00e3096276232d5cc62720ec8273c&prevstart=0
          when I click the outlines in the styles palette it disappears.
          Thanks goes to "basic works"
            All the edges in that model have been either hidden or softened. That'll make it a PIA to get the edges back. You can go through and edit the components and unhide the hidden lines. Turn on Hidden Geometry in the View menu and then select all of the geometry inside the component. Under Edit, choose Unhide>Selected. Rinse and repeat for the rest of the components.
            Actually, I've done it for you.
            Table and Chairs.skp
            • V Offline
              Vicspa
              Thank you so much Dave, I will try all you said since I do have to learn to do it by myself. ๐Ÿ‘
