    [REQ] find similar groups and create components
    26 Posts 6 Posters 2.4k Views 6 Watching
    • soloS
      I may have an outdated lib file, can you direct me to the most recent one?
      • EarthMoverE
        EarthMover
        2.6 is his latest, but it's not specifically needed for the plugin. - http://forums.sketchucation.com/viewtopic.php?t=30503
        However, like you, on my end the plugin itself seemed broken for a while.. If I remember I re-downloaded and re-installed all of my plugins from Thomas and it seemed to fix the issue. Can't say what it was specifically. If it is working properly, when you run the script with nothing selected you should receive a warning that says "Analyzing all definitions in a model can take a long time. Are you sure you want to continue?"
        Content Creator at Skapeup
        • soloS
          I re-installed again and did everything correctly even got the warning and clicked okay and nothing happened.
          I dunno what's up.
          • sdmitchS
            sdmitch
            I'm assumming that the groups don't have names and must be compared entity by entity?
            http://sdmitch.blogspot.com/
            • soloS
              I believe you are right, they are all grouped as per import from Deep exploration which I used to convert the .stp to .skp.
              • gillesG
                gilles
                Solo, could you try this:
                #1 make one of the similar groups a component ( explode the group before )
                #2 select the component
                #3 run Similar objects/ Replace Similar Objects.
                All similar groups become instances of the component.
                • sdmitchS
                  sdmitch
                  Solo, I hate to rain on your parade but creating a group and copying it 99 times versus placing 100 instances of that group converted into a component actually increased the filesize.
                  • soloS
                    What I want is to make it faster to navigate in SU, so making it a component and then the other 99 of the same mesh as a instance of that component would make it lighter in SU.
                    • soloS
                      I tried that to no avail, nothing happened.
                      • soloS
                        This is the ruby consol report:
                        Replacing Similar Objects...
                        Error; #<NoMethodError; undefined method `definition=' for #<Sketchup;;Group;0x148c1b6c>>
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;139;in `replace'
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;137;in `each'
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;137;in `replace'
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;119;in `each'
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;119;in `replace'
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;33
                        C;/PROGRA~2/Google/GOOGLE~1/Plugins/tt_cc.rb;139;in `call'
                        • sdmitchS
                          sdmitch
                          I believe that is because only components have definitions.
                          • gillesG
                            gilles
                            You should report to Thomthom.
                            Could you post a model?
                            • soloS
                              Model is 347MB 😲
                              • gillesG
                                gilles
                                Could you isolate some groups in a separate model to give it a try?
                                  Components, Groups AND Images ALL have "definitions".
                                  However, unlike "instance.definition" there is NO API "group.definition" method [OR indeed "image.definition"] UNLESS it has been added by additional code within a script to make the method - so therefore this suggests 'something is missing', because TT WOULD have included for this somewhere in his coding... ?
                                  So... do you have all of the support files installed properly [needed TT Libs etc] ?:
                                  • gillesG
                                    gilles
                                    It seems that TT Libs aren't request for this one.
                                      That may be... but 'group.definition' does need to be created somewhere...
                                      PM TT... πŸ˜•
                                      • soloS
                                        Okay, I downloaded the window model from the thread where the plugin exists and ran the test and it worked exactly as it should, so this means my instalation and all needed files are in order.
                                        I then created a new scene and made a cube, grouped it and created 20 instances of it then ran the script which did nothing....is it me not understanding what this script should do or is something funny going on?
                                        • gillesG
                                          gilles
                                          If you make on them different ( explode then group or better make component ) it should work.
                                          if you have 1 group + 20 instances of it they all have the same definition, so there is nothing to change.
                                          .... I think; ❓
                                          • soloS
                                            Take this example, I have 8 tubes (grey) and 16 rings (red) they are all groups, what I'd like to happen is for a script to see that there are 8 identical tubes and 16 identical rings and it then makes a component from one of the tubes, delete or changes the others to be an instance of the first component, same for rings.
