Bullion
@johnsenior1973 said:
There's a list of this type of program. It says Artcam Pro costs $7,500.
thanks john...
artcam pro is an amazing software that suits the application in my query, but it is too pricey...
Hussel,
I made an animated avatar, of a silver eagle, several years ago, using SketchUp.
The obverse and reverse are merely texture images, as is the reeding on the edge. I produced 8 frames for the animation, rotating the model 45Β° for each frame.
For just about any coin, the relief is slight (compared to diameter,) so you should be able to generate a reasonable facsimile, using texture images alone.-Taff
@taffgoch said:
Hussel,
[attachment=0:32vst3ys]<!-- ia0 -->Animation4.gif<!-- ia0 -->[/attachment:32vst3ys]
For me that is amazing Taff, thank u so much for sharing.
i thought texture only works when rendering using another software, not in SU.
i need to explore more on that.
thanks bro..
Take a look at this military challenge coin and see what you think of SketchUp's capability for your bullion project:
http://forums.sketchucation.com/viewtopic.php?f=81&t=12112&p=86071&hilit=CHALLENGE+COIN#p86071 -
http://forums.sketchucation.com/viewtopic.php?f=81&t=12112&p=86071&hilit=CHALLENGE+COIN#p86071Wow!...nice coin Roger..amazing.
1st of all, the bullion is more like my future target not a project since i am still new in SU.
I thought that SDS is a basic sculpting tool unlike Artisan. However, the result you've made says it all.
Experience + Imagination + Correct tools = Cool results
Thank you for sharing bro..
cotty,
Great suggestion!
There is a heightfield generator plugin for SketchUp, that can take a greyscale height image, and produce a relief mesh. It may be suitable for the job, comparable to that which you describe.
Didier Bur's heightfield gen v6
-Taff
@cotty said:
somewhat complicated, but possible...
Thanks for your suggestion Cotty...
Brilliant though i am not quite understand yet..
Hussel see the elephant sculpture on the following page: http://forums.sketchucation.com/viewtopic.php?f=15&t=43928&start=15 . Just a handful of photos of your coin from multiple angles and you can create the mesh at the press of a button with "123d Catch" from AutoDesk.
Maybe Bitmap to mesh (Thomthom).
Thank Roger and Gilles...
I will check those things out soon.
Both looks very interesting but the tools from Thomtom reminds me of Artcam.
It turns a 2D Image to a 3D model. I think I've seen the demo in Youtube.
