    Bullion
    16 Posts 7 Posters 1.0k Views 7 Watching
    • H Offline
      Hussel Hann
      Hi guys...
      I have a question. Did anyone ever try to model a bullion like the image below?
      Does sketchup + all the plugins have the capabilities to do so?
      What software is more capable to model something complicated like the bullion coin?
      Pls share your thoughts..
      Thanks guys..
      p/s..hope this new topic is not breaking any rules 😲
      • jason_marantoJ Offline
        jason_maranto
        3DCoat or ZBrush would be good choices for this type of thing if you want to create your own -- although if you are rendering you can simulate the "relief" results fairly well with a normal map, which means SketchUp could a be a perfectly suitable platform to model the base coin.
        Best,
        Jason.
        • H Offline
          Hussel Hann
          Best,
          Jason.
          Thanks Jason..
          very much understand now.
          thanks a lot bro
            johnsenior1973
            Don't know how much it costs, probably in the thousands, but Delcam Artcam is geared towards this type of thing.
            http://www.artcampro.com/index.php/about-artcam
              johnsenior1973
              There's a list of this type of program. It says Artcam Pro costs $7,500.
              (shopbottools.com)
              • H Offline
                Hussel Hann
                (shopbottools.com)
                thanks john...
                artcam pro is an amazing software that suits the application in my query, but it is too pricey... 😒
                • TaffGochT Offline
                  TaffGoch
                  Hussel,
                  I made an animated avatar, of a silver eagle, several years ago, using SketchUp.
                  The obverse and reverse are merely texture images, as is the reeding on the edge. I produced 8 frames for the animation, rotating the model 45Β° for each frame.
                  For just about any coin, the relief is slight (compared to diameter,) so you should be able to generate a reasonable facsimile, using texture images alone.
                  -Taff
                  "Information is not knowledge." -- Albert Einstein
                  • H Offline
                    Hussel Hann
                    @taffgoch said:
                    Hussel,
                    [attachment=0:32vst3ys]<!-- ia0 -->Animation4.gif<!-- ia0 -->[/attachment:32vst3ys]
                    -Taff
                    For me that is amazing Taff, thank u so much for sharing.
                    i thought texture only works when rendering using another software, not in SU.
                    i need to explore more on that.
                    thanks bro.. πŸ‘
                      Roger
                      Take a look at this military challenge coin and see what you think of SketchUp's capability for your bullion project:
                      http://forums.sketchucation.com/viewtopic.php?f=81&t=12112&p=86071&hilit=CHALLENGE+COIN#p86071
                      http://www.azcreative.com
                      • H Offline
                        Hussel Hann
                        Wow!...nice coin Roger..amazing. 😲
                        1st of all, the bullion is more like my future target not a project since i am still new in SU.
                        I thought that SDS is a basic sculpting tool unlike Artisan. However, the result you've made says it all.
                        Experience + Imagination + Correct tools = Cool results πŸ˜†
                        Thank you for sharing bro..
                        • cottyC Offline
                          cotty
                          somewhat complicated, but possible...
                          • Black & white image from coin
                          • Matlab (or free clones?) to display as 3D surface
                          • Export as STL
                          • Import in SketchUp
                          • Use as real 3D relief (if you have a faster computer than me πŸ˜• ) ...
                          my SketchUp gallery
                          • TaffGochT Offline
                            TaffGoch
                            cotty,
                            Great suggestion!
                            There is a heightfield generator plugin for SketchUp, that can take a greyscale height image, and produce a relief mesh. It may be suitable for the job, comparable to that which you describe.
                            Didier Bur's heightfield gen v6
                            -Taff
                            • H Offline
                              Hussel Hann
                              • Export as STL
                              Thanks for your suggestion Cotty... πŸ‘
                              Brilliant though i am not quite understand yet.. πŸ€“
                                Roger
                                Hussel see the elephant sculpture on the following page: http://forums.sketchucation.com/viewtopic.php?f=15&t=43928&start=15 . Just a handful of photos of your coin from multiple angles and you can create the mesh at the press of a button with "123d Catch" from AutoDesk.
                                • gillesG Offline
                                  gilles
                                  Maybe Bitmap to mesh (Thomthom).
                                  http://forums.sketchucation.com/viewtopic.php?t=31339#p275772
                                  • H Offline
                                    Hussel Hann
                                    Thank Roger and Gilles...
                                    I will check those things out soon.
                                    Both looks very interesting but the tools from Thomtom reminds me of Artcam.
                                    It turns a 2D Image to a 3D model. I think I've seen the demo in Youtube.
