    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 481.9k Views 114 Watching
    • emerald15E Offline
      emerald15
      Having some spare time this Friday, I've been looking for answers. I was going to pose my questions re: Layout - specifically on raster vs. vector resolution & on the possibility of smaller PDF file sizes. However, I found this thread & have not only found - well, if not a solution, then at least confirmation that the files sizes are what they are... but have spent the last hour enjoying studying some very beautifully presented drawings and 'listening' to some like minded opinions on SU vs. AutoCAD.
      I too have quit on AutoCAD in favour of SU in the last year & almost everyday find something new I like about it. Yes, LO is a bit 'clunky' but my scrapbook & templates are better organised now, which is a help.
      My work (exhibition design) is nothing like as complex as the above, so seeing LO cope with these presentations... well if you can - then I can too! πŸ˜„
      • EdsonE Offline
        Edson
        hi emerald,
        regarding file sizes, there are some utilities that allow one to reduce pdf sizes by 75% (at least on the mac size of things) without perceivable loss of quality.
        http://www.mahfuz.arq.br
        • fouronethirtyF Offline
          fouronethirty
          all this and all that , i just have to wait for the developers to release new improved version of l.o, i do all of my architectural documents using su to l.o. it works great, just one thing, l.o needs more tools and improvements, i know guys at google knows exactly what to add there, simply amazing tools works just fine and making things easier. πŸ˜„ many tnx to them
            lapx
            Love your work and style Sonder! Everyone is pushing revit including consultants because its BIM capabilities which sketchup is not strongly suited with these characteristics at present. I'm sure one day maybe but currently schedules, takeoffs, referencing,interferencing is not addressed adequaltely I presume? How do you deal with some of the timesavers that are highly dependable in BIM programs not to mention coordinaton with other consultants who may not use sketchup.
            This is perhaps the biggest reason people continue to use autcad products because its easier to trade files with everyone else w/o having to deal with conversions. We work on 10s of million dollar projects. It would be virtually impossible to do this work exclusively using su it seams. I wish!
            • ashscottA Offline
              ashscott
              Wow, this is a very useful thread, some of the drawings posted are truly inspiring.
              I am halfway through an engineering project and have been creating working drawings directly in SU (many, many layers), exporting as .jpg (I can get a high enough resolution that way), and then compiling the .jpgs into a .pdf
              However, reading this thread has shown me I can do a much better job with layout if I will just take the time to learn it. I initially turned away from Layout as it seemed so unintuitive. Hopefully this will save me a heap of the re-working I am having to do when someone objects to something in a working drawing.
              By the way, you all keep referring to working in raster mode in LO but I can't seem to get dimensions accurate enough in raster mode - I have to switch to vector to ensure the dimension is snapping to the point I think it is snapping to - has anyone else experienced this?
              Just some stuff I do with Sketchup.
              • bmikeB Offline
                bmike
                i work in vector for the most part. hybrid to show section cuts and various materials and 'sketchy' styles as needed.
                i did a few projects in SketchUp with layers and views - a PITA compared to the control you'll have in LayOut.
                yes, there are some un-intuitive bits to it - but once you settle in on a process, you will get faster with it.
                  sonder
                  Just an update. These are how I am formatting my detail sheets. There are 6 exterior sheets and 3 interior sheets for this particular project. So far the speed is working out great.
                    sonder
                    Lighting plan.
                    • pbacotP Offline
                      Beautiful, Sonder ! the details look great with the fog. 3d details something I'd like to do more of. Usually only end up doing 1-2 3d details if at all. Very useful for water proofing in particular They don't look that hard to model--a lot of push-pull, but I bet finding the right view for every one takes some work. Your cutaway technique is very effective and obviously well thought-out. Then finishing, sending all to LO and final tweaking must take some more time. I just think it would blow my hours budget...
                      Curious about your light switch depiction, but that's not a SU thing.
                      P.S. "Metal Ridge" looks like a valley to me.
                        sonder
                        Thanks for that catch. Yes it is a valley. I set the view centered in SU and save as a scene, so I don't actually do much adjusting in LO, other than resizing the reference box. These detail sheets really didn't take me long. I do have a huge library of details though, so editing them for individual jobs is pretty quick. Notation took me the longest because this is my first round of full details with Layout. The next jobs will get quicker.
                        The light switching and symbols are all done in LO. The switching looks a little different as this home will have a full lutron/savant system with lutron control panels and Ipad docking stations for various automated controls.
                        • bmikeB Offline
                          bmike
                          wow, sonder, really nice details and electrical plan!
                          i'll have to mess around with fog... nice effect.
                          -mike
                            sonder
                            Thanks.
                            Yes the fog really helps with depth and also lightens the model a little for crisper notes. I am using that affect on all drawings now including plans. The electrical plan above is without fog, but in my next round it will have a slight fog affect.
                              seasdes
                              I do not know whether there is a answer to this. However, is it much slower to use Layout for construction drawings compared to CAD?
                              Sorry if I am pushing in here. But my question relates to construction drawings.
                              Walter
                              Using Sketchup Pro 2019
                                sonder
                                Walter
                                For me it is faster, but I have developed my whole detail library in SU over the past 5 years. Once you get used to how LO works, I think it is faster. If you are just learning, then count on a learning curve which will be slower at first. The key is setting up all your scrapbooks for standard notation and graphics. Keep you SU models tight and maintain your scenes. I just finished producing 3 sets of construction documents for 3 different custom homes. All three were completed over the last 3-4 months with each set having between 45-55 sheets of architectural drawings. This was my first time utilizing LayOut, so there was some time involved in setting up standards / experimentation.
                                  seasdes
                                  Thank you Sonder
                                  I am working on a project that is a bit rough around the edges. I think that I used the wrong style.
                                  I will pay more attention to your recommendations on the next project.
                                  Walter
                                  • bmikeB Offline
                                    bmike
                                    Another small project for a workshop.
                                    https://lh3.googleusercontent.com/-M9q773YwJH8/T6p8LKfkUMI/AAAAAAAASwY/doQR7UawG4s/s1111/oldstonebarn-3-22-11_01.jpg
                                    https://lh4.googleusercontent.com/-yLUqMkN0uhk/T6p8Lm0pT1I/AAAAAAAASwc/pYLzFNPq-9A/s1111/oldstonebarn-3-22-11_14.jpg
                                    https://lh5.googleusercontent.com/-g0JVrNLkqXo/T6p8MJ-W7aI/AAAAAAAASws/3NtM1N1e1rA/s1111/oldstonebarn-3-22-11_15.jpg
                                    https://lh4.googleusercontent.com/-B0tHwN6dO_I/T6p8M5AslGI/AAAAAAAASw0/LaGqNH2fnHo/s1111/oldstonebarn-3-22-11_16.jpg
                                    On deck are 2 small buildings - I'm taking the entire process through SU and LO, as well as another small timber frame workshop project (similar in scope to these drawings).
                                    Here's hoping Trimble sees the value in LayOut and ups the development of it. It is my go to tool now for taking 3d to 2d.
                                      pirun14
                                      working drawing Layout sketchup for interior architecture http://www.facebook.com/pages/Layout-sketchup-Thailand/142833949164127
                                      http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc7/475149_227919923988862_514627023_o.jpg
                                      http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/463546_227920020655519_736370999_o.jpg
                                      http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/469696_227920083988846_803786330_o.jpg
                                        pirun14
                                        build-in TV in Bedroom
                                        http://www.facebook.com/media/set/?set=a.233361276778060.50387.142833949164127&type=3
                                        • pbacotP Offline
                                          Pirun! that's wonderful crisp pictures and fresh format.
                                          I don't know if I commented on your last project bmike. All your stuff is really great. What can I say? It gives me hope for LO (and the human race....for that matter)! πŸ‘ πŸ‘ πŸ‘
                                          Pirun (or anyone). It would be great if you could comment:
                                          What was difficult in presenting this project in LO? Did you learn anything new? Any good tips on dimensions or any other tools? Is this output in vector? to png?
                                          THANKS for posting. Peter
                                            mwm5053
                                            This is really great stuff 😍 😍 😍 I've been getting to know LO in the past week or so reading Bonnie Roskes's ebook and looking for examples of layout in LO so I'm awe struck by these examples.
                                            Thanks to all the contributors.
                                            2011 iMac
                                            SU 2015 Pro, 2017 Make
                                            V2 Twilight
                                            macOS Sierra 10.12.5
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
