    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 243.3k Views 43 Watching
      Several issues overlapping...
      First you have a model that is a jumble of nested components/groups.
      If you place a cutting component onto a face that is not in the current active entities context, then although it glues onto it, it won't 'cut' as it has no contact with the geometry in the other context.
      Secondly, your 'problem' window component is made up of other components - these internal bits don't need any special 'behaviors'.
      IF you want the window to cut the wall at the 'rectangle' that's just in front of the assembled frames etc, then leave it as a simple rectangle, don't weld it into a looped curve [unless you want any punched reveals to have smoothed edges], and you also don't need to make the rectangle into a component [or group], and it certainly doesn't need to be a component with any special 'behaviors' added to it - please leave it as plain geometry inside the cutting component - then it works for me when used inside a common context !
      • irwanwrI Offline
        irwanwr
        finally made it, thank god.
        thank you very much for the tool πŸ˜„
        window 1 cm below plaster
        wall punching window through
        6 x 17 Gg Bandung Jl Amaliun + Denah 2.skp
        • guanjinG Offline
          guanjin
          @tig said:
          To make [or edit] a locale file look in the ../Plugins/TIGtools/ subfolder.
          There are several #HolePunchTool...lingvo files.
          Copy the base file #HolePunchToolEN-US.lingvo as #HolePunchToolIT.lingvo
          for ITalian.
          To find your exact locale 'code' type/copy&paste this in the Ruby Console
          Sketchup.get_locale.upcase
          This 'code' then goes on the end of the file's name, before .lingvo in place of 'EN-US'.
          Edit the new file and you'll see lines of code like this:
          Exiting.<==>Exiting.
          The text to the left of the <==> is the hard-coded English version and to the right the translation - obviously in the English lingvo file it's the same words!
          Change the right-hand side to your locale translation, keeping punctuation and spaces etc if any, so for an IT version you might have.
          Exiting.<==>VerrΓ  chiuso.
          Complete your translations and then save the file.
          When you restart Sketchup the tool should display in the locale language as it'll automatically find the new file.
          If you find some text that's wrongly translated, then check the lingvo file and edit it.
          If you find that some text has not translated, then check the lingvo file and fix it - if the text is not actually in the file then let me know as sometimes bits of hard-coded text and the lingvo text mismatch - although I think that this one is pretty solid.
          TIG hello:
          I translated the text for the ZH-CN, tool display in English? ? ? πŸ˜’
            Is this a question?
            Or is it a statement ?
            You are free to translate any tool's linvgo into Chinese [although some have been translated already].
            All I ask is you zip the new lingvo file and post it in the tool's thread with an explantion, so others can use it too, and I will then package it with any future updates of the tool too...
            πŸ˜‰
              Here's Guanjin's Chinese lingvo file [Thank you!].#HolePunchToolZH-CN.zipUnzip it and place the file in the TIGtools folder in the Plugins folder...
              • guanjinG Offline
                guanjin
                @tig said:
                Here's Guanjin's Chinese lingvo file [Thank you!].[attachment=0:2ftu9qht]<!-- ia0 -->#HolePunchTooZH-CN.zip<!-- ia0 -->[/attachment:2ftu9qht]Unzip it and place the file in the TIGtools folder in the Plugins folder...
                Is still in English, can not display Chinese!!
                  You made a spelling mistake in the name; I've corrected the posted version...
                  ...TooZH... should have been ...ToolZH...
                  • guanjinG Offline
                    guanjin
                    tig I too admire you, I was too stupid, I want to translate all your tools in China to promote! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                    • JQLJ Offline
                      JQL
                      I'm new to sketchup but obviously I realized already that half its potential is due to people like you. So thank you!
                      This tool immediatly struck me by its usefulness, (well it sort of punched me in the nose, actually).
                      It still lacks one thing to be perfect though, (not that I am complaining or anything, I don't wanna be punched again):
                      You clearly state that the inner walls must be paralel to the outer ones. However, would it be very hard to make the tool work even if they're not?
                      To put in other words, could one use this tool in a wall made of Joint-pushed-pulled loft surfaces?
                      www.casca.pt
                      Visit us on facebook!
                        JQL
                        At the moment it is a 'wall punching tool'... and walls have a front and a back face that are parallel...
                        Ti allow other permutations gets very complicated - as you will find if you try to PushPull a shape on an outer face it will not punch an inner face if it's not perpendicular to the push/pull direction [i.e. parallel with the original face]... You can get around it by pulling it further, intersecting the new form with the back face and erasing the unwanted bits to leave a hole - but this is pretty complex to code in...
                        A JPP'd pair of faces should be parallel.
                        If the punching spans more than one facet you'll only get the inner hole in the most 'central' one.
                        Best to do a second JPP, intersect and erase unwanted bits?
                        • JQLJ Offline
                          JQL
                          Thought so... If it isn't easy to do "by hand" it should be very hard to automate. The work around I used was to insert a volume inside the window component in a separate layer. Then I intersected the inner wall with the component and removed what I didn't want. I then hid the separate layer of the volume. To close the walls I had to make the component unique and draw the necessary lines. Repeat the process for the other windows... Hate complex shapes.
                          It will be an headache to change the window positions later and not being able to drag the inner hole with it.
                          I will try to find a tool that "drapes" a hole in a surface in the direction of a given face/component. It would be cool if it could also "drape" a fill in the hole after, so I could easily heal the face again at a much later time if i need to... maybe by extending all the lines in the surface. There should be something like that.
                          Any way thanks for your excelent tools and your unbelievably fast answer! That I just didn't expect!
                          www.casca.pt
                          • U Offline
                            UncleMonkey
                            Hi, TIG,
                            I'm using SU8 free, on a MacBook Pro Core Duo 1.83 GHz, 1.5 GB Ram, OS 10.6.8. with latest Java patch. The #HolePunchTool.rb is located at
                            /Library/Application Support/Google SketchUp 8/SketchUp/plugins along with deBabelizer.rb, and the various .lingvo files are in plugins/TIGtools.
                            In the past I've sometimes been able to use the Hole Punching Tool to great advantage, but not now. No matter what I do, I get the message "No Suitable Punching Component(s) Selected. Exiting."
                            This happens both with the actual window I'm trying to use, and with a test component that's just a rectangular prism. Both are set to glue and cut hole. I've tried pasting the window/prism inside the editing context of the walls, exploding the wall component before trying to punch, and just positioning the window component on the wall without opening either. Tried selecting both punching component and target, or only component. Nothing helps.
                            I know I'm missing some really simple point here, and it's embarrassing to ask you, but I can't seem to figure it out on my own, and the advantages of your tool are irresistible. Thanks for saving countless people countless hours of intersecting and erasing, and for your help with this.
                            David
                            This is the whole problem, in a file reduced to the relevant elements only.
                              Your window has its insertion-point [axes] on its back corner, not the front - where it might normally be put.
                              It also is placed onto the wall's inner-face - not its outer-face - so there's nothing to be punched, as it punches backwards from the component, expecting to meet an inner-face.
                              If you move the instance onto the outer-face and reglue it to that, then it will punch a hole through both faces of the wall, although at that point the window is then balanced on the very front of the wall.
                              May I suggest that you relocate the window's axes so that it cuts any wall at the correct place, when you insert it on the outer face, as intended by the entire concept of 'cutting-components'.
                              Also having a cutting-component made of lots and lots of subcomponents will take ages to work out the cutting/punching 'hole'.
                              Try exploding nested geometry to speed it up.
                              Basically you are making your cutting-component too complex and with strangely placed axes...
                              • U Offline
                                UncleMonkey
                                Many thanks, TIG! I had completely forgotten how axes placement affects cutting and punching. I am thinking that as a general rule, it might be best to start out with punching components reduced to the perimeter only, and when they're placed to my satisfaction, open one to edit all and then insert the subcomponents. (My reason for wanting to keep them unexploded is so I can get an easy count of how many to put in my BoQ.)
                                The amount and quality of effort you and others like you (Gaeius, for example) put into helping us struggling beginners is probably the best thing about SketchUp. Thanks again!
                                David
                                  Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                                  Fixed rare DefnsObserver Bugplat! onQuit with some DC coded edits.
                                    baiduaiya
                                    Thanks TIG.
                                    • pbacotP Offline
                                      I would like to use this tool, but other than a couple successes, my experience so far has been about 50/50 the window moves to the inner wall or SU crashes.
                                      hole punch test.skp
                                        @Peter
                                        I can get it to flip faces, but only if I put the cutting window component neat the top of the wall, and the inner wall-face has a lower top.
                                        This means that the hole/reveals cut are incomplete and something goes wrong...
                                        I'll look at it sometime when I am less busy... but meanwhile try and check that the hole the component will cut falls fully onto the inner wall-face...
                                        • JQLJ Offline
                                          JQL
                                          Dear TIG,
                                          I'm divided between using Hole Punch tool or Double Cutting Components to create openings.
                                          I've attached an image and .skp with details:
                                          http://www.casca.pt/varios/holepunchtool.jpg
                                          If Hole Punch Tool could automatically create steps 4 and 5 on image, we could have the best of both worlds.
                                          If by any chance you were able to adapt the observers(!?) you use to connect faces and components, and make them connect both components as in step 7,then Hole Punch Tool would be, in my modest opinion, a revolution in the way people model windows in Sketchup.
                                          Of course I'm totally incapable of coding, so I'll be looking forward for your reply... ansiously!
                                          Best regards,
                                          JQL
                                          Sketchup File Used for "wishlist"
                                          www.casca.pt
                                            Here's an update http://sketchucation.com/forums/viewtopic.php?p=271170#p271170
                                            It cuts through multi-leaf walls and also into groups onto which a cutting instance is glued [but do NOT copy grouped punched-components because the reveals will not remain inside the group!]
                                            • 7 / 10
