    Table Scene - MaxwellRender
    20 Posts 3 Posters 3.2k Views 3 Watching
    • jason_marantoJ Offline
      jason_maranto
      I'm not sure what you mean -- I just added a chair (via import) to the scene no issues at all... I never even opened RealFlow.
      Best,
      Jason.
        panpanndundu
        i mean when we add another object that must be interacted with particle without using realflow, cuz when we load a particle from realflow we cant see the mesh without rendering. so i thing it easier to load mesh than particle bin. actually i just take some piece of the object to simulate in Realflow, cuz it take much time when we use big part of the object.. Sorry if im wrong, i never tried realflow render kit before..
          jason_maranto
          Oh yeah, totally, you would have to go back to Realflow if you want anything to factor into the simulation -- all the RealFlow Render kit allows you to do is change the meshing options at render time... so the geometry the simulation is interacting with doesn't change, only things like the detail of the mesh, which may save you a couple of trips back and forth to RealFlow.
          However one important factor is it does allow for motion blur effects in Maxwell, which you cannot get from a meshed object in Studio, since Studio does not support animation (nor does the SketchUp plugin).
          Best,
          Jason.
            panpanndundu
            Wow. . i think i must try it.. thank you very much jason.
              jason_maranto
              You are very welcome -- I'm excited to see what you show us next πŸ˜„
              Best,
              Jason.
                panpanndundu
                okey .. I will submit my next rendering with Realflow Render Kit for Maxwell..
                Best,
                Pandu P
                • hellnbakH Offline
                  hellnbak
                  I don't understand any of what you guys were talking about, but I do like the results πŸ‘
                    jason_maranto
                    RealFlow is a physics simulation software (think of it like SketchyPhysics on steroids) often used for water/fluid simulations. Next Limit (makers of Maxwell) specialize in physics simulations software's -- Maxwell being a light simulator.
                    Being from the same software company, naturally there is a fairly powerful link between the two packages that I was pointing out -- the bottom line is: we should see some even cooler images soon πŸ˜„
                    Best,
                    Jason.
                      panpanndundu
                      Jup, just like SketchyPhysics on Fluid Mode. The 2nd image I've used SketchyPhysics for glass arrangement. Realflow is a awesome program, and we can combine with skethcup by export to obj file, then just let maxwellrender finish it all. πŸ˜„
                      I will be doing the update image by this week end, and submit as soon as possible, of course by using Relflow renderkit for maxwell just like jason recommend.. πŸ˜‰
                        panpanndundu
                        In Progress sketchup-RealFlow-Maxwell
                        Pandu P
                          panpanndundu
                          final render
