    Component definition list from Ruby vs SU window
    5 Posts 3 Posters 784 Views 3 Watching
    • P
      Pout
      I use this code to list all used component definition names:
      def TESTXD.listcompnames1
      		$componentnames=[]
      		Sketchup.active_model.entities.each{|e|
      			TESTXD.listcompnames2(e)
      		$componentnames.uniq!
      		$componentnames.sort!
      		puts ($componentnames)
      	def TESTXD.listcompnames2(e)
      		theclass=e.class
      		if theclass==Sketchup;;Group
      			gen=e.entities
      			gen.each{|gent|
      				TESTXD.listcompnames2(gent)
      		elsif theclass==Sketchup;;ComponentInstance
      			$componentnames<<e.definition.name
      			e.definition.entities.each{|ent|
      				TESTXD.listcompnames2(ent)
      This gives me a list in the ruby console.
      Now if I compare this list with the list shown in the components windows I see that certain definitions are available in ruby but not in the components window.
      Is this due to the fact that those component definitions are only used in nested component definitions? That makes no sense.
      Or maybe I'm missing something.
      • P
        Pout
        ok, hitting 'Expand' would be a good idea 😳 😳 😳 😳
          If you have a lot of model entities, duplicate instances etc it can take a while to sift through it all.
          It's quicker to iterate the model.definitions and compile lists of 'names' [or references] for all groups, components, used-components, unused-components and images thus
          defs=Sketchup.active_model.definitions
          groups=[]; group_defs=[]; group_refs=[]; images=[]
          compo_names=[]; used_compo_names=[]; unused_compo_names=[]
          compo_refs=[]; compos_instances=[]
          compos_instances_names=[]; compos_instances_refs=[]
          defs.each{|d|
            if d.image?
              images << d.name
            elsif d.group?
              groups << d.instances[0].name
              group_defs << d
              group_refs << d.instances
            else ### compo
              compo_names << d.name
              if d.instances[0]
                used_compo_names << d.name
              else ### unused
                unused_compo_names << d.name
              compo_refs << d
              compo_instances << d.instances
              ins=[]; d.instances.each{|i|ins << i.name}
              compo_instances_names << [d.name, ins]
              compo_instances_refs << [d, d.instances]
          Choose which data you want to extract for later use...
            Note that the DefinitionList include groups and images as well. As TIG mentioned, some components are hidden by default in SketchUp's Component Browser - sub-component of imported models for instance. They are marked with ComponentDefinition.internal?.
            Detailed explanation of the ComponentList and ComponentDefinitions in SketchUp: http://www.thomthom.net/thoughts/2012/02/definitions-and-instances-in-sketchup/
            • P
              Pout
              great, thank you both for the information!
