    Sofa stitching
    6 Posts 3 Posters 342 Views 3 Watching
      aser28
      Hi i am doing sofa drawings but i couldnt manage to do stitching on the sofa is there any way that i can create that with su. Thanks.
      • mitcorbM Offline
        mitcorb
        Doing the sofa stitching is possible. However, if this sofa is part of a larger model, it may just be adding to the file size and therefore adding processing time for such things as renders, if not additional modeling. Many would say, try to find a texture with the desired stitching pattern in the image, or make your own. Or at least create a component with only the visible surfaces and multicopy that, so that the only addition would be the component instance data in the file.
        Ask yourself if, in a scene, will the stitching actually be visible.
          aser28
          Thanks but i want to do it with modelling
          • hellnbakH Offline
            hellnbak
            This is probably too crude for your purposes, but I have sometimes used the construction lines in Tools On Surface to simulate stitching in some of my car models. For what it's worth
              aser28
              is constrution lines visible in renders?
              • hellnbakH Offline
                hellnbak
                Well, I don't know about that, I'm not a renderer (would like to be, but it seems to be beyond my capabilities 😞 )
