Push pulling to a curve
8 Posts 2 Posters 170 Views
    rhammans
    Hello all,
    A newbie here trying to get a sketch created for a chair that I built for a client. Attached is a screen shot. I have a curve for the backrest that is also chamfered. You can see when I push/pull I end up with a part I can't eliminate. Any help would be greatly appreciated. Rick
      Hi Rick,
      What part (face) is that you want to PP? Could you also include a screenshot when you did not start the PP? Or better; attach the model itself?
        rhammans
        Thanks for the help I am trying to push the chamfer off and cant get past the curve. Here is the file
        Thanks again Rick
        hammansConoid1.skp
          Press the ctrl key when PP'ing further than that point. At the end, select all > right click > Intersect selected then start deleting unwanted stuff. This is how it should look like afterwards (promise me that you will also try top do it)
          hammansConoid1.skp
            rhammans
            Trying, but not having a lot of luck. I right click select all then right click for intersect, it gives me choices with model or context. Both won't b/c I get a dialog, Nothing connects with model. and when I select the top of top face of the triangle it also selects parts of the model, same with trying to erase the common face the two parts share. I really want to learn this thanks for your help.
            Rick
              Don't worry of the two faces being mysteriously connected. Just delete the triangle face and redraw an edge of that top face.
              Are you saying that after selecting all, you do not have the intersect faces... selected option? Intersect with model will do in this case actually, too.
                rhammans
                Gaieus,
                Thank you finally got it. You are a godsend.
                Rick
                  One more thing: you will end up with a bunch of unnecessary edges dividing that face that you have reversed (blue). You can delete all horizontal ones (then reverse those faces so that the white is showing outside)
