    Dynamic Component as Parametric Design Tool
    Scheduled Pinned Locked Moved Dynamic Components
    31 Posts 10 Posters 42.1k Views 10 Watching
    • cucsat2003C Offline
      cucsat2003
      Hi mates,I'm also the one who concerns parametric design too πŸ˜„ .Thanks taekle for your very usefull tips.
      I'm new to Dynamic Component,this my very first try.
      http://i298.photobucket.com/albums/mm249/cucsat2003/DCi.jpg
      • bmikeB Offline
        bmike
        Can't say I'm doing anything as exciting as this - but for a bit I was playing with generating timbers and joinery, and also generating tools for compound roof design. Because I need to have the volume of the timber untouched (and in one component) - I'm not modeling the backing cuts or end cuts - but creating guidelines over the volume, and then using marker components to swap out for joinery, that are also dynamic. The wireframe house shape in the beginning of the video is also a dyn component - I can change plate height, pitch(es), etc. I use this when creating gable shapes, then I lock it and use it as a guide for my framing.
        This was very preliminary... and used as a proof of concept. If I ever have time I'd get back in and refine these things (or learn Ruby...)
          taekle
          Cucsat2003! You are the first and still only one who uploaded a DC parametric model except me! πŸ˜„
          Please keep posting your results.
          Shura, I feel happy that my screenshots were helpful to you.
          And the result of 'blend plugin' looks fantastic! It inspires me very much! Thanks.
          D12dozr, I hope you still keep interesting DC parametric things.
          I will post with another DC model(s) ASAP.
          Please keep concerning everybody!
          By the way, how can the workshop be done?
          http://taekle.blogspot.com
            d12dozr
            😲 That's awesome, taekle! πŸ€“
            Thanks for the detailed explanation, I'm going to go back and read it half a dozen times or so, so that it can soak in...
            http://goo.gl/f7ooYh
              taekle
              model_01 this surface shows regular pattern of wave
              Hi guys, As I said before I've come back with another 2 DC parametric models.
              They are very simple comparing with the ones I posted before.
              And I am conceiving something different in DC parametric model, I'll also introduce that here someday.
              Then enjoy DC parametric world again.
              model_01 there's specific rule in repetition of wave
              model_01 you can see repetition of wave
              model_01 close look
              screen shot_01
              As you see the formula is very simple.
              After 'loft by splines' of this set of profiles(I only drew a half circle), then copy 3X3. That's it!.
              Try this yourself.
              I'll give some explanation of the key parts(or steps) of this formula.
              1. Draw a half circle in any size along with (in this case) red axis('X' axis).
                Arc or any other profiles will be also alright. Then make component, in this case 'half_cir'
              2. Set formula to copy in X axis.('s' attribute is set for spacing between these copies.)
              3. Select these copies and make component, in this case 'set_cir_X'(parent of 'half_cir')
                and again set formula to copy in green axis('Y' axis).
              4. In LenZ of 'half_cir', type any formula you want. I like to use 'sin' and 'cos', cause they are periodic.
                In this formula you should include 'X' or 'copy' of its own and 'Y' coordinate of 'set_cir_X'(parent).
                'Y' coordinate of parent component will make sub-component changing along with 'Y' axis.
              5. In RotX of 'half_cir', type '=if(copy=odd(copy),180,0)'. This will make every two half circles upside down which then looks like wave or pulse.
              6. After complete every step then copy and move to other place, and explode every component included.
              7. Do 'loft by splines'
              Next one also has regular pattern but a little bit deformed.
              model_02 regular but deformed pattern of wave
              model_2 you can see changing in length along with X axis
              model_02 close look
              screen shot_02
              There are two differences to first one.
              In this case you should set the 'PosX' of 'half_cir' in formula.
              Then set 'LenX' accordance with PosX.
              I mean [Nth** LenX] = [(N+1)th PosX] - [Nth PosX]**.
              The formula expressed in LenX of 'half_cir' means this.(here 'copy' roles 'N')
              Little bit more complex but not that difficult.
              You can see below a set of profiles, lofted surface and result of 3X3 copy of that.(resulted in 4X4)
              Any one who feels interesting in DC parametric process please try yourself and post your own results here!
              I uploaded first one's SKU file on my blog. Visit my blog and find your way. πŸ˜„
              http://taekle.blogspot.com/2010/11/regular-but-deformed-surface-using.html
              • jeff hammondJ Offline
                nice taekle ❗ ❗
                out of curiosity, will you post a hidden line view of the waves and maybe the model stats (face count, # of edges, etc) ?
                thanks
                [edit] ha, nevermind 😳 i can get it from your blog i see.
                [edit-2] actually, i can't get if from your blog. when i click the link, i get this:
                *%(#FF0000)[Sorry, the page (or document) you have requested is not available.
                Please check the address and try again.]*
                  taekle
                  Jeff Hammond, sorry, I fixed link on my blog, please try again.
                  (In Google doc's, sometimes, this kind of link error occurs.
                  They used to say the error is related to multi-login information or something like that)
                  If you still have problem then let me know.
                  taekle.
                    taekle
                    I just visualized the movement of a simple DC parametric model.
                    Enjoy this video.
                    [flash=640,505:20olptmb]http://www.youtube.com/v/gzAISi4ZXWA?fs=1&hl=en_GB[/flash:20olptmb]
                    [flash=640,505:20olptmb]http://www.youtube.com/v/RFbvBJvA8Hk?fs=1&hl=en_GB[/flash:20olptmb]
                    • shuraS Offline
                      shura
                      Back again, and again holding my breath. I wonder if I ever get my head around DCs.
                      (did not loose interest, just moved to new appartment and waiting much too long for the internet connection 😐 )
                      That last visualization is really great, and thaks for sharing the waves pattern.
                        Completly missed this thread! Very cool examples! 😎
                        • 2 / 2
