2D Graphic Export as DWG bugsplatting.
4 Posts 1 Posters 489 Views
    Krisidious
    2D Graphic Export as DWG bugsplatting over and over... cannot get it to come out. will not export as dxf or dwg, will export other models not this one, even another model that is very similar in materials and components... 3D dwg exports fine. tried numerous settings with in the export menu, nothing affects.
    can't figure it out... any ideas?
    By: Kristoff Rand
      Krisidious
      I've exploded all the geometry, I've "purged", I've "fixed problems" don't understand it...
      By: Kristoff Rand
        Krisidious
        it has something to do with me having a section cut or something that's in the model, I turn off the section and the export works. but if I delete the section and make a slice through the model and then try the export, it fails again. I'm thinking it's some part of the model that is in the current view while the model is sectioned.
        By: Kristoff Rand
          Krisidious
          ok... it was this Faucet Component 6340_v2
          deleting it fixed the error.
          By: Kristoff Rand
