    2D Graphic Export as DWG bugsplatting.
    4 Posts 1 Posters 662 Views 1 Watching
    • KrisidiousK
      Krisidious
      2D Graphic Export as DWG bugsplatting over and over... cannot get it to come out. will not export as dxf or dwg, will export other models not this one, even another model that is very similar in materials and components... 3D dwg exports fine. tried numerous settings with in the export menu, nothing affects.
      can't figure it out... any ideas?
      By: Kristoff Rand
      • KrisidiousK
        Krisidious
        I've exploded all the geometry, I've "purged", I've "fixed problems" don't understand it...
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          it has something to do with me having a section cut or something that's in the model, I turn off the section and the export works. but if I delete the section and make a slice through the model and then try the export, it fails again. I'm thinking it's some part of the model that is in the current view while the model is sectioned.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            ok... it was this Faucet Component 6340_v2
            deleting it fixed the error.
            By: Kristoff Rand
