    [plugin]Random replacement of components
    47 Posts 13 Posters 48.1k Views 13 Watching
    • sdmitchS Offline
      sdmitch
      Pilou, Thanks again for providing the tutorial. It looks perfect!!!
      http://sdmitch.blogspot.com/
        In fact that is some redundant with the use of the Dialog box Info for rename a group of components! 😳 πŸ˜„
          Little teaser β˜€
          The 24 position Plug always by Sdmitch will be released in a few time! 😎
          • EdsonE Offline
            Edson
            @sdmitch said:
            In response to http://forums.sketchucation.com/viewtopic.php?f=323&t=37434 and others, I have written a plugin to accomplish this given two sets of components, a source set and a target set. These sets are identified by giving all the members of the set the same component name. Components also have a definition name which is what is entered when the component is created. The component name is displayed and can be assigned in the Entity Info panel. The appearence of a component is determined by the definition assigned to it by the definition name. If a sub-set of target components are pre-selected, then only those will be randomly changed.
            it would be great if the plugin's author could explain how to use it or, better still, post a tutorial showing it.
            sorry, pilou, but yours is not that clear to me.
            http://www.mahfuz.arq.br
              πŸ˜„ @Edson ("Definition Name" and "Name" are two distinc thing in a component)
              select some components with different "Definition Name" in any position
              Give the "Name" Source to these selection with the Info Dialog box
              Draw another one component: Draw copy past it anywhere you want in any position
              Select all these copies
              Give the "Name" Target to the all selection copies with the Info Dialog box
              launch the plugin Random Replacement πŸ˜„
              I can't be more clear πŸ˜„
              (the 24 positions is another plugin not yet released πŸ˜‰
              • EdsonE Offline
                Edson
                πŸ™‚ @Edson ("Definition Name" and "Name" are two distinc thing in a component)
                thanks, pilou. you are right: in writing, the explanation is very clear.
                I have been asking for a similar plugin for a long time but no one seemed willing to create one. for me it will be very useful to randomize vegetation and windows (closed, open, half this, half that, etc).
                a comment though: one does not necessarily have to name the source components source and the target ones target for the plugin to work. first I named them as you suggested and then I named them 1 and 2. the plugin worked in both situations. so, as long as there is a named source group and a named target group it works fine.
                  @Edson πŸ˜„
                  No, Source and Target are not nescessary names πŸ˜‰
                  It's just these given by default in the dialog box πŸ˜‰
                  you can put any names you want πŸ˜„ (of course these that you have yet renamed your components in the Info Box πŸ˜‰
                  But carreful it's sensitive cases !!!
                    And here the 24 positions plug of Sdmitch πŸ˜‰
                    With his autorisation! 😎
                    Pilou24Positions.rb
                      AcesHigh
                      there are many uses for this plugin.
                      for example... think of 3D tiles on a roof. Each tile is a component. But the roof gets so artificial, with all the tiles exactly the same color, no stains, etc. With this plugin, you would be able to, for example, create some 10 different roof tiles, each of them a slight different color variation, some stains, etc. And randomly replace the original components along the entire roof.
                      another possibility: a building with a glass faΓ§ade. Real such buildings will have curtains/blinds behind the windows. Make the the building with window components. The random replace them with OTHER window components, each window component with blinds in different positions (no blinds, blinds half way pulled, pulled down completely)
                      there are so many uses!!!
                        rachmatrf
                        Thhank you Sdmitch
                          Sdmitch has made a new variant with no Random integrated! β˜€
                          (see second post for more precsion of use πŸ˜‰
                          31 May 2012
                            A little tut πŸ˜‰
                            No limite of number of any components source or target! πŸ‘
                            You can name all your source components by hand but it's painfull when you have numerous!
                            So a little trick πŸ˜‰
                            Just select Components source and copy this in the ruby console
                            Sketchup.active_model.selection.each{|c| c.name='Source'}
                            Your source components are now named "Source"
                            You can make the same for Target Component πŸ˜‰
                            Sketchup.active_model.selection.each{|c| c.name='Target'}
                            Edit : In fact for the rename Source and Target you can make the just with the Entity Info Box! πŸ’š
                            You can now use the random plug πŸ˜‰ (click for zoom)
                            Of course it's infinite possibilities πŸ˜’
                            You can fill the space with no periodic infinite volumes πŸ’š
                            you can play with this speedy one πŸ˜„
                            Edit 31 May 2012
                            A new variant without random is integrated!
                            Dice2.skp
                            renameInstances.rb
                            31 May 2012
                            • soloS Offline
                              This is not working for me, Pilou can I send you a sample model by pm and you show how to do it?
                                Of course yes you can! β˜€
                                with a small file (sufficient for the concept) and a save as V7!!! πŸ˜‰
                                • soloS Offline
                                  http://dl.dropbox.com/u/1129899/test%20tree.skp
                                  Strange how the size of file increases 50% when saving as SU7 from SU 8.
                                    Sorry it's always V8 when its arriving at home !!! πŸ˜‰
                                    • soloS Offline
                                      Here is a SU 6 version
                                      http://dl.dropbox.com/u/1129899/su6.skp
                                      • JBJDesignsJ Offline
                                        JBJDesigns
                                        This is an awesome plugin... thank you both very much!!! Jo πŸ˜„
                                        ...you send them to school, you give them books, and they eat the pages...
                                          coty82
                                          This plugin is indeed great with so much potential. Do you think it could be possible to
                                          make it able to replace child components that are inside mother componennts?
                                          You could do so many patterns just by replacing components inside components.
                                          • sdmitchS Offline
                                            sdmitch
                                            coty82
                                            Please check Personal Messages.
                                            • 1 / 3
