    Update entity by webdialog/excel
    6 Posts 4 Posters 461 Views 4 Watching
      Pout
      Just a question (before creating it myself):
      Is there any plugin/script/... which updates an Entity/Component/Group when it's parameters are changed in an external 'interface' (can be a webdialog or an excell sheet)
      Basically, when you update the parameters of the object by hand (type new values in a cell or input textfield) and hit a button in Sketchup the object is adapted.
      Thx in advance!
        Parametric control?
        Dynamic Components comes close - it uses WebDialog for the UI.
          Pout
          Indeed.
          I'm looking into DC but there's not a lot of info.
          So maybe someone already developed something like this, so I can learn from it.
          On the other hand, when I have a model in which 1 DC definition has two instances and I update on of those instances:
          framing_wall_instance = Sketchup.active_model.entities[0]
          framing_wall_definition = framing_wall_instance.definition
          ad = framing_wall_definition.attribute_dictionary "dynamic_attributes"
          ad["_lenx_formula"] = '275.447'
          $dc_observers.get_latest_class.redraw_with_undo(framing_wall_instance)
          The other one does not seem to change.
          Even more when I place an new instance in the model, it shows the 'original' component, but when placing it (click) it updates and is then equal to the edited instance.
          Probably logical but I don't see why
            When you place a DC each instance is automatically made unique, so subsequently editing it won't affect the other instances.
            It IS possible to have multiple copies of DC instances [just make the copies from an instance that's already inside the SKP rather than inserting a fresh instance]: then editing one with affect all of its 'clones', but leave its [unique] siblings alone.
            If you are doing it 'in code' it is possible to give the base DC an extra 'identifying attribute' [e.g. typeCode='framing_wall'] and then your Ruby code can iterate the selection [or entities collection?] and find all DC instances that are using that matching 'identifying attribute' and processes all of them to match - thus side stepping the issue of the 'uniqueness' of the instances' definitions...
            • Dan RathbunD Offline
              Dan Rathbun
              Just from memory.. I believe that the DC extension uses special dictionaries at both the definition and instance level... ie, (example,) to keep specific scaling factors for the instance.
              I'm not here much anymore.
                Pout
                a little bit more information:
                Standard DC definition attributes (dynamic_attributes):
                Retrieve with (for the selected instance):
                xx=Sketchup.active_model.selection[0].definition.attribute_dictionaries['dynamic_attributes']
                xx.each{|key,value| puts key.to_s+'-'+value.to_s}
                Returns (app. depending on user set attributes of the selected instance-in this case LenX and LenY are 'user cannot see' and material is 'user can see'):
                _formatversion-1.0
                _has_movetool_behaviors-0.0
                _hasbehaviors-1.0
                _lastmodified-2012-02-21 10:13
                _lengthunits-CENTIMETERS
                _lenx_access-NONE
                _lenx_formlabel-LenX
                _lenx_label-LenX
                _lenx_units-DEFAULT
                _leny_access-NONE
                _leny_formlabel-LenY
                _leny_label-LenY
                _leny_units-DEFAULT
                _material_access-VIEW
                _material_formlabel-Material
                _material_label-Material
                _material_units-STRING
                _name-Huis1
                lenx-393.700787401575
                leny-393.700787401575
                material-
                When changing LenX and LenY to 'user can see':
                _formatversion-1.0
                _hasbehaviors-1.0
                _lastmodified-2012-02-21 10:15
                _lenx_access-VIEW
                _lenx_label-LenX
                _lenx_units-DEFAULT
                _leny_access-VIEW
                _leny_label-LenY
                _leny_units-DEFAULT
                _name-Huis1
                material-
                Standard instance attributes (dynamic_attributes):
                xx=Sketchup.active_model.selection[0].attribute_dictionaries['dynamic_attributes']
                _hasbehaviors-1.0
                Now if you add an attribute on definition level eg. LenX this is accessible as lenx for both the comp. definition as the instance.
                Important: to be able to access that value on instance level with _lenx_formula (eg. to change the value) the attribute must be set to at least 'users can see this attribute' . Otherwise it cannot be changed through ruby.
                If I get out more information, I'll post it here.
