    Please please help me out (2pt perspective rendering)
    extensions
    3 Posts 3 Posters 986 Views 3 Watching
      jinakira99
      Hello guys,
      I have been looking for how to render 2 point perspective view in vray SU to exactly match with skethcup viewport for a day long. However, I couldn't find out any right solution for this problem and any decent forum for me.
      So, I attached image which explains what is my goal.
      If you look at the image the A, B and C is my process to get 2 point perspective view (which is C that is my goal image for rendering). And, the 1,2 and 3 is rendered image for each sketchup viewport from A,B and C.
      As you notice, A-1, B-2 are perfectly match with each other. but problem is C. After I zoom out and moved the model from B to get right size image of 2pt perspective, I rendedred the image of C. But the rendered image still shows same with "B".
      I have tried Vray toys plugin, (which does not work). And tried rendering from long distance with high resolution and croped image that I don't like to use because it causes too many context building block my main model.
      So, please give me a little better way to get the right image for "C". My firm designs a lot of highrise building so that I should be able to render like that image.
      Appreciated in advance.
      • rodrigonotorR Offline
        rodrigonotor
        Try changing lens shift value in options->camera between 3-10
        http://www.sketchando.net/foro_imagenes/lens.jpg
        • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
          abhi4591
          thanks a lot....it works......no need to use advance camera tools. thanks...
