    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 145.8k Views 43 Watching
    • brodieB Offline
      brodie
      @zoom123 said:
      My only issues with Maxwell now is the inability to test the production engine
      The same engine used by the free version is that used by the paid version so you have unlimited access to the production engine. The main thing you're missing out on is Maxwell Studio which I believe you can test in the demo.
      and the inability of non-licensed users to post in the forums - which results in low forum activity in general ("Maxwell for Sketchup (Standalone)" section has just 3 topics).
      I don't have much of a position on this although I agree with many of Jason's sentiments. But if I were in your shoes I'd want a dedicated forum as well that I could ask questions of. That said, Jason and I would be more than happy to get you any answers to questions that come up. Jason's tested more aspects of the program and probably done more test renders than would be imaginable. And although he has an excellent training series he continues to give a plethora of free advice. I've been using Maxwell in a production setting for several years now in association with SketchUp and also try to answer any Maxwell questions I come across here.
      -Brodie
        Paul Hanusiak
        I got them to work. I ended up just starting from a new, basic model to test it out and got them working there. I couldn't get them going on the larger model until I copied into a new model and saved under a different name so it seems to have been a glitch with my file. It's all working now.
        Thanks guys. It's great to see such fast responses online.
        • Z Offline
          Zoom123
          1. Context click the group (or component) and choose Maxwell> Separate By> Material
          2. On the Output tab change the setting for "Use Instances" to "No".
          These things do not seem to apply to the Standalone version.
          I downloaded the IES example component from the Maxwell forums but I can't get the component itself to be shown lit. (but light is still coming from it). Backlight and Reflector are both set to "Yes" in the options.
          • jason_marantoJ Offline
            jason_maranto
            IES lights only show the pattern of light given by a fixture (as measured in a lab, inside a sphere) -- the sphere is not an actual light source (it is simply there to reproduce the testing environment) and therefor does not emit light (I usually hide it).
            This is why I usually say IES lights are best used "off-camera" where we can see the results but not the "fixture" itself... If you must see the fixture "on-camera" you can either physically model it and use regular emitter materials or you can fake it with a hybrid emitter/IES approach.
            Equating an IES file with a "spot light" you might find in a typical Biased renderer is a mistake -- they are not the same things at all... an IES file is supposed to be real-world data about a real-world light fixture (whereas biased spotlights are idealized CG constructs). Of course you can falsify IES data and make it anything you wish, but it defeats the purpose of why IES files were created in the first place: http://www.iesna.org/
            It is possible that those context menu options would not be in the "stand-alone" plugin since they are relevant to how the file will output into an MXS file or Maxwell Studio... and since the "stand-alone" plugin does not allow you to save as MXS file (or output to Studio) there would be little need for those options.
            Since I finished the introductory videos, I only use the full Maxwell Render Suite (since I do own a copy) and the associated plugin... so I've not kept track of any new additions to the "stand-alone" plugin since then.
            Best,
            Jason.
            • Z Offline
              Zoom123
              Thanks.
              Are there any tutorials on how to create hybrid emitter/IES luminaries or other best practices in creating luminaries that will be on-camera?
              Is it ok to physically model lamps with Maxwell, or could it result in very slow rendering?
                jason_maranto
                I've seen some good posts on the Maxwell forum about IES files in hybrid arrangements and you might want to do a search there to see what other people who work more in that field do... I'm not Arch Viz (more sci-fi/fantasy) so I tend to not worry about those types of things very often. There are many other Maxwell users on this forum who are more qualified than me to comment on this and I hope one of them chimes in here...
                As far as physically modelling light fixtures it can be done, and with amazingly realistic results, but it often does come at the costs of higher rendering time. In particular there are two areas that can increase rendering time and both are related to caustics:
                1. Overly smooth reflections -- this is simple to fix, just make the reflector material rougher... and generally this is more true to life, I've noticed people often tend to overestimate how "smooth" a surface really is.
                2. Caustics seen through dielectric(glass)/SSS materials -- this is particularly bad if the emitter is completely encased... unfortunately this is a known issue with Unbiased rendering in general and if anybody manages to solve it using truly unbiased techniques it will be big news.
                Best,
                Jason.
                • Z Offline
                  Zoom123
                  Thanks. Apart from the "Tutorials / FAQ" section should I be looking anywhere else? I found some info but is not exactly what I was looking for, I will search more.
                    jason_maranto
                    The WIP/Gallery sections tend to have the most information after the regular Maxwell Render V2 subforum... Tutorials/FAQ section will not have much of value as it's mostly older stuff.
                    Best,
                    Jason.
                    • utilerU Offline
                      utiler
                      OK, I'm getting a little better at this but have some Q's.
                      n settings you can set the number of threads MW uses... In one of the tutorial videos say that you can hit the 'dot' and say reset and it will work out how many is sufficient.
                      What happens if mine says 0? Does it mean I have no cores at all in my system??? 😎
                      Here's a job I'm doing at the moment. 3 storey specialist Medical suites. I've chosen to export them at 1024pix as they are for a website so I didn't think they needed to me any bigger. Sample level 14 with a little opacity applied to trees and peeps.
                      Just Curious...
                      • Z Offline
                        Zoom123
                        The default is 0 and it means that it uses all cores/threads available. If you are using Windows you can open the Task Manager > Performance and there CPU usage should be close to 100% for all threads.
                        • utilerU Offline
                          utiler
                          Thanks Zoom, but why is there an option if it just defaults to your system's performance?
                          Just Curious...
                            jason_maranto
                            Because you can set it for less than the maximum to allow other programs to use those remaining resources more efficiently... setting it for 0 is adaptive and that is where I leave it most of the time.
                            BTW, you are getting some strong vignetting in your render due to the small focal length of the camera -- In the future, if you do not want the vignetting there you can easily remove it by enabling the de-vignetting option (under Simulens) and moving the slider to to 100%.
                            Best,
                            Jason.
                            • utilerU Offline
                              utiler
                              Thanks for your advice, Jason. I'll give it a try tomorrow. πŸ‘
                              Just Curious...
                              • irwanwrI Offline
                                irwanwr
                                πŸ‘
                                Andrew, that model was rendered with "FREE" Maxwell Render for SketchUp!?
                                • utilerU Offline
                                  utiler
                                  No Irwan, I bought the license but still the output res is only 1024pix...
                                  I'm really enjoying how easy it is to drive!!
                                  Just Curious...
                                  • Z Offline
                                    Zoom123
                                    Hello, I am still a bit confused on the differences between the Draft and the Production engine. In their website they say "Maxwell Render is unbiased: for any given scene, both the draft and production engine will eventually produce the identical image" but from some of the responses here I got the impression that for more complex lighting you need the Production engine. So now I don't know what to expect from the Production engine. Would it produce an even better result or would it produce the same result but faster?
                                    Or maybe that "eventually" is only theoretical, and for complex scenes the draft engine could take many days to produce a result that the Production engine can do within a few hours? (i.e. you will practically never wait for the Draft engine to finish)
                                      jason_maranto
                                      Pretty much -- in the Unbiased world "eventually" really means "longer than you want to wait"... it's a promise that remains unfulfilled because you wont test it. Much like if you keep walking in a straight line you will eventually end up back where you started (by circling the earth) -- nobody will ever actually put this to the test so it remains a widely accepted truth that nobody actually sees.
                                      The optimization of the FIRE engine (the draft engine here) is such that it will give reasonably fast results for scenes with simple light interactions... with the primary focus on speed of feedback while making changes -- this is useful while you are setting camera, materials and environment settings.
                                      Interior shots are generally anything but simple... relatively low light-levels and lots of emitters, combined with lots of bounces and complex materials/surfaces.
                                      The production engine (this is the real full-power Maxwell engine) is optimized to actually render to Maxwells full potential -- it's not concerned about giving you fast feedback while you are working, it's there only to give finished results.
                                      Both engines are necessary in a complete workflow, but given the option you would never choose the draft engine for final work... and the circumstances where it might be suitable as such would be mostly limited to Arch Viz scenes lit by physical sky or IBL and product shots lit by IBL.
                                      With alot of skill and patience you can pull it off -- but it will take longer and will definitely be noisier than is necessary.
                                      Think of it like the difference between SketchUp free and Pro -- yes you can create presentations without the tools in Layout (part of the Pro version), but it is cumbersome and more problematic than it needs to be and will likely not look as good... not to mention that you will likely have to have some other expensive software (Illustrator/In Design) to complete the project anyway.
                                      People use SketchUp free for many things but its designed purpose at this point is primarily Google Earth modelling -- the fact that it can do considerably more is mostly a testament to the community of Ruby plugin authors we have here.
                                      Best,
                                      Jason.
                                      • andybotA Offline
                                        andybot
                                        If you recall this thread you will see that for a reasonable scene, the difference between draft and production is incremental, not night and day. My impression was that it gets a slightly better result a little faster - maybe 10-20% (My subjective impression) If you give it a torture test scene, like one small daylit opening and complex emitters, sure, you may see a big difference, but I think it more has to do with how well you set up the lighting situation. It all depends on the kind of scene you are trying to render...
                                          jason_maranto
                                          As I said -- Arch Viz lit only by Physical Sky or IBL will work (more or less). However start adding emitters and more complex materials/models and things become difficult for the draft engine to resolve very quickly.
                                          Your scene setup was pretty basic for Maxwell therefor the difference between engines is minimal (as you say).
                                          This falls under knowing the limitations of the tool and working within them.
                                          There is also an issue with uneven power of emitters -- basically the idea is that the sun is a much more powerful source of light than the emitter materials... when you put both light sources in the same scene the emitters often look "grainy" due to the uneven power ratio (Maxwell prioritizes powerful emitters).
                                          Best,
                                          Jason.
                                          • Z Offline
                                            Zoom123
                                            Thanks, now that difference is clear!
                                            Another question:
                                            I've been looking at arroway textures (ex: http://www.arroway-textures.com/en/products/concrete-1/contents ) and I noticed they provide several different kinds of maps (diffuse, bump, specularity etc). How would I apply those textures with Maxwell for SU?
                                            I understand how to add the diffuse and bump maps, but where would I add the specularity / glossiness map?
                                            Also there are some textures where a bump map is provided and in addition they give a value for displacement. How can I do that?
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
