    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 145.8k Views 43 Watching
    • jason_marantoJ Offline
      jason_maranto
      Actually the benefit I see immediately for users of both versions is increased utility of Maxwell within SketchUp -- in the past is was easy to overlook a lack of certain features within the plugin because there was always MXED and Studio to create workarounds... but now those "missing" features become obvious and that should lead to a more robust in-SketchUp Maxwell experience for all users.
      I truly hope the free version becomes a monster hit -- all those new users will help drive exciting new changes to the plugin and Maxwell overall that we can't even fathom yet.
      Best,
      Jason.
      • utilerU Offline
        utiler
        I have just purchased this to give it a run but there doesn't seem to be much help on the Maxwell site to help installing....
        Any help here?
        Cheers,
        Just Curious...
          jason_maranto
          In the zip file there is a text file which has the specific instructions -- but in short, it installs just like any other Ruby plugin for SketchUp (drop it into the plugins folder).
          Best,
          Jason.
          • utilerU Offline
            utiler
            Thanks Jason.... πŸ‘
            Just Curious...
              jason_maranto
              Here's a link to an interview with the people behind the new plugin:
              404 Not Found
              (www.sketchupartists.org)
              and also there is a new 30% off promo for Maxwell Render Suite starting today (there's a special code to use) -- details here:
              https://plus.google.com/u/0/106165332069081872570
              Best,
              Jason.
                Paul Hanusiak
                I can't get the emitters for the Maxwell Render plug-in to work in SketchUp 8 Pro. I am running the licensed version (the $95 one) not the full suite. I've read through the manuals and a couple of forums and I've tried all the typical fixes such as reversing the faces etc. The scene is all black. Any ideas?
                I'm running an Mac G5 Pro, with dual quad core Xeon processors, 8gig RAM and OSX 10.6.8 if that makes any difference but I don't think it's a hardware issue, more likely a software thing. Could it be a Silverlight issue? I can't seem to find what version of silverlight Maxwell installed.
                  jason_maranto
                  Silverlight is just for the UI, it should not have much to do with the rendering itself which is Maxwell -- but Silverlight 4 is the recommended version.
                  Have you tried the newest version of the plugin (2.6.10 which has some fixes for emitter issues)?
                  Also some things to try:
                  1. Context click the group (or component) and choose Maxwell> Separate By> Material
                  2. On the Output tab change the setting for "Use Instances" to "No".
                  3. Make sure there are no other materials applied to the geometry (backface or edges) which may potentially confuse the engine.
                  Best,
                  Jason.
                  • utilerU Offline
                    utiler
                    Not sure what I'm doing wrong with the glass settings but when rendered it previews very dark. Is it a sun setting or am I doing something other incorrectly?
                    Cheers,
                    πŸ‘
                    Just Curious...
                      jason_maranto
                      Using "real" glass has some issues and is not recommended for general Arch Viz. They created a solution made particularly for windows called AGS (Architectural Glass Solution)... you will find it listed under the character types.
                      Alternately, you can simply use the default character type and reduce the opacity of your SketchUp material and the plugin will automatically convert it to AGS (this would be my preferred method).
                      If you still want to use "real" glass be aware that the panes of glass must be "closed volumes" (SketchUp Solids) and have all the dimensions and details (including thickness) of the real-world window panes... this is also true of any other dielectric (water, gemstones, etc.) and any object that has regular SSS applied (thinSSS materials do not have this issue).
                      Best,
                      Jason.
                      • Z Offline
                        Zoom123
                        Jason,
                        Since members without a license can not use the Maxwell forum, where can I ask questions and get answers about Maxwell for SU? I couldn't find some contact email address for non licensed users.
                        Since now there is a free version of Maxwell wouldn't it be appropriate to have at least one section of your forum open for the users of the free version (who are also potential clients for the paid version)? I could use Skethucation, but it would seem more appropriate to ask Maxwell specific question in a Maxwell forum.
                          jason_maranto
                          I don't have any control over those things -- I don't work for Next Limit, I'm just a regular user (albeit very enthusiastic).
                          There are actually quite alot of very knowledgeable users here on this forum -- I may be the most consistently vocal about Maxwell but that is only because I support the videos I made for the plugin. I like to know where people are having issues because it helps me to better understand where I can improve the next time I do a tutorial.
                          Also one of the top SketchUcators on this forum (Brodie) is a multi-contest winning user of Maxwell and is an excellent resource not only of SketchUp advice but Maxwell advice as well... but there are many other (perhaps) less vocal Maxwell users here who can help if need be.
                          We are not "official" support and don't pretend to be, but for alot of problems users might encounter we should suffice.
                          To be clear though, I agree with Next Limits policy on this -- I do not care to allow non-paying users to take precedent over paying users in any way... and I think it would be unfair (to paying users) to give the same rights to non-paying users. As it is there is a fairly large gap in the $900 I paid for Maxwell and the $95 licensed users of the stand alone plugin paid -- as far as I'm concerned we are already treading that fine line where other users of the full Maxwell Render Suite (especially those antagonistic to SketchUp) are likely to begin resenting some aspects of this new option.
                          I also feel the same about SketchUp Pro -- I do (and have for some time) resent that as a paying user there is not a "licensed-user only" forum hosted by Google... I feel that paying users should have more direct access to (and priority from) the dev team for feature requests and bug reports. It's one of the factors that makes me seriously wonder whether I should continue to financially support the software (SketchUp Pro).
                          I would rather give my money to a company that understands the value of a paying customer.
                          Best,
                          Jason.
                          • Z Offline
                            Zoom123
                            I appreciate the help that other users can offer here but I continue to believe that a section in the Maxwell forums would be appropriate. Maxwell could explicitly state that there will be no official support in this section so it really wouldn't cost them anything.
                            I am sure that if paying clients of Maxwell don't mind that a free version of Maxwell was made available they will not mind a sub-section in the forum. Non paying users can be restricted to that section only (something which is very easy to do with forum software).
                            I continue to compare Twilight Render and Maxwell for SU and I think they are both great. Since I upgraded my PC (i7 2600K overclocked to 4.5GHz) I don't have any speed issues with Maxwell anymore. And now they added IES lights my other major concern was eliminated. My only issues with Maxwell now is the inability to test the production engine and the inability of non-licensed users to post in the forums - which results in low forum activity in general ("Maxwell for Sketchup (Standalone)" section has just 3 topics). In comparison Twilight Render has a ton of great info in their forums. A lot of the content is available to all, while they also have a section for licensed users. I think this is a better approach.
                              jason_maranto
                              I think you may be slightly confused -- the Maxwell forums content is available to all to read as well, and there is absolutely tons of info there (just not in the new section for the stand-alone plugin)... all for free and for anybody to read.
                              I myself have posted several thousand free materials for Maxwell that any user can use and made many hours of free tutorials that anybody can watch -- I'm not sure what else you might need for free.
                              The only thing left is support (bug reports and feature requests).
                              My feeling is if you use a free software you get what you pay for (as far as support) -- which means none.
                              However I should reiterate that my opinion means nothing since I am just another user... Next Limit will make those decisions as they see fit.
                              Best,
                              Jason.
                                bravoddb
                                Best,
                                Jason.
                                I Had the same problem, i found that I have to make the emitters group, and the they worked,
                                Jason
                                Where can i download the newest version?, I'm a licensed user
                                Bravoddb
                                  jason_maranto
                                  Yes, it is always best to use modeling techniques that will render problem free -- definitely some of the normal shortcuts of modeling in SketchUp do not work out so great when rendering in Maxwell.
                                  You can download by:
                                  1. go to http://www.maxwellrender.com/
                                  2. click the "log in" link in the upper right hand corner.
                                  3. once you've logged in you can navigate to the download area
                                  4. the first link in the download area is for Windows users and the second is Mac.
                                  Whenever a new version is officially released this will be where you can get it... however if you keep an eye on the Maxwell forum he (JD) often posts pre-release "open Beta" versions of the plugins.
                                  Best,
                                  Jason.
                                  • Z Offline
                                    Zoom123
                                    I am referring to tutorials and info specifically for the standalone sketchup plugin. I know about your 8 video tutorials but I couldn't find much else.
                                    • BurkhardB Offline
                                      Burkhard
                                      Try the VTC online Videos from Jason http://www.vtc.com
                                      http://www.ia-plus.de
                                        jason_maranto
                                        You won't find anything specifically besides those because:
                                        A) It's too new still
                                        and
                                        B) The stand alone plugin is simply a subset of Maxwell -- nothing applies to the "stand-alone" plugin that does not also apply to the normal Maxwell plugin (and Maxwell in general)therefor it's rather pointless to do 2 (or more) sets of videos for essentially the same product.
                                        Also I would not be waiting for tutorials that are SketchUp specific when it comes to Maxwell because it is its own thing -- it is far better to read the online information (and watch the videos) for the main render engine... this is where the good information is anyway, and it applies to all the plugin equally.
                                        Best,
                                        Jason.
                                        • utilerU Offline
                                          utiler
                                          Thanks Jason, that is what I do for glass in SU but I thought I would have to set reflectivity settings, etc..
                                          Just Curious...
                                          • brodieB Offline
                                            brodie
                                            The same engine used by the free version is that used by the paid version so you have unlimited access to the production engine. The main thing you're missing out on is Maxwell Studio which I believe you can test in the demo.
                                            I don't have much of a position on this although I agree with many of Jason's sentiments. But if I were in your shoes I'd want a dedicated forum as well that I could ask questions of. That said, Jason and I would be more than happy to get you any answers to questions that come up. Jason's tested more aspects of the program and probably done more test renders than would be imaginable. And although he has an excellent training series he continues to give a plethora of free advice. I've been using Maxwell in a production setting for several years now in association with SketchUp and also try to answer any Maxwell questions I come across here.
                                            -Brodie
                                            • 12
                                            • 13
                                            • 7 / 13
