    Hidden geometry head scratcher
    26 Posts 5 Posters 1.9k Views 5 Watching
    • boofredlayB
      boofredlay
      Pete, the import of symbols from the warehouse could have caused some problems as well. I never trust any other model than ones I create myself. But if you have to import those details make sure you have all layers on and hidden lines on to see any problems right away.
      To the problem at hand I think you are running into z-fighting with so many surfaces on the same plane. I would suggest drawing your walls as a component. Then draw your roof as a separate component and so on. Eventually you can combine them if you want but keeping as many elements separate will help you in the long run.
      Also, when filling in a surface, if there are too many intersect points around the perimeter SU will not fill it in which is why you are having to create many triangles before getting the full area to fill in.
      My 2 cents.
      • boofredlayB
        boofredlay
        Also, you have many elements that are not co-planar. The attached image - set of dashed lines for example are not on the same plane. The dashes are lower than the rest of the roof and walls.
        Note that small lines in SU will wreak havoc in a heart beat.
        Another suggestion would be to create a large plane then draw your lines on it. Having a surface to draw your 2d lines on will help prevent snapping to some arbitrary point.
        • P
          PETE838
          Great info. Thank you.
          Is there a way to "lock" all of your drawing into the Z plane? Or move your points in the Z (or x or y, for that matter) plane? I know in ACAD you can draw the line, then alter its start and end point coordinates in XYZ, or just draw it by entering the coordinates. Or maybe an add-in to flatten everything into the same plane?
            mics_54
            I think that is what drawing your sheet plane would effectively be doing. Each time you ad a line or other element you will get "On Surface" indication.
              mics_54
              Boofredlay as an aside...if one is using 2D tools is it advised to mix in the standard textures rather than the 2D hatches?
              • boofredlayB
                boofredlay
                Pete, I don't know of a way to lock your drawing tools to a z plane. One way to be more sure you are drawing on a single plane is to do it in perspective mode and continually rotate around your drawing. I don't use SU for 2d much so someone else might weigh in with a better solution.
                As far as flattening your geometry when it goes South, you could use TIG's Flatten to Plane plugin:
                http://forums.sketchucation.com/viewtopic.php?p=281320#p281320
                Michael, I am not sure I understand your question.
                  mics_54
                  I think that probably answers my question. πŸ˜†
                  • boofredlayB
                    boofredlay
                    Glad I could help πŸ˜„
                    • boofredlayB
                      boofredlay
                      Pete, I had a bit of time at lunch so I did a quick video of how I would go about a 2d plan like you are showing. Hope this helps.
                      Draw a plane, group it, use it as a canvas, delete it then finish up your plan.
                      [flash=853,505:32x4el71]http://www.youtube.com/v/Pmc-hJzqhl0&fs=1[/flash:32x4el71]
                        mics_54
                        πŸ‘
                        but one question...how did you do the line extensions when doing the intersections for the hips and valleys?
                        I dont get the inference.
                        • boofredlayB
                          boofredlay
                          Start your line, hover over the existing line then hold down shift. This will extend the line allowing you to reference another point on the drawing. Or start your line, move it along an axis and hold shift, again it will continue along that same path allowing you to reference another point.
                            mics_54
                            dang it i knew that!
                            • boofredlayB
                              boofredlay
                              There is a more detailed explpaination on the GSU videos.
                              http://sketchup.google.com/intl/en/training/videos.html
                              Under "Familiar with Google SketchUp" then "Google SketchUp Techniques: Inference Locking"
                                mics_54
                                The screen capture video worked so flawlessly..what software is that?
                                • boofredlayB
                                  boofredlay
                                  I use Hypercam2
                                  http://www.hyperionics.com/hc/
                                  Make sure you change the keyboard shortcuts (Hot Keys) because they can interfere with your SU ones and mess up your video. I found that out the hard way.
                                  After taking the video I used Windows Live Movie Maker to add text and edit it. Then uploaded to Youtube.
                                  Both Hypercam and WLMM are free.
                                    mics_54
                                    you rock πŸ‘
                                    • P
                                      PETE838
                                      That was astounding how quickly you did that. The same workflow for me takes 20 minutes. Thanks a million.
                                      • boofredlayB
                                        boofredlay
                                        Thanks Michael
                                        Thanks Pete. Practice practice practice.
