    Untitled Capital Ship WIP
    24 Posts 6 Posters 3.8k Views 6 Watching
      aaronfeld
      Yeah thats a lot by SU standards. What I normally do is group the similar thing together. My first one I almost always do is Deco. I throw everything that isn't needed and is just to make things look nice into that. It's sorta hard to explain but you can "layer" everything into the layers (sorry if I just confused you). I mean that you can make the outside one group and then within that group have the interior. You could then make a layer that hides only the exterior. This way when you move the exterior the inside will come with you. I'm pretty sure that wasn't the best way to explain it but... Layers are just a fast way to hide stuff and it still comes with the computational benefits of just running a normal hide command.
        jedicharles
        Okay, I understand what you mean, it's what I thought but I didn't want to assume. I do have a pretty fast CPU and 12GB of RAM so maybe that's why it is only beginning to slow down. I do have a lot of geometry that isn't shown that could be removed. Every component and group are solid shapes so I guess removing the back sides of the objects that are not seen could help. I'll have to test it out to see if there is any benefit.
        http://sketchup3dchallenge.blogspot.com/
          aaronfeld
          Removing the back faces could help but it may not be the most efficient use of your time. Layers are the way to go however, the benefits are far greater then going around deleting back faces. Thats not to say that you shouldn't do it, just pick the right thing to spend your time on. Oh and 12gb of RAM is absurd so you should be fine.
            jedicharles
            Thanks.
              jedicharles
              I worked on the Docking Rings and the Landing Struts and decided to try the free version of Maxwell for SketchUp. I might just buy the paid version. Keep in mind I'm new to rendering. Check it out:
              https://lh3.googleusercontent.com/-85oxkJWPB3E/TvPcaBtf7-I/AAAAAAAAERo/U9JhIwQxEZA/s800/Maxwell%252520Test.jpg
              https://lh3.googleusercontent.com/-d6P2UpjKAmM/TvPgZ9cA_4I/AAAAAAAAESU/0Apu2bMmJG4/s800/Maxwell%252520Test%2525202.jpg
              https://lh3.googleusercontent.com/-nswzCH5cJOg/TvPgaBVDfPI/AAAAAAAAESU/XLOOs8uqTQ8/s800/Maxwell%252520Test%2525203.jpg
              https://lh3.googleusercontent.com/-IOFw5k_hFAU/TvPgZFzbsoI/AAAAAAAAESU/RWiOVgueL1M/s800/Maxwell%252520Test%2525204.jpg
              • jason_marantoJ Offline
                jason_maranto
                Cool stuff, if you want to get a space look you can try an Image Based Lighting environment using a star HDR or EXR image -- or for a quick and dirty approach I like to use a Sky Dome Environment set to nearly black (for horizon and zenith) and enable the sun... this will mimic space in direct sunlight (which is pretty harsh).
                I've used a star HDR for this project:
                http://forums.sketchucation.com/viewtopic.php?p=304138
                Which I got from here (it's not the greatest, but it is free):
                http://www.hdrlabs.com/sibl/archive.html
                However if you are looking for more variety to choose from you could buy this:
                http://www.doschdesign.com/products/hdri/Space.html
                Maxwell uses the "Spherical Map (Latitude-Longitude)" format, so make sure any HDR/EXR images you use are in that format.
                Best,
                Jason.
                  jason_maranto
                  You might also find this Substance to be useful:
                  turbosquid.com
                  (www.turbosquid.com)
                  It can generate thousands of variations of a spaceship hull very quickly to get exactly the look you want.
                  To use it you will need to download the free player here:
                  http://www.allegorithmic.com/products/player
                  This will allow you to create and output any variations you may want for use in SketchUp or Maxwell (or both).
                  Best,
                  Jason.
                    jedicharles
                    Thanks for the information Jason, that will help me a lot.
                      jedicharles
                      Here is the first weapon for the ship. It is a heavy turbolassr cannon based on the ones from a Venator-class Star Destroyer. 🤓 I might scale up the size of the barrels a bit. It is going to be manned by a trooper.
                      https://lh6.googleusercontent.com/-0vmYzJSZ5Qo/TwUCud9PYsI/AAAAAAAAEU4/XzmaFIiVWGI/s640/Untitled%252520Capital%252520Ship%252520WIP16.jpg
                        jedicharles
                        Bigger Barrels, Better!
                        https://lh4.googleusercontent.com/-hFpsEfqMwAA/TyswuWiHnyI/AAAAAAAAEiU/JYbQbVY3wq4/s800/Untitled%2520Capital%2520Ship%2520WIP17.jpg
                        • DanielD Offline
                          Daniel
                          Careful, Charles. According to a well-known little green Jedi master, one shouldn't judge by size! The model is looking good.
                          My avatar is an anachronism.
                            jedicharles
                            [attachment=0:9wbxos1v]<!-- ia0 -->Rebellion for dummies.gif<!-- ia0 -->[/attachment:9wbxos1v]
                            Correct, you are, correct, you are! But, the gun did look silly considering, the main weapon for a 280 meter ship, is it. Yes, hmmm.
                              jedicharles
                              I decided to change the engine layout and the way they are mounted to the ship to make it more consistent with Star Wars style ships.
                              https://lh3.googleusercontent.com/-uI4_pNyQqNU/TyyT9FO-0dI/AAAAAAAAEjM/HRcamYOnr7E/s800/Untitled-Capital-Ship-WIP18.jpg
                              https://lh4.googleusercontent.com/-wblaKBrHfUE/TyyT9jjZLgI/AAAAAAAAEjM/NJNgjfa4U2Y/s800/Untitled-Capital-Ship-WIP19.jpg
                              https://lh5.googleusercontent.com/-BhRFPISzb4A/TyyT8M5AKWI/AAAAAAAAEjM/glb5gnVI0No/s800/Untitled-Capital-Ship-WIP20.jpg
                              • RoidsanR Offline
                                Roidsan
                                Young Mr. Jedi,
                                Do I have this right? The change in engines is to put them on a level position and make them both the same size (they looked different in size to me on the original configuration)? Just curious if I understand you.
                                Another small question – if I come straight down on the turbolazer cannon will it be able to elevate to meet my attack? It looks like about a 10% blank spot in the barrel elevation angle. Wouldn’t want you discover that AFTER launch. 😳
                                It is good to note (Daniel) that in this case big means “bigger projectile, or beam or whatever” which I would prefer in armed conflict, not having the mental powers of the Yoda. Side note: I’m making different titles for my Dummies Manual to put on and sit around where people can see me. Toooo… funny. 🤣
                                The ship looks better, and more formidable. all the time
                                Lloyd 👍 👍 👍
                                Thinking about ship weaponry, have you ever read David Weber's Honor Harrington series? Possibly the most unbelievable deep space fleet battles in Science Fiction. I will never forget the unfortunate and awesome destructive power of "bomb pumped lasers", yeow!
                                Everything's alright now, the photographer's here.
                                  jedicharles
                                  Yes, I decided they should be level with each other. The reason for the change is to make the "wings" flat because the old ones looked too Romulan and I though I also like Star Trek, that's not what I am going for. I also wanted a trench on the leading edge that would match the rest of the ship. Before, the two innermost engines had an additional segment which made them 20 feet longer than the other two. I decided to make theme all the same now because the ship doesn't need to be so long.
                                  Good point... I'll fix it. 🤓
                                  I haven't heard of that but sounds cool. I have a lot of Star Wars audiobooks but they seem to deal mostly with planet side battles.
                                    jedicharles
                                    Now it can fire straight up. The gunner will love that...
                                    https://lh3.googleusercontent.com/-u3xmIodNOo4/Ty3gedm0AWI/AAAAAAAAEjk/TyV3tdfOZ9M/s800/Untitled-Capital-Ship-WIP21.jpg
