    Untitled Capital Ship WIP
    24 Posts 6 Posters 5.0k Views 6 Watching
    • KrisidiousK
      Krisidious
      awesome... the Force is strong with this one...
      By: Kristoff Rand
        jedicharles
        Thanks, that's the plan. Live long and prosper... I mean, use the Schwartz, Lone Star! Wrong again...
        http://sketchup3dchallenge.blogspot.com/
        • RoidsanR
          Roidsan
          Charles,
          It is such a kick to be gone from the forums for a couple of months and come back and find something so great like your ship. ๐Ÿ˜ It is wonderful for sooooo many reasons...the complexity is so exciting, the anticipation for the detail you will accomplish is intense, and the joy, I am LOL, because it is so great that someone has the time and the deep inspiration and appreciation of a sci fi story to do that model. Hurray!! and I look forward to more posts of progress. Oh... and your blog is also great. It is such a pleasure to be able to follow the development of projects like yours.
          You go guy!!!!
          Lloyd
          Everything's alright now, the photographer's here.
            aaronfeld
            That's pretty awesome! The blog showed the interior but can we get some close ups here? Seeing your skill I would assume you know but if you have everything in groups/components you can and should put stuff in layers. It'll help you keep your frame rate up and make it easier to model. I have a model with over 274000 polys and with everything properly layered I run like I was modeling with only a few thousand. Nice job!
              aaronfeld
                jedicharles
                @roidsan said:
                Charles,
                You go guy!!!!
                Lloyd
                Thank you Lloyd, I better get to work on it then!
                  jedicharles
                  Most of the interior is still set to default material but this will give you an idea of what it looks like. You will noticed that everything is aligned to a grid of 4'x4' squares 6 inches apart. I did this to make the ship completely modular in the interior.
                  Entry:
                  https://lh4.googleusercontent.com/-GgGy3HMNkxg/TsW4cr9kpmI/AAAAAAAAD68/hHwukwQos20/s640/Untitled%252520Capital%252520Ship%252520WIP9.jpg
                  Corner Detail:
                  https://lh6.googleusercontent.com/-A7nnjffhje0/TsW4afjH5bI/AAAAAAAAD60/pg6NjtUuEy8/s640/Untitled%252520Capital%252520Ship%252520WIP10.jpg
                  Landing Bay/Hangar:
                  https://lh6.googleusercontent.com/-A0Z6ZGbyq-g/TsW4gG70cWI/AAAAAAAAD7E/7ZYkOtFg7b4/s640/Untitled%252520Capital%252520Ship%252520WIP11.jpg
                  Bulkhead Section Doors:
                  https://lh4.googleusercontent.com/-GgL2lKF0uDs/TsW4jqFI51I/AAAAAAAAD7M/Tiyz7szGeRM/s640/Untitled%252520Capital%252520Ship%252520WIP12.jpg
                  Corridor:
                  https://lh3.googleusercontent.com/-B07ygvDzAJs/TsW4kaSoSRI/AAAAAAAAD7U/GWFweJvuVhI/s640/Untitled%252520Capital%252520Ship%252520WIP13.jpg
                  Yep, everything is component-ized but not in layers. Now when you say put stuff in layers, do you do it so only the part of model you are currently working on is active? I always have the rest of the model hidden when working on components, is that not enough? I have 1,084,145 faces, is that a lot? ๐Ÿ˜ฎ
                    aaronfeld
                    Yeah thats a lot by SU standards. What I normally do is group the similar thing together. My first one I almost always do is Deco. I throw everything that isn't needed and is just to make things look nice into that. It's sorta hard to explain but you can "layer" everything into the layers (sorry if I just confused you). I mean that you can make the outside one group and then within that group have the interior. You could then make a layer that hides only the exterior. This way when you move the exterior the inside will come with you. I'm pretty sure that wasn't the best way to explain it but... Layers are just a fast way to hide stuff and it still comes with the computational benefits of just running a normal hide command.
                      jedicharles
                      Okay, I understand what you mean, it's what I thought but I didn't want to assume. I do have a pretty fast CPU and 12GB of RAM so maybe that's why it is only beginning to slow down. I do have a lot of geometry that isn't shown that could be removed. Every component and group are solid shapes so I guess removing the back sides of the objects that are not seen could help. I'll have to test it out to see if there is any benefit.
                        aaronfeld
                        Removing the back faces could help but it may not be the most efficient use of your time. Layers are the way to go however, the benefits are far greater then going around deleting back faces. Thats not to say that you shouldn't do it, just pick the right thing to spend your time on. Oh and 12gb of RAM is absurd so you should be fine.
                          jedicharles
                          Thanks.
                            jedicharles
                            I worked on the Docking Rings and the Landing Struts and decided to try the free version of Maxwell for SketchUp. I might just buy the paid version. Keep in mind I'm new to rendering. Check it out:
                            https://lh3.googleusercontent.com/-85oxkJWPB3E/TvPcaBtf7-I/AAAAAAAAERo/U9JhIwQxEZA/s800/Maxwell%252520Test.jpg
                            https://lh3.googleusercontent.com/-d6P2UpjKAmM/TvPgZ9cA_4I/AAAAAAAAESU/0Apu2bMmJG4/s800/Maxwell%252520Test%2525202.jpg
                            https://lh3.googleusercontent.com/-nswzCH5cJOg/TvPgaBVDfPI/AAAAAAAAESU/XLOOs8uqTQ8/s800/Maxwell%252520Test%2525203.jpg
                            https://lh3.googleusercontent.com/-IOFw5k_hFAU/TvPgZFzbsoI/AAAAAAAAESU/RWiOVgueL1M/s800/Maxwell%252520Test%2525204.jpg
                            • jason_marantoJ
                              jason_maranto
                              Cool stuff, if you want to get a space look you can try an Image Based Lighting environment using a star HDR or EXR image -- or for a quick and dirty approach I like to use a Sky Dome Environment set to nearly black (for horizon and zenith) and enable the sun... this will mimic space in direct sunlight (which is pretty harsh).
                              I've used a star HDR for this project:
                              http://forums.sketchucation.com/viewtopic.php?p=304138
                              Which I got from here (it's not the greatest, but it is free):
                              http://www.hdrlabs.com/sibl/archive.html
                              However if you are looking for more variety to choose from you could buy this:
                              http://www.doschdesign.com/products/hdri/Space.html
                              Maxwell uses the "Spherical Map (Latitude-Longitude)" format, so make sure any HDR/EXR images you use are in that format.
                              Best,
                              Jason.
                              • jason_marantoJ
                                jason_maranto
                                You might also find this Substance to be useful:
                                ERROR: The request could not be satisfied
                                (www.turbosquid.com)
                                It can generate thousands of variations of a spaceship hull very quickly to get exactly the look you want.
                                To use it you will need to download the free player here:
                                http://www.allegorithmic.com/products/player
                                This will allow you to create and output any variations you may want for use in SketchUp or Maxwell (or both).
                                Best,
                                Jason.
                                  jedicharles
                                  Thanks for the information Jason, that will help me a lot.
                                    jedicharles
                                    Here is the first weapon for the ship. It is a heavy turbolassr cannon based on the ones from a Venator-class Star Destroyer. ๐Ÿค“ I might scale up the size of the barrels a bit. It is going to be manned by a trooper.
                                    https://lh6.googleusercontent.com/-0vmYzJSZ5Qo/TwUCud9PYsI/AAAAAAAAEU4/XzmaFIiVWGI/s640/Untitled%252520Capital%252520Ship%252520WIP16.jpg
                                      jedicharles
                                      Bigger Barrels, Better!
                                      https://lh4.googleusercontent.com/-hFpsEfqMwAA/TyswuWiHnyI/AAAAAAAAEiU/JYbQbVY3wq4/s800/Untitled%2520Capital%2520Ship%2520WIP17.jpg
                                      • DanielD
                                        Daniel
                                        Careful, Charles. According to a well-known little green Jedi master, one shouldn't judge by size! The model is looking good.
                                        My avatar is an anachronism.
                                          jedicharles
                                          [attachment=0:9wbxos1v]<!-- ia0 -->Rebellion for dummies.gif<!-- ia0 -->[/attachment:9wbxos1v]
                                          Correct, you are, correct, you are! But, the gun did look silly considering, the main weapon for a 280 meter ship, is it. Yes, hmmm.
                                            jedicharles
                                            I decided to change the engine layout and the way they are mounted to the ship to make it more consistent with Star Wars style ships.
                                            https://lh3.googleusercontent.com/-uI4_pNyQqNU/TyyT9FO-0dI/AAAAAAAAEjM/HRcamYOnr7E/s800/Untitled-Capital-Ship-WIP18.jpg
                                            https://lh4.googleusercontent.com/-wblaKBrHfUE/TyyT9jjZLgI/AAAAAAAAEjM/NJNgjfa4U2Y/s800/Untitled-Capital-Ship-WIP19.jpg
                                            https://lh5.googleusercontent.com/-BhRFPISzb4A/TyyT8M5AKWI/AAAAAAAAEjM/glb5gnVI0No/s800/Untitled-Capital-Ship-WIP20.jpg
