    Add_group slow on mac
    48 Posts 7 Posters 21.6k Views 7 Watching
    • G
      GWD
      @dan rathbun said:
      For version 8.0M2,
      (http://support.google.com/sketchup/bin/static.py?hl)":100134bg]SketchUp Writer C++ API: In earlier versions, ISketchUpGroup::CreateGroup became slower each time it was called. This shouldn't slow down any longer.
      I would think that this fix was added into the application code as well.
      @Guy: Is your friend's Mac running Sketchup version 8.0M2 ??
      We use on Mac and PC the latest version from google's website. (PC 8.0.11752/MAC 8.0.11.751)
      I did some more testing:
      model = Sketchup.active_model
      entities = model.entities
      puts '- Start test1 add_group bug on MAC -'
      start = Time.now
      for n in 1..1000 do #changed this setting for the testing
      	g = entities.add_group
      	g.name = n.to_s
      	point1 = Geom;;Point3d.new(n*10,0,0)
      	c = g.entities.add_cpoint point1
      puts 'Total time; ' + (start - Time.now).to_s
      Results: bugMAC.JPG
      At this moment we use a workaround. Place the groups in a new model (use the multiple documents on MAC), make a component of all the groups. Save this component and insert it in the model and explode it. The biggest problem of this workaround is that it's impossible to close the new temporary model with ruby. A other problem is that is still a lot slower than on PC.
      Anybody a solution?
      • Dan RathbunD
        Dan Rathbun
        WoW! Excellent test report. Shows that the Mac still has a problem.
        I wonder if the difference has to do with Ruby.? The Mac is still running the initial release of v1.8.5, and the PC was updated to v1.8.6-p287.
        There is a thread on how to point the symbolic references for Sketchup Ruby to a "normal" full Ruby install elesewhere on the Mac's harddrive. (You need to backup the current links, so you can switch back if necessary. Perhaps a shell script?)
        I'd be interested in seeing the comparison for the Mac, running v1.8.5-p0 and v1.8.6-p287, ... (and perhaps even the latest patchlevel for v1.8.7)
        I'm not here much anymore.
        • G
          GWD
          And here are the results for ruby 1.8.7 on mac:
          100 - 0.58 sec
          200 - 1.69 sec
          400 - 10.55 sec
          600 - 33.39 sec
          1000 - 147 sec
          Almost no difference with ruby 1.8.5 😞
          • Dan RathbunD
            Dan Rathbun
            Bummer... definately the problem is in the C++ code.
              jhauswirth
              Looking at the add_group Ruby code, its the same on both platforms.
              One reason (don't know if this is true) it could be slower on the Mac
              is the notifications that are sent around could be updating the Mac
              UI, like the component browser. This may be more efficiently done on
              the PC.
              Also, the same code (duplicate code/cut-n-pasted it looks like) that
              I fixed in the C++ API was also being used in the Ruby code.
              The bug report only mentioned the C++ API, so that's what got fixed.
                the PC.
                I have noticed that if you use Sketchup.status_text within a loop it will be very slow under OSX. It seems that the UI is forcefully freshened all the time, while on Windows you get "white-out" and the UI stops updating - but completes the loop much much faster.
                But if it is the UI that slows things down, then running the test with start_operation and disable_ui argument set to true, should show a good performance increase, right?
                • Dan RathbunD
                  Dan Rathbun
                  @John: thanks for taking a look at this, and "weighing in."
                  @GWD: Are all these groups to be added REALLY have all the same objects (like the example,) and just have a different location (transform) ?
                  • G
                    GWD
                    Dan,
                    No this is just a quick test that reproduce the problem. We have at this moment 2 totaly different script which have this problem.
                    • G
                      GWD
                      the PC.
                      I tested it with start_operation and it as no effect!
                      • G
                        GWD
                        I just did some testing with adding components instead of groups (see script below). And the result is shokking. Placing 600 component give about the same time as the 600 groups 0.7 sec on PC and 27 sec on MAC. BUT after the script ended the MAC keep on showing the busy icon for very long time. More than 5 minutes (then i killed sketchup). I did the same test on mac with different number of components and this are the results:
                        50 components 0.29 sec running script 17 sec busy icon after script
                        100 components 0.85 sec running script 35 sec busy icon after script
                        200 components 3.8 sec running script 2 min 25 sec busy icon after script
                        300 components 7.6 sec running script more than 5 min sec busy icon after script
                        600 components 27 sec running script more than 5 min busy icon after script
                        require 'sketchup'
                        UI.menu("PlugIns").add_item("bugMAC Test2") {
                        start = Time.now
                        for n in 1..600 do
                        	newdef = model.definitions.add
                        	newdef.name = n.to_s
                        	newdef.entities.add_cpoint point1
                        	pt = Geom;;Point3d.new 0,0,0
                        	trans = Geom;;Transformation.new pt
                        	i = model.entities.add_instance(newdef, trans)
                        	i.make_unique
                        • G
                          GWD
                          No solutions?
                          • Dan RathbunD
                            Dan Rathbun
                            Not surprising that it takes the same time to add groups and components, because a group is a special type of component, that also has a ComponentDefinition (whose group? attribute is true.)
                            The extra time, likely comes from adding all that new stuff to the Component browser. (guessing, here.)
                            Close any unneeded toolwindows, especially the Object browser. And use an operation with the disable_ui flag set.
                            That's all we can say. I guess John indicated that there were UI issues with the Mac edition. (I'm not sure if he said the SDK updates did, or did not make it into the last build... he was a bit ambiguous. But internal politics, ya know....)
                            You can always file a bug report. The more people that scream...
                            • G
                              GWD
                              Dan, where can i post a bug report?
                              • Dan RathbunD
                                Dan Rathbun
                                Open Sketchup... pulldown the Help menu, choose "Contact Us" ...
                                ... your browser will open, to the Google Sketchup Contact page.
                                Use the "Bug Report" link, to bring up the form, and fill it out.
                                • G
                                  GWD
                                  I submitted a bug report.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Good news for Mac users. This issue has been reported as fixed in the 8.0M3 release.
                                    see: SketchUp Release Notes
                                    and get the latest MR at the SketchUp Downloads page.
                                    • T
                                      th3lurker
                                      I would have loved it if they fixed add_face too. I've found workarounds, so i don't need it now, but still.
                                      • G
                                        GWD
                                        The problem isn't fixed at all on mac. I did the test i posted before with the new version. On mac the script runs 250% slower on the new version. On pc the script runs 300% faster on the new version!
                                          Can you post your test code?
                                          • G
                                            GWD
                                            You can find the code on page 3
                                            • 2 / 3
