    Add_group slow on mac
    48 Posts 7 Posters 22.3k Views 7 Watching
    • G
      GWD
      @dan rathbun said:
      @John: thanks for taking a look at this, and "weighing in."
      @GWD: Are all these groups to be added REALLY have all the same objects (like the example,) and just have a different location (transform) ?
      Dan,
      No this is just a quick test that reproduce the problem. We have at this moment 2 totaly different script which have this problem.
      • G
        GWD
        @thomthom said:
        @jhauswirth said:
        Looking at the add_group Ruby code, its the same on both platforms.
        One reason (don't know if this is true) it could be slower on the Mac
        is the notifications that are sent around could be updating the Mac
        UI, like the component browser. This may be more efficiently done on
        the PC.
        I have noticed that if you use Sketchup.status_text within a loop it will be very slow under OSX. It seems that the UI is forcefully freshened all the time, while on Windows you get "white-out" and the UI stops updating - but completes the loop much much faster.
        But if it is the UI that slows things down, then running the test with start_operation and disable_ui argument set to true, should show a good performance increase, right?
        I tested it with start_operation and it as no effect!
        • G
          GWD
          I just did some testing with adding components instead of groups (see script below). And the result is shokking. Placing 600 component give about the same time as the 600 groups 0.7 sec on PC and 27 sec on MAC. BUT after the script ended the MAC keep on showing the busy icon for very long time. More than 5 minutes (then i killed sketchup). I did the same test on mac with different number of components and this are the results:
          50 components 0.29 sec running script 17 sec busy icon after script
          100 components 0.85 sec running script 35 sec busy icon after script
          200 components 3.8 sec running script 2 min 25 sec busy icon after script
          300 components 7.6 sec running script more than 5 min sec busy icon after script
          600 components 27 sec running script more than 5 min busy icon after script
          require 'sketchup'
          UI.menu("PlugIns").add_item("bugMAC Test2") {
          model = Sketchup.active_model
          entities = model.entities
          puts '- Start test1 add_group bug on MAC -'
          start = Time.now
          for n in 1..600 do
          	newdef = model.definitions.add
          	newdef.name = n.to_s
          	point1 = Geom;;Point3d.new(n*10,0,0)
          	newdef.entities.add_cpoint point1
          	pt = Geom;;Point3d.new 0,0,0
          	trans = Geom;;Transformation.new pt
          	i = model.entities.add_instance(newdef, trans)
          	i.make_unique
          puts 'Total time; ' + (start - Time.now).to_s
          • G
            GWD
            No solutions?
            • Dan RathbunD
              Dan Rathbun
              Not surprising that it takes the same time to add groups and components, because a group is a special type of component, that also has a ComponentDefinition (whose group? attribute is true.)
              The extra time, likely comes from adding all that new stuff to the Component browser. (guessing, here.)
              Close any unneeded toolwindows, especially the Object browser. And use an operation with the disable_ui flag set.
              That's all we can say. I guess John indicated that there were UI issues with the Mac edition. (I'm not sure if he said the SDK updates did, or did not make it into the last build... he was a bit ambiguous. But internal politics, ya know....)
              You can always file a bug report. The more people that scream...
              I'm not here much anymore.
              • G
                GWD
                Dan, where can i post a bug report?
                • Dan RathbunD
                  Dan Rathbun
                  Open Sketchup... pulldown the Help menu, choose "Contact Us" ...
                  ... your browser will open, to the Google Sketchup Contact page.
                  Use the "Bug Report" link, to bring up the form, and fill it out.
                  • G
                    GWD
                    I submitted a bug report.
                    • Dan RathbunD
                      Dan Rathbun
                      Good news for Mac users. This issue has been reported as fixed in the 8.0M3 release.
                      see: SketchUp Release Notes
                      and get the latest MR at the SketchUp Downloads page.
                      • T
                        th3lurker
                        I would have loved it if they fixed add_face too. I've found workarounds, so i don't need it now, but still.
                        • G
                          GWD
                          The problem isn't fixed at all on mac. I did the test i posted before with the new version. On mac the script runs 250% slower on the new version. On pc the script runs 300% faster on the new version!
                            Can you post your test code?
                            • G
                              GWD
                              You can find the code on page 3
                                driven
                                after a lot of digging, it appears that your test code will run in 0.8[1..3] seconds on both Snow Leopard and Mountain Lion with free or pro SU v6, v7 or v8, UNLESS you have either of these in your preference list
                                %(#FF00BF)[<string>OutlinerController</string>
                                <string>ComponentGBrowserController</string>
                                these have no ill effect, but add either of the others and you beach-ball...
                                %(#00BF00)[<key>OpenInspectors</key>
                                <array>
                                <string>PagePanelController</string>
                                <string>LayerPanelController</string>
                                <string>StyleBrowserController</string>
                                <string>SoftenPanelController</string>
                                <string>EntityInfoController</string>
                                </array>]
                                They actually fork the main Thread into a timer loop to make the thumbnails and will do that even if the ruby has run before you open the Inspector. i.e run test code without, then zoom, orbit, make new geometry, etc... turn on 'Components' or 'Outliner' and you'll get a beach-ball.
                                If 'Components' is run first 'Outliner' opens straight away.
                                • 3 / 3
