    [Plugin] Select component instances on right click
    28 Posts 16 Posters 37.1k Views 16 Watching
      confitex architure
      @jorgensen said:
      Would it be possible to change the script so that it don't select instances that are hidden, or instances that are on a hidden layer ?
      Yes it is. It's even far better. The link on the first post has been refreshed
        confitex architure
        @sepo said:
        I have installed the version 2 from the top of this tread.
        Hi sepo, What are the name of your instances? select instances only works when components are selected, no groups allowed in the selection set.
        Are you sure you've deleted the first version of the plugin?
          Morpeth
          very impressed.
          • JClementsJ Offline
            JClements
            Doesn't work for me for the Families.
            If I select either a unique component version or the original component, right-click, choose Families from the menu the result is that the geometry is DESELECTED.
            I copied the script at the top of the posting 31 May 08 (a.m.).
            Also, note that the there are two .rb's listed in the script, one with "v2", the other without.
              JClements
              This is a copy of part of the script's code. See the reference to the .rb in the 1st and last line:
              if (not file_loaded?("select_instance.rb") )
              UI.add_context_menu_handler do |menu|
              if compos_valid_selection
              menu.add_separator
              menu.add_item("Select Instances") { select_component_instance }
              menu.add_item("Select Families") { select_component_made_unique }
              file_loaded "select_instancev2.rb"
              Attached is a test file. Now when I run the script, choosing Select Families recogizes a family component and selects one family instance.
              Try right-clicking on each component instant and the choose Select Families; for me the resulting selection always changes to Object B. Is the script intended to work or is it supposed to select all family instances at once?
              Instances.skp
                confitex architure
                Hi John,
                I don't understand what's wrong with the list. Do you mean in your plugins folder? You should erase the former version, the one without the "v2", from this folder.
                I tried again and again and everything is ok on my side. What are the name of your components ?
                  confitex architure
                  Hi John,
                  it has been fixed (DL on the first post)
                    JClements
                    Thank you.
                      Abdullah
                      I want to select multiple components with similar definition names (like "compo" and "comp#1") in the entire Model. It means, it means not only those inside the selected object, but also the others ones which are inside other objects.
                      I have the following plugins:
                      [] "Selection Toys", which selects components from everywhere, but only those with same name.
                      ] "Select Instances", which selects component families with similar names (like "compo" and "comp#1"), but only inside the selected object and not everywhere.
                        Take care making selection sets that span different contexts - you can Bugsplat it you try to manipulate them !
                        To select instances of similar named definitions this will work
                        n="match";m=Sketchup.active_model;s=m.selection;s.clear;m.definitions.each{|d|s.add d.instances if d.name=~/#{n}/}
                        Change the string 'match' within the "" to the pattern match you want - I suggest that you read-up of pattern-matching - e.g. n="[Cc]at" finds all definitions like 'Cat', 'cat1', 'tomcat', whereas anchoring the pattern to the start/end like this n="^[Cc]at" only matches 'Cat and 'cat1', or n="m[Cc]at$" to only matches '#tomcat' and 'TomCat'...
                          Abdullah
                          It didn't work first, because there was a "$" in the string (it looked like "abc$match"), so took only the part after "$" (and it looked like "match")and it work well. Thank you very much.
                          By the way, are there any "good" Sketchup Ruby Tutorials/Books for Beginners? I would really like to learn it.
                            Look for Automatic Sketchup - as a pdf or a to-buy hard-copy.
                            There are also several other links in the "developers' forum"...
                            If you place a $ at the very end it says the pattern ends there.
                            If you want to search for a '$' inside the text escape it '$'; same with the '^' which marks the very beginning.
                            Here's a short guide to pattern matching... http://www.tutorialspoint.com/ruby/ruby_regular_expressions.htm
                              John_C
                              That's great, thanks ... πŸ˜„
                              • F Offline
                                fullyfledgeded
                                Hi, Is there any way of selecting component families even if they are in groups or nested within other components? The only way i can get it to work with this plugin is if i explode until all desired components are no longer grouped or component nested.
                                • F Offline
                                  fullyfledgeded
                                  Thanks TIG and Abdullah for sorting out a that code πŸŽ‰ I was frantically, searching the forum for a solution that i missed this code.
                                  Alot of my component instances, have annoyingly renamed, with #1, #2 etc added to them, ultimately creating new component definitions, increasing file size 😠
                                  now that i can select multiple instances at once, I can replace them with one component definition.
                                  However I still don't why this is happening, other people have this problem too:
                                  404 Not Found
                                  (sketchucation.com)
                                  might start a new post to see if there is any more info
                                  cheers
                                    smicha
                                    Great plugin. Thanks
                                      Sir
                                      fantastic plugin. extremely useful.
                                      thanks
                                      • 2 / 2
