    How to create texture files and import
    12 Posts 3 Posters 1.0k Views 3 Watching
    • C
      Centipede13
      OK I've done that, but it is tiled. Is that a function of the resolution of the image?
        Real wood isn't seamless so tiling would be natural. It doesn't matter what the resolution of the image is as far as that goes.
        That's why I use images of full size boards and not those goofy little square images. For example, the same material image is used for the different pieces of the top of the table in this image but I picked different sections of it for each piece.
        http://farm8.staticflickr.com/7001/6754334421_077b3cf90f_z.jpg
        And on this hayrake table, I used several plank images to paint the table top. The images were of planks for the same log so the color matches pretty well.
        http://farm6.staticflickr.com/5256/5479721282_921655355e_z.jpg
        Here's a close up of the Morris chair from the first image. the same thing applies. Only a couple of wood grain texture images were needed because I could pick out different parts of an image for different parts of the chair.
        http://farm6.staticflickr.com/5249/5360168878_5af27ee535_z.jpg
        If you want seamless you should go with plastic laminate. πŸ˜†
        • C
          Centipede13
          See how the image is tiled? Is that normal?
          Tiled Texture
          The image on top is the 2 inch x 4 inch x 6 feet component.
          The bottom image is a rectangle that is 4 inch x 6 feet.
          I import the image to the rectangle, as texture, then I paint the face of the component.
          The two boxes (~ 2 feet each) shows where the image is repeated instead of spanning the whole component.
            Can you post the original image?
            • C
              Centipede13
              Here's the image.
                I can't tell well enough from your first posted image but it looks like either the image isn't set to be 6' long or the "board" is longer. I imported the original image as you posted it and applied it to two "boards" One I made 12' long so you can see how the image repeats.
                weathered Board.skp
                • C
                  Centipede13
                  Your file is exactly what I was expecting.
                  I'm not sure what I had done wrong, but I started over from a new file.
                  Now it's working just like yours πŸ˜•
                  Thanks for the help.
                  • C
                    Centipede13
                    I have another question regarding importing.
                    I noticed that there is a loss of resolution from the image to the imported texture.
                    (Original image is clearer, imported texture is fuzzier)
                    Is there a setting that will keep the original resolution?
                    Or should my original image be a higher resolution to start with?
                    • GaieusG
                      SketchUp reduces what it displays to 1024 pixel resolution (or 2048 if you enable "Use maximum texture size" under Window > Preferences > OpenGL settings - but this can low down performance with a slower video card).
                        FWIW, I didn't have Use Maximum Texture Size ticked when I imported your image.
                        As to what you did differently, before, I guess I don't know. It's possible that instead of setting the length of the material by clicking on the right edge of the rectangle, you clicked on the far horizontal edge and the rectangle wasn't the right width. Might be possible to deconstruct the SKP file to figure it out but since you've now got it sorted, don't look back.
