    [Plugin][Code]SKMtools,Material/ImageTools
    176 Posts 36 Posters 270.1k Views 36 Watching
      Here's an minor update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
      For ImageTrimmer - 'Simplified image' - a rare error on delete edge is now trapped.
        Here's a major update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
        The MAC execution of the jar files has been addressed - it affects most tools/methods.
        You need Java installed/enabled and appropriate permissions to execute files and read/write to the ../Plugins/SKMtools folder. On a MAC you might be prompted to allow a jar file to run - if so answer 'yes' - this should only get asked the once for each jar-type... πŸ€“
          Here's an update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677 which fixes a minor glitch with the ImageAnimationAppObserver - it was working OK but could sometimes give spurious error messages in an open Ruby Console until this fix...
            Adasiekkk
            Hi!
            Congrats on an amazing plugin, but there is one major issue I have.
            When I decide to undo the previous action (Ctrl+Z or Edit->Undo), in the place where animation was I now have all pictures tiled next to each other.
            Thanks,
            Adam
              Rather than try to undo Image Animations you must just stop all animations.
              To get back to an original Imgage's start-frame you need to start that individual Image's animation... angd then stop it when the frame you want appears...
                billberet
                hey everyone. I am new to this forum so please be gentle.
                i just built my first maker-bot and it is working great printing all my 3d models.
                i have installed google sketchup, free version, v8
                i installed the plugin, and everything is fine so far. i have the image trimmer menu item under the tools dropdown.
                so i want to create a 3d model of a 2d image.
                i import a greyscale .png file with transparencies, then i run the IMAGE TRIMMER plugin.
                when i do this, i get the notifications on the bottom saying 'making edges files'
                the dots scroll as it processes ...............
                then that's it, the process finishes and nothing happens.
                i am running on a win7 machine 64bit.
                does anyone have any ideas that can point me in the right direction?
                thanks again
                bill
                  Billberet
                  Read back through the posts... esp. about ensuring Java, and thereby .jar files, are enabled, AND that the .jar extension isn't hijacked by a compression app.
                  Also see a recent post about how a PNG Image must have solid and transparent areas - otherwise semi-transparent areas are taken as transparent too...
                    billberet
                    thanks,
                    just had to right click, run as administrator!!!
                    then poof, i had access to the jar files!!!!
                    thanks again
                    -bb
                      marchorg
                      Trimmer appears in the tools menu. I use the french version. I import a PNG image "use as image" (Utiliser comme image) in sketchup 8.
                      While the image still selected I select "Trimmer" but nothing seems to happen.
                      Any help welcome,
                      Kind regards
                      Marc
                        Have you installed all of the files in the subfolder as they come packaged in the zip file ?
                        The imported Image MUST be a PNG file, and have a transparent background [note semi-transparent pixels within the image are regarded as 'to be removed' too... so edit the image file before importing it; flatten it, add a transparent layer back, pick the background color[s] using a magic-wand and delete those pixels so the background shows as fully transparent, tidy up loose pixels, very thing parts etc, save it and import!].
                        The PNG Image needs to be a reasonable size...
                        Do you get error messages in the Ruby Console.
                        Is Java properly enabled on your computer [Control-panel > Java] ?
                        Are .jar files set to be be allowed to execute locally ?
                        Are .jar files associated with Java and not erroneously with some 'Compression' software ?
                        Do you have full-permissions to your Plugins folder and all of its subfolders ?
                        Do you have access-permissions to execute the '.jar' files needed to process the image ?
                        Is anything made in a subfolder in the folder with the SKP - if so what ?
                        Have you tried running Sketchup as administrator ?
                        πŸ˜•
                        There are many possibilities.
                        If you real the posts in this thread you will see the list of mess ups. and how fixing the issues, that has allowed every user to get things working properly [eventually]...
                        πŸ€“
                          marchorg
                          I tried to make Java the default program to open .jar files. Got an error message.
                          I tried to open Sketchup as administrator. The trimmer seemed to fail once but did work the second time ? Anyway it did work! 😍
                          Thank you very much for your help
                          Marchorg
                          • pbacotP Offline
                            I wonder if anyone can tell what I am doing wrong with Image Trimmer.
                            If I run the image in the attached SU file. I get a component. Image Trimmer seems to complete all operations. But the component is just a few scattered dots. The rest of the image is gone.
                            File with tricky image.
                              It's useful if you supply the original Image file too...
                              For some reason it's failing to make a proper loop of the main 'face' - there a one pixel gap in the crook of her arm/hand [also a non-transparent white gap between the hands that needs sorting]...Capture.PNG To fix this, edit the component.
                              Edit > Select-All
                              Entity Info > untick 'hidden' so that all edges are now visible.
                              Draw in some large diagonals and make faces [as above].
                              You can quickly zoom into the problem area.
                              Add in the missing edge to heal that gap and make all needed faces.
                              To tidy up, use a 'DeleteCoplanarEdges' tool to remove the diagonal lines you've just added - or Erase them.
                              Now open the Material Browser and find the image-material.
                              Paint it onto the front AND back faces of the now-faced cutout.
                              Select-All again, and deselect the Faces - either using a 'SelectionTool' or by holding ctrl+shift and clicking on the face[s].
                              Use the Context-menu to Hide the still selected Edges.
                              I'm unsure as to why it can't cope with this particular image - that one pixel seems to have scuppered it ! Perhaps editing the Image in Gimp osa would reveal an odd combo of solid and transparent pixels around this area - the simpler the PNG Image's outline is then the less prone ImageTrimmer is to errorsCapture2.PNG Shown here with all edges still unhidden for clarity...
                              EDIT:
                              I've edited the exported Image and made that 'crook' less sharp, also tidied up hair/hands, cropped it to optimize its size etc; Re-imported it etc...
                              Now it ImageTrims quickly and faultlessly...Capture3.PNGImgTrimRedo.skp
                              • pbacotP Offline
                                TIG,
                                Thank you so much for the explanation. I thought it was something more basically wrong with my usage. I did see that some of the shape could close and not other parts, and applied the texture but it looked wrong and I felt I was going the wrong direction with this.
                                After previous tries I took the image into GIMP and applied a solid mask of the shape,looked for holes and flattened, trimmed again, and still got the result you saw. I now know that it WILL work but may need to reprocess some shapes further. The original image had a lot of translucent pixels in that crook area. Some GIMP process to make hard and simplified edges would help. I see you were able to put back in some of the holes, which I had filled, thinking they were part of the problem.
                                Excellent plugin! Sorry I was such a bother.
                                Peter
                                  No worries...
                                  You'll appreciate that the algorithms in the files that have to find the edges around the 'solid' parts are quite complex, and occasionally you can contrive a set of pixels that it processes in a gapped result - in your case it was just one pixel ! A simple image-edit fixed it in a trice... Try to keep PNG files for trimming quite simple, with no single pixel 'inlets' or 'peninsulas' as these are ignored anyway as they cannot form a face because their two edges would be coincident and [rare] occasional combos can cause edges to get missed and face to fail to form...
                                  πŸ€“
                                  With Gimp I find the best way is to flatten the PNG, add a transparent alpha-layer back in and then use the 'magic-wand' to pick the background color pixels en mass, with a limited color-variation range + delete-key to remove them - you can then see the 'chequered-background' rather than the typical 'white'; then zoom in and pick any 'edge pixels' that have been 'anti-aliased' where the object's color and the background's color are 'merged'... and delete those too - always ensuring that small transparent holes or solid 'peninsulas' or 'islands' are at least 2 pixels wide... Finally auto-crop the PNG image to minimize the amount of 'blank' background, this is because every pixel needs to be considered, so because the transparent ones are not important to us in the final form you are best of to minimize how many of them there are in the image, before trimming it...
                                  β˜€
                                  • pbacotP Offline
                                    Or this might be possible in most images using "grow" selection.
                                    Thanks, that would not have occurred to me--somehow I thought it would just ignore those. Peter
                                      It does ignore them BUT it has to look at them to find out they are to be ignored, so an image with masses of blank outer space will take longer to process simply because all of those [eventually] unused pixels must be examined; so if they are not going to be used in the image-trimming don't include them in the Image... That also goes for all tiny areas in an Image; any that are < 2 pixels across will [usually] not become either faces or 'holes' because their edges will be coincident when considered for trimming !
                                        ggggito
                                          Here's an update: http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
                                          The SKMtools Temp folder that is needed to process files etc, is now made in the User's Temp folder [OS specific] rather that the ../Plugins/SKMtools folder, avoiding potential permission issues...
                                            Ben Ritter
                                            TIG,
                                            Thank you for your generosity.
                                            What am I doing wrong? I imported a .png and implement image trimmer, but I don't see anything different about it once the process is completed.
                                            • 7 / 9
