    SketchyPhysics3.2 (Dec 2)
    55 Posts 23 Posters 22.0k Views 23 Watching
    • robintR Offline
      robint
      hi all
      Im posting some models that illustrate some points and queries
      all comments gratefully received
      Robin
      [my cone n ball
      rotates using a motor hinge (when will this become reversible?
      Two balls used, small one falls to bottom so that larger one is off centre and crawls up the side and out otherwise just drops to bottom.
      nice demo of centripetal force and a hollow solid](/uploads/imported_attachments/elvl_myconeandball1.skp)
      [my lift ball
      tried using lift capsule and got it working, then i moved the capsule and it all fell apart. but now i cannot recreate a lift capsul with a slider or a piston
      strikes me that a slider is unnecessry as its the same as a piston but without accel and damping figures - so why bother.](/uploads/imported_attachments/E5tW_myliftball.skp)
      [my rotating box
      strange that the slider now makes a hinge behave like a servo
      If you push tha slider to one end then the cube over turns and starts rotating in an erratic manner (like a ball running up and down a valley then gaining enough momentum to over top and run down the next valley.
      before (maybe in a previous version of SP this feature would behave like a true reversible motor - now it doesnt? what happened
      also if you get it going full speed one way then throw it into full speed other way, it crashes SU](/uploads/imported_attachments/wXwb_myrotatingbox1.skp)
      [my spring box
      cant get the spring to move at all. is it now not supported in sp3.2 ?](/uploads/imported_attachments/IRVt_myspringbox1.skp)
      As one door closes another one slams in your face
        solodown
        Toujours pas de nouvelles pour faire fonctionner ce plug-in sous Mac OS X 10.5.8 avec Google SketchUp ?
        • Z Offline
          zunkian
          Hi!
          Is there a manual for SketchyPhysics for beginners?
          If there is one, please upload.
          Thank you.
          Andy
          • dereiD Offline
            derei
            Indeed a user manual for users that did not used ketchyPhysics before would be nice. I noticed that some beginners tips are to be fond here http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki , but I'm sure that version 3.2 have much-much more features than are detailed there.
            Thanks.
            • 4 Offline
              4dHans
              Could you do like explosions in a future version? That would be cool! 😍
                mickeyao
                MBP with 10.5.8 Thanks!
                  sketchyKev
                  @robint said:
                  hi all
                  Robin
                  For the first one (rotating cone) you can make the motor reversible by changing the controller code to (slider('motor8055')-0.5)*2
                  Using that code the middle position of the slide control is off, full left turns one way and right turns the other way.
                  For the second one, to create a lift capsule do this:
                  Create a solid floor.
                  Place a wheel capsule with built in hinge on the floor.
                  Place a lift capsule with built in slider on the floor.
                  Using the JCT click on the hinge joint, then ctrl-click on the slider.
                  A menu pops up asking if you want to "Create a worm gear..". Click "OK".
                  Run the simulation and turn the hinge capsule clockwise and the other capsule should rise.
                  You can build a lift from scratch from components. Just make sure each joint is grouped with the moving objects and joint connected with something static before trying to make the worm gear connection.
                  For the record a slider is not a piston with the accel and drag values set to zero. A piston with those values will not move.
                  For the rotating box using a slide controller on a hinge, the program does not recognise a controller called "speed" so it has defaulted to servo behaviour. You can get the same behaviour from a servo by setting min=-180 and max=180. It is known that servos behave badly if you try to get them to complete full circles or more than one circle. There is no need to mess with the hinge controllers as servos and motors are provided.
                  For the box on a spring, the spring is orientated vertically and does not allow sideways movement or rotation. When you try to drag the box the drag action defaults to horizontal movement. To pull the box up or down inline with the spring you need to hold left-shift on your keyboard while dragging with the left mouse button. Try the spring orientated sideways and it should work fine. The springs are on the stiff side so it is worth playing with the accel and damp settings.
                  Hope that helps.
                    AlainBo
                    There are months now that sketchyphysics 3.2 installs 3.1 !!!
                    Don't understand this update !?
                      bouleaux
                      Hello,
                      congratulations for this marvellous job !
                      I'm using sketchup 8 on a Mac Book Pro running on Mac Os 10.5.8
                      and I would loooove to be able to use sketchyphysics with this computer
                      any chance ?
                      thx again
                      • OxerO Offline
                        Oxer
                        @bouleaux said:
                        Hello,
                        any chance ?
                        thx again
                        Hi, bouleaux
                        I'm a mac user too, the last version 3.2 doesn't work on Mac but the 3.1 version works fine on OSX Leopard with SU 8.
                        I hope this help you.
                          bouleaux
                          Hello Oxer, many thanks
                          I tried to find the 3.1 version, but it doesn't seem to be available for download anymore (on this page : http://code.google.com/p/sketchyphysics/downloads/list)
                          Do you know of another place to find it ?
                          Thank again for your answer
                          • OxerO Offline
                            Oxer
                            If you want i can send it you by PM
                              AlainBo
                              I tried to add kaybord control on my physified lynx crane but I cannot get it working properly.
                              It actually works with sliders so, the joint position is given by the slider position so the crane's arm, for example stays in the position set by the slider.
                              With keybord control it's different and even if I can move the arm with a key, it cannot stay in position when I release the key.
                              original joints where servo. I tried to use a motor instead but the result is almost the same.
                              Any idea?
                              lynx_100ton_mobile_crane SP_KB.skp
                              • ashscottA Offline
                                ashscott
                                Here is the answer to your question from this thread: http://forums.sketchucation.com/viewtopic.php?f=61&t=44399
                                There is a much better answer than using a motor to place a joint where you want it - you need to use a servo and a little ruby script
                                Step1: place your servo within the group you want to move and attach it to a base group
                                Step2: select the servo and open the sketchyphysics UI
                                Step3: within the UI apply the following settings
                                min:0
                                max:1
                                accel:4000
                                damp:1000
                                controller:@servo1 (you can actually call it anything starting with @
                                Step4: Select the base of your model and open the sketchyphysics UI
                                Step5: place the following rubyscript in there:
                                    if frame<1.00
                                    @servo1=0.00
                                    # this allows servo to incrementally increase based on joystick input (righty) you can change it to any of the joystick axes
                                    @servo1+=(0.5-righty)
                                    # this sets range of movement for the servo as it is not set in the servo's UI
                                    if @servo1>45;@servo1=45;end
                                    if @servo1<-45;@servo1=-45;end
                                It took me a long time to work this out (reverse engineering another model) so I am more than happy to help anyone out with it if these instructions are too hard to follow.
                                I believe this is a very powerful function in sketchyphysics and I have only seen it in one model in the 3DWH
                                Just some stuff I do with Sketchup.
                                  AlainBo
                                  Hi Ashscott,
                                  Thanks for your answer.
                                  I tried your script and one I wrote and in any case I get the following error when I start the simulation:
                                  Error starting the simulation: Error in Script:
                                  undefined method'<' for nil:NilClass
                                  C:/Program......../ControllerCommands.rb:1314:in 'initEvents'
                                  It something is not correctly initialized. Is there something to import at the beginning of the script or something like that?
                                  Any idea?
                                  Is there any wiki on the basics of keyboard control? The only one I know is http://sketchyphysics.wikia.com/wiki/Ruby.
                                  • ashscottA Offline
                                    ashscott
                                    You need to make sure that the name of your servo in the controller box (select the servo and press the 'UI' button) is the same name used in the script - in the example I have used the name '@servo1'
                                    It looks like it is spazzing out because you haven't got a name right somewhere......
                                      AlainBo
                                      Hi Ashscott
                                      I didn't really take time to verify but I diectly entered the script like that in the "scripted" field. I think it's the problem because no method is known.
                                      In the "On Tick" field, no problem.
                                      I think a method, like onTick{ ...} for example, should be created.
                                      Alain
                                      • emerald15E Offline
                                        emerald15
                                        Hmm... same thing here. I started out with 3.2 but it seemed a bit un-stable (might have been my fault - still learning). I reinstalled 3.2 but at the install wizard point it suddenly reverted 3.1. This then seemed to case more conflict & SP randomly worked or crashed. I'm also using windows 7 (x64) & SU8 - could it be this combi won't load SP3.2?
                                        Solution for the moment is running SP3 instead - but no sound effects.
                                        NB. has anyone actully produced an SP movie with sound effects - I haven't seen one yet.
                                          emerald15
                                          Don't know if anyone can suggest a solution here... I was getting to know sketchyphysics (although it sees a bit temperamental, not always running as it should. I'd produced a few animations (domino falls, etc.) Now it crashes as soon as I hit SP play. I've re-installed 3.1 & again onto a second PC - but still the play button crashed SU. Any ieas?... is there somehting I need to set in SU preferences maybe?
                                          • ashscottA Offline
                                            ashscott
                                            Try making a simple SP file from scratch - sounds like there might be something in your file that is causing issues if you have been trying to open the same file - I get that often when I have made errors in SU models or ruby script before and it takes a while to work out what it is by elimination but I don't know a better way to do it
                                            • 3 / 3
