    Animations
    9 Posts 4 Posters 337 Views 4 Watching
      Diogo_Louro
      Hey guy's, my name is Diogo and this is my first post, and i have a problem.
      I have some works done on SketchUp, with some scenes, but, when i export the animation the quality of it sucks, and i need to know how to improve the quality of it.
      Thanks for the help
        Pretty hard to tell you how to improve something when we have no idea what you're getting now. Why don't you share a sample with us so we have a starting point.
        • Jean LemireJ Offline
          Jean Lemire
          Hi Diogo, hi folks.
          If you click on the Optionbutton on the Animation Export Dialog Window, you can increase the pixel count to get a larger picture. You can also change the frame rate to get an animation that is more fluid. You can also use antialiasing to smooth diagonal lines and minimize the staircase effet.
          Just ideas.
            Diogo_Louro
            Hey,
            Here it is, my animation.
            Like i said, the video has low, low, low, quality, and i need to improve that.
            APW COIMBRA - Europeu 2012.avi
              Jean Lemire
              Hi Diogo, hi folks.
              First, go into the animation setupand uncheck the box labeled Scene delay. This will remove the pause that can be seen for each scene.
              Second, have you read my first post?
              What is your frame rate ? It looks like the default 10. Try more.
              What is the picture size ?
              Do you use antialiasing(probably not).
              Just ideas.
                Diogo_Louro
                Hey guy's,
                I saw your last post, but it's still the same.
                And i can't find the frame rate.
                • BoxB Offline
                  You change the image size and frame rate in the Options section of the Animation export window.
                    Diogo_Louro
                    Hey guys
                    Thanks for the help!
                      Jean Lemire
                      Hi Diogo, hi folks.
                      To access the animation settings to be able to set the scene delay to 0, use View Menu --> Animation --> Settings or Window menu --> Model info --> Animation.
                      Just ideas.
