    MR2 broke plugin during C extension require
    51 Posts 4 Posters 3.9k Views 4 Watching
      Here we go: similar error reported: http://forums.sketchucation.com/viewtopic.php?f=180&t=41077&start=60#p376236
      Later it seemed to be related to that he had built Ruby himself. It worked when he used the pre-built version, Don't know why it was so though.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=41077&p=378810#p376632
        @thomthom said:
        TIG had problems with installing plugins with the RBZ feature. Not related to C Extensions.
        There was someone else the other day that reported similar error though, will see if I can find the thread.
        I've not experienced any C Extensions problems when migrating to M2.
        that issue came from the fact that there was a 'custom icon' for the Plugins folder, adding it subtly changed the permissions under Vista and the M2 tested code then thought the user didn't have permission to write to the folder, when they did ! This might have been fixed in the public version - I haven't tried it. πŸ˜•
          But did it cause a problem in loading C Extensions? Wasn't it the RBZ installer that threw errors?
            The MR2 [in testing] RBZ installer threw an error - but no C-extensions broke.
            • Dan RathbunD
              Dan Rathbun
              Well his Tortoise SVN program IS changing all the folder icons to a custom icon.
              require is saying it cannot find the file, but it does exist.
              I'm not here much anymore.
                No, it says it cannot find the module - not the same as the file.
                If the file was not found there would be a different error message - like this:
                require 'foobar' Error: #<LoadError: (eval):155:inrequire': no such file to load -- foobar>
                (eval):155
                (eval):155`
                  draftomatic
                  @dan rathbun said:
                  With a script perhaps ?
                  Wow, I hope you didn't write that just for me! I'm gonna play with it right now. I am very suspicious about Vista and permissions/folder attributes since I've confirmed it works on XP and 7.
                    draftomatic
                    Instantly when I started reading this sentence, the words "no such file to load..." popped into my head. Thanks for catching that.
                    So what's the difference? I'm not finding much info from my googling.
                      Did you see the links I posted earlier, on the second page in this thread?
                        draftomatic
                        Yes I read through them, but I didn't see anything useful. One of those threads didn't seem to ever find a resolution? Or did I miss something...
                        Also I'm not using a self-built ruby... I'm using 1.8.6 p287 for the libraries and dll.
                        Edit: Just re-read the thread, seems like he resolved it by using the pre-built Ruby. Which is what I've been using all along...
                        • Dan RathbunD
                          Dan Rathbun
                          Well for anyone.
                          I suppose we could make it a bit more flexible, and move it to it's own topic with a "[Code]" prefix so Jim's code snippet indexer will list it.
                          It also should be module wrapped in some way. In some generic namespace SkpFileUtils, or something, and the methods made into module functions. Maybe a mixin module anyone can mix into custom modules and classes ?
                            draftomatic
                            Hey Dan. I ran the script and it didn't help.
                            I was also playing with printing the chmod flags for each directory (using File.stat.mode), and using File.readable? (which was always false, even after running your script). I'm not an expert at this stuff and am getting distracted by other priorities.
                            For what it's worth, the result of:
                            sprintf("%o", File.stat("/").mode)
                            is always 40755 (octal I believe?) for the directories, before and after running your script.
                              Can you share the .so file you have problems with? So we can test - figure out if it's a local issue on your computer or the binary itself..
                              • Dan RathbunD
                                Dan Rathbun
                                Well sorry. As I did say it wasn't tested.
                                  draftomatic
                                  Oh, I think it did was it was supposed to, except that maybe the chmod call didn't do anything. Not sure, but it did recurse the folders okay, so thanks for that! =D
                                  I may get a coworker to help me out with this later in the week since she knows more about chmod and permissions.
                                    Isn't it easier to just test on another machine? One with a clean SU installation. Then you can find out if it's a local issue or not.
                                      draftomatic
                                      I have tried 4 machines with fresh installations - 1 XP, 2 Vista, 1 Win7.
                                      The two Vistas have the problem. The others don't.
                                        draftomatic
                                        Here's the troublesome .so file. Just rename it with a .so extension (Sketchucation wouldn't let me upload as .so) Although it might depend on others in the Ruby installation.
                                        This came straight from:
                                        Ruby 1.8.6 p287 One-Click Installer: http://rubyforge.org/frs/download.php/47082/ruby186-27_rc2.exe
                                        openssl.txt
                                          draftomatic
                                          FYI, all I did with my plugin is I packaged most of that Ruby installation in the above post with my plugin. I tried to trim most of the fat as there are source files etc. in there. Probably still left a huge amount in that doesn't need to be...
                                          Edit: I know I've made several post about this before, but I tried to do the same thing on Mac and I could never get a 1.8.5 that would work (I even tried compiling it but every version I could find after scouring the internet was missing the thread.so standard C extension. A sad story... we still don't have Mac support because of this >.< ).
                                          So anyway if you want to reproduce the error, just drop that installation into your \Plugins\Foo folder and try requiring openssl.so on Vista. As always you may want to adjust your $LOAD_PATH variable.
                                            I had no problems loading the openssl.so file you posted. (Win7 64bit)
                                            • 2 / 3
