    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Statusbar text in model
    13 Posts 3 Posters 769 Views 3 Watching
    • CadFatherC Offline
      CadFather
      Hi, is there any way to show the text in the status bar on the top left of the modeling window (only when processing)?
      that way we could hide the status bar altogether and get some extra room..
        Moved this into Developers'...
        I don't think it can be done, neither manually nor in code.
          CadFather
          that's a pity - takes too much space..
          • Dan RathbunD Offline
            Dan Rathbun
            Maybe. (driven is playing with using the model.add_note() method. This means the user cannot then use the model's note for anything else, and there is/was a bug, that the note does not show when there are no entities in the model.)
            "only when processing" is a challenge. There is always some text displayed. What do you mean by this ?
            The main problem is that there are no API getter methods to actually get the text from the statusbar, or the VCB label nor VCB value. There are no API observer classes nor callback methods, that watch the statusbar nor VCB.
            We know how to toggle the statusbar on/off on PC via Sketchup.send_action(59393) but not test if it's visible via the API.
            I do not know if it can be done (or how,) on Mac.
            Also, the VCB needs to be undocked from the Statusbar when it's hidden. The VCB also does not have API methods to hide, show or get it's visibility state. (Again we can use Win32API calls only on PC, to tweak this, provided we can get a list of all the various localized language titles for "Measurements".)
            I'm not here much anymore.
              CadFather
              Dan, thanks for that explanation of the inner workings - very clear.
              the only status bar info i really need is the plugins progress and options (like sandbox tools progress or fredo's bezierspline options, etc..). the standard sketchup messages i know them by heart and usually ignore.
              though this would also mean that other developers would have to write code specific for such a function, a la 'organizer.rb'. ๐Ÿ˜’
                Sketchup always starts with the status-bar showing... [I think!]
                So then the lines of code in this 'method':
                def status_bar_toggle() Sketchup.send_action(59393) if [PLATFORM].grep(/mswin/)==[PLATFORM] end
                run once, either when Sketchup or your tool first opens, will turn the status-bar OFF [PC only !]
                Run again it turns the status-bar back ON.
                It's a 'toggle'.
                So perhaps you need a persistent variable [@/@@ even $ ?] ... and then you do NOT re-toggle if it's set the once, or perhaps only have it run 'OFF' when the tool is active, and reset 'ON' as the tool exits for any reason.
                  CadFather
                  Yes TIG, if you send 59393 the status toggles on-off (i already use it).
                  on pc the state is stored in the registry so next session it will be remembered.
                    Where in the registry ?
                      CadFather
                      HKEY_CURRENT_USER\Software\Google\SketchUp8
                        Because the '.send_action(59393)' is a 'toggle' you don't know if you are turning the status-bar's visibility OFF or ON !
                        This is OK if you can see the effect, but it's useless inside a 'tool' when you want to switch it 'OFF' - if it's already 'OFF' you'll switch it 'ON' !
                        The registry entry isn't updated until Sketchup closes, so you can't check that while inside a SKP, BUT you can get it at startup.
                        Incidentally, if you try 'read_default' for 'Visible' it fails to get it as I suspect it's the wrong sort of key [i.e. not REG_Z] ?
                        You could make .rb that makes a PC .cmd file and get the appropriate Registry key 'Visible' value, erasing temp-files etc.
                        This .rb could auto-load at startup... and always set status-bar visibility ON by erasing the 'Visible' key OR set it OFF by adding the 'Visible' key with the right value if it's NOT there...
                        It seems to be 'ToolbarsUser-Bar14' consistently - i.e. same on mine - presumably the early numbered toolbars are made in order by Sketchup [at least in this version] ?
                          Dan Rathbun
                          DO NOT use PLATFORM, it's deprecated (and will be removed sometime.)
                          module Your_UI_Utilities
                          if RUBY_PLATFORM =~ /(mswin|mingw)/
                            def self.status_bar_toggle()
                          else # Mac
                              puts('Windows only method "status_bar_toggle()" called.')
                          end #module
                            Dan Rathbun
                            key: ToolbarsUser-Bar***nn***
                            whose attribute: BarID (DWORD) = 0xe801 (59393 decimal)
                            [ My key happens to be "ToolbarsUser-Bar14" ]
                            and when hidden, also has an attribute:
                            Visible (DWORD) = 0x00
                            when shown this attribute is deleted.
                            EDIT: The registry attribute & value only gets updated when Sketchup closes, so cannot be used "live" to get the state of the user's statusbar.
                              Dan Rathbun
                              Sorry, forgot to note that. (Added a note to my previous post.)
                              Yep... Sketchup.read_default() still cannot read DWORD values (and also seems not to be able to read even string values in some of the OEM keys, which I never noticed happen in v7.)
                              I use Win32API calls to read entries (of all types) in the OEM keys. (Requires the Win32API.so file.)
