    Ruby Scripting Question - Defining Functions
    7 Posts 3 Posters 507 Views 3 Watching
      jrstoup
      I am trying to streamline my code by putting my function calls into a loop. So far, I have been unsuccessful. Anyone care to give me a clue as to why?
      #What I have
      UI.menu("PlugIns").add_item("Method 1") {method1}
      UI.menu("PlugIns").add_item("Method 2") {method2}
      UI.menu("PlugIns").add_item("Method 3") {method3}
      def method1
        derp = "derp1"
      def method2
        derp = "derp2"
      def method3
        derp = "derp3"
      The above code creates three menu items called "Method 1", "Method 2" and "Method 3". Those entries call the corresponding methods created below them. What I would like to do is put all of that into a loop so I can create as many entries and methods as I want. Here is my rough attempt at that:
      #What I want
      max = 3
      for n in 1..max
        switchStr = ""
        UI.menu("PlugIns").add_item("Method " + n.to_s) {
          switchStr = "method" + n.to_s
          eval switchStr
        def switchStr
          derp = "derp" + n.to_s
      Now, unfortunately the above code doesn't work. I am currently looking through the Ruby documentation to determine what exactly it is that I need (a proc perhaps?) however I thought I would take a shortcut and ask you. So, what am I doing wrong here? I feel like this should be simple and I'm just missing something. Thoughts?
        Why not make one method that takes arguments
        module James
        ###menu
        plugins=UI.menu("PlugIns")
        plugins.add_item("Some_Method 1"){self.some_method(1)}
        plugins.add_item("Some_Method 2"){self.some_method(2)}
        plugins.add_item("Some_Method 3"){self.some_method(3)}
        ### method[s]
        def self.some_method(arg=0)
          @derp="derp"+arg.to_s
          ### etc
          self.another_method() if arg > 0
        def self.another_method()
          UI.messagebox("You chose '"+@derp"' !")
        end#module
        Put your methods inside their own [your?] Module!
        Called as James.some_method(arg)
        The value of 'arg' can be any type of class - here it defaults to 0, and the .to_s assumes we want to convert it, whatever it is, into a string...
        Note, making derp into @derp will allow you to use it in other methods within the same module too !
          jrstoup
          I tried using your function and sadly, regards of which menu item I select ("Some_Method 1", "Some_Method 2" or "Some_Method 3") it always says "You chose 3". Any ideas why I am only getting the final index of the loop?
            Without seeing your exact code I don't know... πŸ˜•
            • Dan RathbunD
              Dan Rathbun
              The first line in TIG's example should read:
              module JStroup
              and the last:
              end #module
              He typo'd ("method" instead of "module". And I'd use a more unique module name than just "James", but TIG's intent is that you always have your code run inside your own unique "Author" namespace.)
              P.S.: This thread should be moved to the Developers forum.
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                @jrstoup said:
                I tried using your function and sadly, ... it always says "You chose 3". Any ideas why I am only getting the final index of the loop?
                It may work better if you pass the argument on to the another_method(), like:
                (Probably the cause is really the "module" typo as above.)
                require('sketchup.rb')
                module JStroup
                  ### method[s]
                    ### etc
                    self.another_method(arg) if arg > 0
                  def self.another_method(arg)
                    UI.messagebox("You chose '#{arg.to_s}' !")
                  ### load once block
                  unless file_loaded?(File.basename(__FILE__))
                    ### menu
                    ### reqister file as loaded
                    file_loaded(File.basename(__FILE__))
                end#module
                  Sorry about the typo !
                  I've corrected the original post 😳
                  [== a brain-fart - I must must type 'module' several times a day !]
