    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.2m Views 73 Watching
    • soloS Offline
      I'm getting this:
      Error; #<NoMethodError; undefined method `definition' for nil;NilClass>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `main'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;190
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `call'
      Nothing happens, no dialogue box.
      • TIGT Online
        @solo said:
        I'm getting this:
        The relevant code is this [ending line #103
                sel = model.selection
        		comp = []
        		$arc_labels = []
        		comp_height = []
        		sel.each do |e|
        		  comp << e if e.is_a? Sketchup;;ComponentInstance
        		  edges << e if e.is_a? Sketchup;;Edge
        		comp_height = comp[0].definition.bounds.depth
        So the error is saying that the selection [sel] doesn't contain a component-instance ?
        Since 'nil' has no 'definition'...
        It could be better trapped to stop if the selection contains no instances but...
        SO - question: does the selection contain a component-instance when you run the tool ??
          jorge2011
          hi sr Chris Fullmer.
          This plugin is generating the following error
          Error: #<NoMethodError: undefined method edges' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in curve_ordering'
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in times' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in curve_ordering'
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main'
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
          I use sketchup8 pro
          It is possible to fix?
          Thank you very much
          • Chris FullmerC Offline
            Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
              jorge2011
              that error can not play Mr. Chris, but the plugin works well in general.
              thanks
                ok, I hope it keeps working for you,
                  Lobster
                  Hi chris,
                  Great plugin, however i have this on a model.
                  Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in add_text' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in curve_labeler'
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:70:in curve_ordering' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:105:in main'
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:190
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `call'
                  Here is a link for it http://www.mediafire.com/?aesv4fd1ccv1cvn
                  It does not get to the reverse option. The plugin works fine on a simple box and a curve.
                  SU8, OSX 10.6.7
                  It seems to write 'start' but not 'end'.
                  I hope it is useful, if you have time to have a quick look.
                  Regards
                  Sam
                    raineysky
                    I am trying to make a chain like in the video in the first post. Must be doing something wrong because I'm getting what's in the picture below when I set the component rotation to 90°. Any advice? SU8 Free M2
                    Thank You
                      It all has to do with where the component axis is set. It looks like its oriented correctly, its just not centered right. Then once the chain is made, you need to edit the component and extend one end of it so that it overlaps into the other components, which I think I did in the video.
                      But first, spend some time figuring out how to center the component axis better.
                        raineysky
                        OK. Thank You very much Chris. I'll let you know how it turns out this weekend. Thanks again for your help and for the plugin.
                          raineysky
                          I did it!!! Centered the axis like in the picture below and it works like a charm. Thank You very much Chris for your help and for a wonderful plugin.
                            panpanndundu
                            Awesome tool, thank you chris fullmer ...
                            Component Stringer + Maxwell Render
                              thegoodguy
                              Brilliant plugin 😄 Just what I need. Thanks.
                              • I Offline
                                ivreich
                                Any chance there could be a "stretch" modifier (like the stretch tool in FredoScale) when stringing components? Although i guess this would destroy the component definitions.
                                joel
                                • kingsiK Offline
                                  kingsi
                                  Many thanks for the excellent pluggin
                                  Noobtastic
                                  • kingsiK Offline
                                    kingsi
                                    Wonderful plugin. Many Thanks Chris
                                    Noobtastic
                                      You're welcome and you're welcome!
                                        aaulestia
                                        Chris,
                                        I've been trying to use this amazing tool to place a Tree component along some streets, but can't them to be separated as I need them to be(distance between each component). Do you have any ideas to fix this? I would really appreciated it!
                                        Ana
                                          Cisne
                                          This is what happens when I select the line with the component and choose the uniform. When I choose the mode none, the plugin puts only one component at the beginning of the line.
                                          http://mail.mailbrturbo.brturbo.com.br/mail/?ui=2&ik=8dffb473f5&view=att&th=13da7e7bc7c744a6&attid=0.1&disp=safe&realattid=f_herdulfw0&zw
                                          • H Offline
                                            herrschnitzel
                                            Great Plugin I was searching for it.
                                            I moved the plugin in my plugins folder but I cant find it in sketchup.
                                            • 7 / 9
