    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 41.6k Views 16 Watching
      Jim
      @chyn2000 said:
      irb(main):002:0> require 'D:\suext'
      You did it again.
      Use:
      require "D:/suext"
      irb(main);001;0> require 'C;\SX_Basics'
      LoadError; 127; The specified procedure could not be found.   - Init_C;\SX_Basics
      C;\SX_Basics.so
              from C;\SX_Basics.so
              from (irb);1
      irb(main);002;0> require 'C;/SX_Basics'
      => true
      irb(main);003;0>
        Jim
        Ok, I just built TBD's suext example using Visual Studio Express 2010.
        In order to get the extension to require properly, I had to use:
        require "SUExt" <-- note case
        require "suext" failed.
          chyn2000
          Yep Jim. That was exactly it!
          Thanks everyone. Let me know if there is anything I can do to help.
          Actually, it occurs to me that we may want to start making a small library of math and geometry ruby extensions very targeted towards SU. Thoughts?
          -Chyn
            Not a bad idea. I had plans of doing some bezier functions.
              Jim
              Maybe wrapping up an existing library for SketchUp/Ruby would be a way to go? Here's some interesting ones:
              [1] http://vcg.sourceforge.net/index.php/Main_Page
              [2] http://www.cgal.org/
              [3] http://ptex.us/
              [4] http://code.google.com/p/ruby-sketchup-sdk/
              [5] http://www.visilibity.org/
                jefftrull
                I was so excited to discover that someone was building Sketchup extensions with Visual Studio 2010 - that's exactly what I need to do - unfortunately, after going through the whole process, I can't seem to successfully load the SX_HelloWorld module:
                require 'SX_HelloWorld'
                Error; #<LoadError; C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so; 126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so>
                (eval)
                (eval);0
                Notice this is not a situation where the file is missing - that produces a similar but different error message.
                After some Googling it seemed like missing .so's are sometimes the culprit, so I tried copying over some from my Ruby build directory (win32ole.so and Win32API.so), but it didn't help. Finally I tried running Sketchup from the VS2010 command line shell - this resulted in the infamous "bugsplat".
                I'm at my wit's end here... any ideas?
                Thanks,
                Jeff
                PS: My Ruby install gives RUBY_PLATFORM=i386-mswin32_100, RUBY_VERSION=1.8.6; Sketchup gives RUBY_PLATFORM=i386-mswin32 and the same version
                • Dan RathbunD Offline
                  Dan Rathbun
                  FYI: When require loads a shared object library file (and not a ruby script,)
                  the require(filepath) method looks for a C function named:
                  "Init_" + File.basename( filepath, File.extname(filepath) )
                  and runs it after loading the shared library.
                  This means that named C function must exist (even if it does nothing,) and must be named exactly as the file is named (CASE SENSITIVE.) If an enduser renames the so (or dll, dylib, etc.,) file later (including changing the case of any characters,) then loading the library file with require() will fail. (usually resulting in a "entry point not found" error.)
                  I'm not here much anymore.
                    jefftrull
                    Thanks for the quick response! Unfortunately, I don't think that's the issue, for three reasons:
                    1. The error message is "The specified module could not be found", rather than "entry point not found"
                    2. I'm using the example file from bitbucket unchanged... the name of the relevant function there is "Init_SX_HelloWorld", vs filename "SX_HelloWorld.so"
                    3. I can use this module OK in Ruby standalone (whichever one I built with)
                    I do think it's got to be something simple... I just can't see what it might be. The error message isn't terribly helpful 😞
                      Dan Rathbun
                      BTW your on Windows 7 ??
                      Is the path:
                      %(#BF0080)["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]
                      and what is the result of (at the console):
                      puts $LOAD_PATH
                        jefftrull
                        That's right, Windows 7 Professional SP1
                        Is the path:
                        %(#BF0080)["C:/Program Files(x86)/Google/Google SketchUp 8/Plugins/SX_HelloWorld.so"]
                        No, it's "C:/Program Files/Google/Google Sketchup 8/Plugins/SX_HelloWorld.so" (no "(x86)")
                        puts $LOAD_PATH
                        puts $LOAD_PATH
                        C;/Program Files/Google/Google SketchUp 8/Tools
                        nil
                          @jefftrull said:
                          1. I can use this module OK in Ruby standalone
                          Hm... it works in IRB, but not SketchUp?
                          Exactly what version of Ruby did you use to build the extension?
                          Also - did you remember to modify the config.h file as described in the README?
                            The error you report is mentioned in this article: http://apocryph.org/2007/06/16/totally_bullshit_ruby_extension_experience_windows/
                            However, I did not experience such error... not really sure what the difference is here...
                              Dan Rathbun
                              Is the path:
                              So (just to be clear:
                              1) You installed the 32bit version of Windows 7 ??
                              2) Are you running Sketchup with the Google supplied "msvcrt-ruby18.DLL" (which is v1.8.6-p287,) or did you replace the "msvcrt-ruby18.DLL" library file in the Sketchup program dir, with the one that you built ??
                                Dan Rathbun
                                .. and did you try: require('SX_HelloWorld.so')
                                (ie, specifying the extension, which should skip the search for a "SX_HelloWorld.rb" file.)
                                  jefftrull
                                  thomthom, thanks for your help. I've suddenly found a formula that works. The key thing is to use the Ruby built from the one-click installer you reference in the README http://rubyforge.org/frs/download.php/47082/ruby186-27_rc2.exe
                                  I hope it doesn't go away anytime soon (it's no longer listed on their index page) - I'm glad you had the direct link, because using either of the two Ruby builds I made from source (one VS2008, one VS2010) fails.
                                  To answer your questions:
                                  1. yes, it works in irb for all three Ruby builds without problems
                                  2. I did the config.h hack for the one-click version, but for the VS2008 and VS2010 I was able to compile the extension with the same version of VC++ I used to build Ruby itself, so it wasn't necessary... I think?
                                  3. All Ruby versions were 1.8.6-p287, chosen to match SketchUp
                                  4. The apocryph report relates to the need to embed a manifest into the .so file. Following that advice allowed me to compile under VS2008 - under VS2010 no manifest was produced (and its integration was apparently unnecessary)
                                    jefftrull
                                    Thanks again for considering this problem of mine, Dan. As you can see from my previous message, it's now working, but I'm still not sure what was wrong.
                                    Looks like it. "system properties" says "32-bit operating system"
                                    That's an interesting question. I haven't changed anything in the Sketchup program dir, beyond copying the SX_HelloWorld.so into Plugins. What is the significance of those msvcrt* files?
                                    Thanks,
                                    Jeff
                                      Ah, so you initially used a Ruby version you built yourself?
                                      I don't really know what makes the difference there. I just tried to find a minimum work solution - so I started out with a pre-built Ruby.
                                      @jefftrull said:
                                      1. I did the config.h hack for the one-click version, but for the VS2008 and VS2010 I was able to compile the extension with the same version of VC++ I used to build Ruby itself, so it wasn't necessary... I think?
                                      Dunno - you might not need it if you built Ruby yourself. The version you had might not have that check in it. With the pre-built version I used I had to remove that check otherwise it would not compile.
                                        Dan Rathbun
                                        It's THE Ruby interpreter that the Sketchup executable loads. (Copied from the pre-built v1.8.6-p287 binary package.)
                                        The one that your full Ruby install (ruby.exe and rubyw.exe,) loads is in the "bin" subdir of the full install folder heirarchy.
                                        see: Ruby Interpreter DLLs (Win32)
                                        and making sure you saw this link list: [Info] C/C++ Ruby extensions & SketchUp plugins
                                          jefftrull
                                          Thanks again for the helpful information, Dan. I gathered from the "Ruby Interpreter DLLs" link that you can replace the interpreter used by Sketchup with a different one; indeed that seemed to work, but it made no difference in my ability to load the .so file. Still works OK in irb (when the compiler versions match), fails in Sketchup. The good news is it doesn't really matter - I have a working recipe now. The one-click binary is the only thing that's worked for me over all the combinations, and with that, either VS2008 or VS2010 works fine.
                                          I'm off to turn this into a CMake recipe (this application is cross-platform); would anyone be interested in seeing that when it's done?
                                          Cheers,
                                          Jeff
                                            Dan Rathbun
                                            Be aware that Mac Sketchup still distro's with Ruby v1.8.5 initial release.
                                            • 4 / 9
