πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
The making of 2008 BMW E92 M3 GTR
61 Posts 20 Posters 8.5k Views 20 Watching
  • E Offline
    ely862me
    Hope it helps for making cars after blueprints.
    Elisei (sketchupper)
    Come and See EliseiDesign
    • H Offline
      hellnbak
      It's really nice of you to share your methods for making your incredible cars. There are too few people out there doing cars, maybe this will encourage a few more to take the plunge into (IMHO) the most rewarding field of 3D modeling.
      • I Offline
        irwanwr
        anyone knows where to get Isuzu NHR/NKR 55 series blueprint?
          Marian
          I have found no blueprints but I found a skp model of it πŸ˜„
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          • I Offline
            irwanwr
            πŸ˜† thank you Marian. but that's a box pickup model. i was planning to draw a minibus model. already working on it actually. though few friends and relatives have been asking me for visual for their house drafts.
            i've never thought to look for it in the warehouse πŸ˜† duh
              Marian
              πŸ˜›
              http://1.bp.blogspot.com/_B1sMZPmPA64/TTbianbWR1I/AAAAAAAAARQ/meJFmN7VJIo/s1600/Ambulance+Standar+NHR+55.jpg
              • I Offline
                irwanwr
                πŸ˜† yes, Marian. actually that company located on the other island of my country.
                and apparently you showed me one of 3 "blueprint"s that i have here. if you checked that "blueprint", it wasn't really a blueprint at all and not quite symmetric kind.
                i am working on this one though, if i have the time;
                sorry elisei and steve, didn't mean to get off topic πŸ˜›
                • H Offline
                  hellnbak
                  Not good enuf. You're fired, go home.
                  • I Offline
                    irwanwr
                    πŸ˜†
                    • E Offline
                      ely862me
                      Hey , no problem ! πŸ‘ I'll rehire you for one reason : finish that minibus,slam it to the floor add some wider/bigger wheels put a W12 engine and let's ride together in the Le Mans race .
                      Btw , there is no thing as perfect blueprint, so don't expect all the lines to match perfectly.All the blueprints i worked on so far were disaligned. At the beginning I was a bit upset, didn't knew how to handle it, and then I realised that there is no need for perfect alignment(although that makes the work harder). Just make sure you follow the overall lines and you will be ok . Nobody is going to compare the real scale model inch by inch with your model !
                      Also, most important search for as many as possible good pictures of the car you are modeling, because you won't be able to reproduce a real car just from some flat blueprints(which are often not accurate).
                      Some more work !
                      • E Offline
                        ely862me
                        And more work on this beast !
                        HINT: Don't forget to use XRay and parallel projection combined with each view to follow exactly the blueprint lines .
                        BTW : How it is possible to see the blueprints when i work inside a component or group? I am forced to work only outside groups or components because the blueprints are not in them . Is there a way so i can see them while are not inside the groups or components?
                        • E Offline
                          ely862me
                          Getting there !! πŸ˜‰
                          • I Offline
                            irwanwr
                            πŸ‘ wow, you should teach me how to have that kind of talent and patience working on that thing
                            • andybotA Offline
                              andybot
                              Nice work! coming along nicely πŸ˜„
                              Good question.. I'd love to see an answer. One possibility is to use photomatch - this is set up exactly for tracing images. It's tricky setting the view, but it's possible to do parallel projection I believe.
                                Marian
                                I already answered that one to Ely directly but I'll say it again so more people will know.
                                It is possible to keep pictures visible even while working in groups/componenets by just keeping the photo unexploded when you first import it. Of course doing this limits you to only being able to scale or move the pictures into place. So you'll have to precut the pictures and then import each one into SU.
                                • E Offline
                                  ely862me
                                  @irwanwr said:
                                  :thumb: wow, you should teach me how to have that kind of talent and patience working on that thing
                                  I don't know if that is something to be taught but something to be achieved in time .
                                  Thanks for that info Marian .
                                  Some more work on the bimmer !
                                  • E Offline
                                    ely862me
                                    Getting into details !
                                    • alvisA Offline
                                      alvis
                                      excellent knowledge, good and neat job πŸ‘ πŸ‘ πŸ‘
                                      • andybotA Offline
                                        andybot
                                        how are you doing the step in the second to last and third to last images? From SDS to a simpler mesh? Are you using a plugin?
                                        • E Offline
                                          ely862me
                                          Hey guys,thanks for the comments!
                                          I never let the parts subdivided, except when they are final, and even then I keep a copy of them unsubdivided .
                                          I subdivide the part to see how it looks and then I undo the entire operation of subdividing.
                                          I explained that better in my book : http://books.sketchucation.com/
                                          • 1 / 4
                                          1 / 4
