Licensed - Limit Exceeded / Free Version
I understand that with the new SU8M2 it is not possible to open the free version once the licensed limit is exceeded. Since it is only possible to have one SU file open at once (or?) this makes it very inconvenient to cut and paste from one model to another. Is this really no longer possible? Thanks for the help...
Hi GmChroma, hi folks.
When the 8 hours trial period is reached, SU Pro normally reverts to SU free.
If this doesn't work, delete SU and download the free version and install it again.
Whatever the way you have, you can always open as many instances as you want with SU, Pro or free. The number of instances depends on available memory and size of each model.
Just ideas.
not any more, when 'Pro Trial' ends it ends, you need to download and instal 'free' separately.
You may be able to have both at once on a PC, but I don't think so... it's very complicated on a mac...
Pro 'network licenses' limit the 'total number' of instances to the total 'number of seats', but 'individual' license or 'free' don't have that limit.
john -
Right - it seems that it's not possible to have the professional and free versions working side by side. I found this comment (here: http://www.google.com/support/forum/p/sketchup/thread?tid=23077b23e79c7266&hl=en ) posted by a google employee:
"The Free installer will overwrite any Pro installs that you have– it isn't possible to install both Free and Pro side-by-side on the same system. We have implemented a new system to support offline use of network licenses (which I think you'll like) but you'll need to add to your network license if you've got more users than your current license allows."
This strikes me as a significant problem. For example, if I want to inspect or edit a component before loading it into my primary model, I need to close down. If the model is large and takes a while to load, this can become a huge time sink. Will folks really need extra licenses to do this?
I would be grateful for any workarounds. Thanks!
I regularly have three and sometimes four sessions of SketchUp 8 pro going on my machine at the same time. And having the pro version I've never seen a need to even download the free version.
Thanks, Dave R -- now I follow Driven's distinction about the limit on network licenses (which I should have said applies in my case)
But this still seems to be a problematic change for SU8 M2 because previously unlicensed versions would automatically open when the network limit was exceeded.
Ah, yes. I didn't realize you were talking about a network license.
I understand that 'SU sales team' has some sort of provision planned for education and corporates, so email them... john
I took Driven's advice and reached the SU folks. They confirmed the direction of this thread:
"As you may know, network licenses of SketchUp Pro no longer revert to the free version when you have exceeded the use of your allotted amount of network seats.
Each situation is different and there are always different ways of satisfying each individual need.
You have the option of adding additional network seats which would give you more room -- as well as more users -- to operate on your existing network.
You may also be interested in converted your two-seat network license into two individual licenses; individual licenses allow you to run multiple instances of SketchUp Pro on the same machine without receiving the error message you're receiving now."
