    Color schemer
    15 Posts 8 Posters 1.5k Views 8 Watching
    • T
      tspco
      Time for me to bug you plugin gurus again, I am color scheme challenged, I can't tell what color goes with what color. I use a freeware program that will give me 6 colors,from a sample that supposedly go together. More options would be nice. I cannot use this in a sketchup model because of the shading and textures, so I take my sample from the materials pallette swatch.
      Anybody have any ideas how to make this work?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        Jim
        I attempted one using colr.org - an OK but not great color site. Could probably be done better using kuler.adobe.com
        Error 404 (Not Found)!!1
        (sketchuptips.blogspot.com)
          Have you tried this?
          • T
            tspco
            On Kuler right now, looks promising.
            • T
              tspco
              OK I made a color scheme on Kuler, downloaded the ase file, (I don't have a program to open an ase file, not buying PhotoShop). There are some scripts that reportedly work with gimp, but there is a lot of things to make it work, for conversion from ase to gpl. Download python 2.5, run this download this, etc,etc. There was one app that looked good, complete and ready to run. Opened it and imported an ase file, it crashed, twice, deleted it. Back to square 1, do I used my color picker (jcpicker)on kuler. Picked all 5 colors, wrote down the rgb for all five, opened SU painted my model, great. But there has to be a better way to do this.
                Well, how often do you need to do this? Here's an option that really doesn't take long.
                I made a screen grab of the color set on Kuler
                Import it into SU as an image. Explode it. Draw quick rectangles over the color patches. size isn't critical. Right click on each rectangle and choose Make Unique Texture. The colors will be created as material patches in the In Model Materials library.
                Color Swatch.skp
                • T
                  tspco
                  Never thought of that approach Dave, I will have a go at it, sometimes all we need is another angle to consider, thanks
                  • BoxB
                    Once you have brought your colour chart into SU you can always just use the tool in material edit called "Match Colour on Screen" or simply use the Alt key with the Paint Bucket to sample the colours you want.
                      If you use that method you don't even have to import the image of the colors into SketchUp. You can just sample from the web page.
                        andre51
                        Hi, try the site below - I think this is the best 'color schemer'
                        http://genopal.com/
                          There is Jim's plugin:
                          http://forums.sketchucation.com/download/file.php?id=39046
                          404 Not Found
                          (forums.sketchucation.com)
                          • T
                            tspco
                            I tried Jim's plugin I kept getting script errors, never did work quite like I thought it would, and yes I was online, but using IE9.
                            • gillesG
                              gilles
                              For Mac user as I know:
                              • T
                                tspco
                                Looks good but alas I am a PC
                                • cottyC
                                  cotty
                                  This is a nice and helpful website too: http://www.colorexplorer.com/
                                  my SketchUp gallery
