    Have a line, need a curve
    10 Posts 6 Posters 282 Views 6 Watching
      richardtallent
      I'm trying to model this freestanding soaker tub:
      http://home.tallent.us/postedfiles/Melissa-Photo.jpg
      So far, this is where I am:
      http://home.tallent.us/postedfiles/Melissa-CAD.png
      The bow and stern of the actual tub are curved, but my model just has straight lines between the top and bottom curve vertices.
      How can I deform these surfaces to more closely resemble the actual tub? I contacted Modern Bathrooms (the distributor) and they sent me a PDF spec sheet but of course have no CAD files available. Here it is if it is more clear than the photo.
      • ely862meE Offline
        ely862me
        Try to use follow me with a curved profile.
        Make it at first symmetric and after that use Fredo Scale to scale it from top .
        Hope it helps!
        Elisei (sketchupper)
        Come and See EliseiDesign
        • mitcorbM Offline
          mitcorb
          I noticed the pdf gives dimensions, but not enough dimensions, I believe. Of course you could do an image trace on screen to get the model going, but you cannot simply transcribe all of the dimensions. So, as ely862me says, that may be the best way.
          EDIT: Oh, and you will most likely need to scale up the whole business for modeling so you don't encounter the tiny faces issue.
          • mitcorbM Offline
            mitcorb
            I thought I would mount that pdf and attempt to trace it. I tried to scale it to the 48 1/2". Of course, the 36 1/4" dim had no relation to that one, nor any of the other ones. The whole page is intentionally distorted. I also tried to map it out and do fillets. You will not be able to locate the arc endpoints exactly.
              driven
              I'd work in metric as it's a european design.. set a drawing to meters and scale it back [by 1000] when finished.
              It will auto convert on import to an imperial unit drawing.
              from the site
              • gillesG Offline
                gilles
                You could use TIG's Extrude edges by edges:
                draw profiles
                apply EEbE
                • mitcorbM Offline
                  mitcorb
                  Hi, gilles:
                  Very well done.
                  • gillesG Offline
                    gilles
                    thanks TIG.
                    • mitcorbM Offline
                      mitcorb
                      Yes, thanks TIG 👍
                      • irwanwrI Offline
                        irwanwr
                        😄 another one wizard's plugin i've just learnt 👍
