    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 31.9k Views 25 Watching
    • jason_marantoJ Offline
      jason_maranto
      @solo said:
      :mrgreen: πŸ˜•
      I'm guessing he put that hole in the wall for that exact reason to stress out an unbiased engine.... almost cruel.
      Maybe he did at that -- pretty sadistic indeed πŸ‘Ώ
      Best,
      Jason.
      • majidM Offline
        majid
        @jason_maranto said:
        @solo said:
        :mrgreen: πŸ˜•
        Best,
        Jason.
        not for sure mate, solo is right. also I was using the free version, and am not on testing a "real model" as if Maxwell is modeled to mimic the real world , so it most be also capable for a bit larger or smaller objects "that are possible in real world".
        twilight and v-ray also were good on this scene... no something special, but just a simple scene.......
        I was not aware of "roughness on emitter materials and was thinking completely at the other side!!! (imagined that it must be like a light bulb, and so, must be glossy...., as real world πŸ˜‰ ). also about the lights... I've modeled it based on one of maxwell manual scenes.
        at the other hand , Thea also supports more light types... that are really handy while I am not familliar with maxwell lights ( I just have experienced Mx r1.7)
          jason_maranto
          To be clear my point is that Maxwell is optimized to render scenes with realistic proportions and details in the geometry, the higher-poly the better...
          A test like this proves very little because nobody who is using Maxwell as it is intended to be used is actually going to ever need a scene like this.
          Basically all you are saying to me with this test scene is "Maxwell sucks at the pure CG look" -- which I already know, it's not meant for that.
          The question of speed is somewhat redundant because of course any biased engine is going to outperform unbiased engines in speed as a rule... and fully unbiased engines should generally vary in render time very little assuming they are using the same hardware resources and using similar features.
          And finally it has been said in just about every way conceivable that the draft engine (which is all that is available in the free plugin) is not suitable for complex lighting... it can be used but do not expect great results fast using more than 1 - 2 lightsources.
          The free plugin will do a very nice job on exterior arch-viz shots and IBL lit advertising-type product shots, but arch-viz interiors (with emitters) will be somewhat of a stretch using the free plugin.
          But at the end of all this, to be completely fair, if you are going to compare the interior results from other engines you need to use the production engine -- at $95 it is still cheaper than Twilight... and this way you would be comparing apples to apples.
          Best,
          Jason.
          • majidM Offline
            majid
            a bit off topic,
            let me ask , wich is the best setting to prepare a light model using maxwell, and does it offers ,point , or spot light or we must model them?
            also I like the simple interface of su plugin while it has almost everything needed.
            twilight is really handy but it's interface is not still friendly (maybe we must be patient for next version that seems has some interesting new features (like toon shader πŸ˜‰ ).
            as I mentioned befor, fry is a nice render engine and also so powerful that hasn't been such popular as i.e. v-ray....
              jason_maranto
              Right now the options are to use an emitter material or an HDR emitter material.
              The emitter material allows you to set the light power parameters the same as a real light fixture -- so you would want to apply the material to the same surface area as a real light to achieve the most realistic results. Keep the material roughness at 100% unless you are planning on showing it as turned "off" in another render and need the "glass" look.
              The HDR emitters are bit more flexible IMO and I would tend to use them for any complex light effects (computer monitors, TV's, fireplace, etc.) -- basically any 32-bit image will do.
              Coming soon are IES lights which are already supported by the engine but are not available as an embedded type in the current stand-alone plugin release... this would be the best choice for light fixtures, especially if the light source will not be seen "on camera".
              Point or spot lights do not exist in Maxwell because they are considered Biased approaches to lighting -- so IES would be the alternative, which is why I am excited to see they are coming.
              I've been helping alot of new users lately and the most common issue I am seeing is the geometry they are using is not Maxwell-ready... Maxwell really will only give as good of results as the geometry you feed to it. Generally any shortcuts taken in the modeling will yield poorer results with Maxwell -- it wants the model to be as the real thing. Emitters are not excluded from this -- for instance if you want to do a flame you can use a regular emitter material but you would need to model the flame to scale with details (probably with artisan or similar).
              At one point in time I was better versed in the various rendering packages, and I really enjoyed comparing (which is why I try to read whenever something is posted about other engines and participate in the "render this" threads when I can) -- but these days I have my hands full trying to stay on top of all the software packages I already use, so I'm not personally testing other engines.
              There are a number of really tremendous unbiased engines -- I'm not so crazy about the biased engines in general, but with good post processing skills almost any engine can produce usable to excellent results these days.
              Best,
              Jason.
              • andybotA Offline
                andybot
                Jason,
                I'm curious, I don't know if you've posted about this elsewhere, what do you see as the major disadvantage of biased renders? Kinda leading I know, but you keep putting down biased renders, so I'd be interested to hear why. If you've already written extensively about it, can you point me there.
                Andy
                  jason_maranto
                  Nope I tend to avoid the subject since I'm far from an expert -- I already have 2 biased renderers myself, but I prefer Maxwell by far and use it almost exclusively when I have a choice.
                  It's really as simple as the quality of light for me -- I just think unbiased renders generally look better (more realistic) out of the box... but the thing that aggravates me about the biased approach in general is the arcane terminology that is used so often for many parameters (this is present in some unbiased engines as well). Probably the thing that appealed to me most about Maxwell was the simplicity and relate-ability of the parameters and the quality of light.
                  It's really the same thing that appealed to me about SketchUp -- I'm not a big fan of the typical "CG speak"...
                  Best,
                  Jason.
                  • andybotA Offline
                    andybot
                    Thanks Jason. I suppose I'll just have to see for myself when I have a chance to play with it and compare some scenes. This has been a helpful thread to get a general idea of where the strengths are of Maxwell.
                    • majidM Offline
                      majid
                      off topic but maybe interesting: motiva colimo+ Thea render is almost a miracle, has anyone tested it? (Thea as a hybrid engine and motiva as a time saver!!)
                      I also like the relight system of Thea:1-relight.jpg
                      fymoro models are good for almost every render engine (maybe not good for hypershot that has a weak interior render result)
                      • arail1A Offline
                        arail1
                        I also like the relight system of Thea:[attachment=0:ofhpbqth]<!-- ia0 -->1-relight.jpg<!-- ia0 -->[/attachment:ofhpbqth]
                        I'm curious about this. I couldn't find a page to download a demo from motiva colimo but I'd like to try it out.
                        Maybe you could post some more thoughts, insights about it's usefulness?
                        Edit: I just found the demo download link.
                        • majidM Offline
                          majid
                          I tried again the free maxwell plugin version, still too noisy for interior. I got a reasonable result out of twilight with biased 0unbiased settings...on my old crappy machine
                            jason_maranto
                            Hardly surprising since I just spent pages of posts telling you that it will not work -- and why, and what the solution is (pay the $95).
                            • irwanwrI Offline
                              irwanwr
                              ... and why, and what the solution is (pay the $95).
                              that seems quite obvious πŸ˜›
                              • majidM Offline
                                majid
                                @majid said:
                                I tried again the free maxwell plugin version, still too noisy for interior. I got a reasonable result out of twilight with biased , unbiased settings...on my old crappy machine
                                I see I see, I am comparing both demo versions of maxwell and twilight(IMO twilight has a good demo, fully functioning, biased + unbiased engine, more light options..., with a watermark and size limitation, while maxwell has no watermark, but not good quality, etc...)99$- 95$
                                  jason_maranto
                                  There is no watermark because it is not a demo -- there is no demo for Maxwell except for the full Maxwell Render Suite. It is a fully functioning render engine unlimited in both time of use and of watermark and very capable of producing excellent (and relatively fast) results for what it designed to do... all for free.
                                  However it was not made to do what you are trying to do. which is stated clearly on their webpage and I have said over and over again on these forums -- but the good news in not everybody needs to do what you are trying to do... for those users it may be a perfectly usable piece of free software.
                                  I get the sense you are trying to prove a point, but what you seem to fail to grasp is that it is not a comparable software -- it was never designed to be. The Twilight demo (and all other demos) are demoing the full software -- this is only a small subset of Maxwells capabilities.
                                  The $95 version of the Stand-alone plugin is more comparable in quality for the types of renders you want to produce, but it too is simply a subset of the full Maxwell Render Suite.
                                  If you cannot understand it's designed function then you cannot prove it fails -- your conception of what it should do is totally flawed. I've proved elsewhere on these forums that the free version of the stand-alone plugin can render exterior (daylight or IBL envirnments) shots with extremely large and detailed geometry to a very high quality level very rapidly (see below for an example).
                                  One of the Eye Candy (from silver_shadow) models rendered with IBL environment to SL 12 which took 4 minutes.
                                  Best,
                                  Jason.
                                    sonder
                                    The best and most straight forward free ware I have tried has been Kerkythea without exception. I was rendering within a couple hours of playing around - that was without using any tutorials or watching any videos. The output and ease of use with sketchup is amazing. I have just started looking into Thea which looks incredible. I will be ordering that as soon as I get back in my office early next week. My hats off to the developers of both those programs.
                                      And probably not incidentally, that's basically the same person.
                                        sonder
                                        Excellent! I guess my transition should be that much easier.
                                        • irwanwrI Offline
                                          irwanwr
                                          in my opinion too. KT is the best freeware available ever there for rendering.
                                          i spent less than 48 hours from learning both SketchUp and Kerkythea to send 3 models rendered to a friend. who ask for a favour to give an idea for a quite small building to develop.
                                          back then there was only SketchUp 6 available to download and learn πŸ˜„
                                          here's one of them that still left
                                          [attachment=0:2d336y5i]<!-- ia0 -->3 x 11 C lights.jpg<!-- ia0 -->[/attachment:2d336y5i]
                                          if there's any other 3D modelling and a render application that would allow you to download-learn-modelling-render and send 3 models in less than 48 hours, please let me know (not to mention they are the freeware ones). i might give it a thought to try them πŸ˜›
                                          • andybotA Offline
                                            andybot
                                            Well, I finally had a chance to try the Maxwell free plugin. I like it! The user interface is great, and I like the preset material types. The adjustments that I want to make are all there - environment settings, material reflections, etc. In a few tests, it is actually not as slow as I feared compared to vray. I did try some interior daylit scenes, and while the speed is not too far off, the output quality is significantly more noisy with Maxwell. Overall, I like the lighting quality better than twilight, but I didn't see a whole lot of difference compared to vray. Of course, with vray, it is much more complicated to control material qualities, so it would be more difficult for a newbie to use out of the box.
                                            In any case, it was nice to try, and I can certainly recommend it to those looking. For me though, Maxwell doesn't appear to offer anything that I can't get with vray.
                                            • 3 / 7
