    BIM for SketchUp - again?
    51 Posts 14 Posters 13.4k Views 14 Watching
    • bigstickB Offline
      bigstick
      I think the 'thick faces' approach sounds great!
      There are a number of ways you could create them though. Tools which specifically create the wall and slab objects would automatically set up the relevant tags/labels sound to me to be the most efficient solution.
      However - ultimately there may be more complex wall types to build though. Angled, curved, stepped, tapering walls are all not that unusual. It may be that the 'thick faces' approach won't quite work with stepped, angled or tapering walls. If you could maybe allow each wall to be created in native SU geometry, and made into a group and tagged with an attribute, it gives you the benefit of modelling however you want, with flexibility to do pretty much what you want.
      If you extended the attribute tagging principle and defined an open schema, any of the plugin authors here could build an integrated set of tools for all sorts of BIM elements, based on some of the plugins that they already have. A true community approach!
      Someone would need to create an IFC export script though.
      I have just checked out bimserver, sounds great! Would it work with large/complex models?
      • brewskyB Offline
        brewsky
        You are right, for new geometry a button "create wall" would be best, that could create the geometry AND add the labels. But the reason I think the approach of selecting faces would also be great is with complex shapes and for upgrading an existing design to BIM. Check the example image(made with my demo plugin, still need to solve corners)geometry.jpg
        I would like that very much! Some opinions from other plugin developers or IFC experts would come in handy!
        I'm also working on that, the previous version of my plugin DOES IFC export, but it only makes walls and windows.
        For the future version I would like to work together with http://ifcopenshell.org/, if that works we don't have to build the full IFC framework in sketchup/ruby but just the translation to SketchUp! And even better, all contributions to that project would also be usable in blender and the like!
        bimserver.org is a great project! I think it does work on large models because the principle is simple, as far as I understand it.
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
          To make separate 'solid' 3d sides look at the shell tools by Jim and Thomthom [also Fredo's JointPP].
          You'll get the two 'shells'.
          Then you find all of the vertices of one and find the nearest corresponding vertex of the other Draw edges between them and add faces to the internal partitions.
          [JointPP can do this for you with appropriate settings].
          Then separate out each pair of faces and their edges as '3d facet - distorted cuboids' - each in their own groups/instances...
          Erase the original geometry.
          • brewskyB Offline
            brewsky
            Thanks! I'll check them out.
            The way I'm building it right now(even the parts in the image are no push-pulls)is:
            Get the plane of the "base"-face, offset this to bottom and top, calculate a perpendicular plane for every edge(and I need to improve this to "half the angle" between this and the connecting face). Then intersect the planes and create vertices(and faces) on the intersection points. That way I think I can generate the entire geometry in one go.
            What do you think? (I hope my ramblings make sense πŸ˜„ )
              JointPushPull copes with adding thickness to a 'shell'. It can also copes with adding internal partitions ['sides'].
              You just need a way to extract the 'parts'...
              Good luck πŸ˜‰
                Pout
                brewsky and others
                Based on your comments, there are two possible pathways:
                BIM as in: be able to attach BIM properties and parameters to an entity. That's it, these parameters do not influence the entity when changed.
                BIM as in: when changing IFC parameters/properties teh entity is changed accordingly, even more, when adjectent entities are influenced they also change if needed (bit like Revit)
                As you can see, the first option is easy, but what is the added value?
                brewsky, can you pm me your contact info, I'm located in Belgium, maybe we can have a chat.
                • brewskyB Offline
                  brewsky
                  I agree, the more information you've got, the more usable it becomes...
                  This goes for every bim-plugin, but also for a basic common framework...
                  But even if you just have 4 labels; "width=100", "length=6000", "height=3000", ifctype="IfcWallStandardcase" AND the default sketchup information of a group/component; "placement point" and "placement vector", can tell you a whole lot about the wall!
                  The more "standard definitions" we as plugin builders can agree on, the better it gets. You could even agree on a basic Sketchup::Ifc module that contains a few classes for maybe ifc-export/import, generating globally unique id's(guid) and managing ifc-units...
                  • bigstickB Offline
                    bigstick
                    The added value of the first approach, is that SU can be integrated into an existing (or new) BIM workflow.
                    So users can use SU in conjunction with Revit, Microstation, Archicad, Vectorworks etc.
                      On the question of 'GUID'... like
                      af8f4bfc-2604-43ec-acf1-489b153db0d6
                      To make a unique GUIDs I'd use a method that does something like this:
                      def new_guid()
                        guid=''
                        (0..35).to_a.map{|a|
                          rand(16).to_s(16)
                        }.each_with_index{|e,i|
                            e='-' if[8,13,18,23].include?(i)
                            guid << e
                        return guid
                      The reference you get from guid=new_guid() is now a unique GUID following recognized standards for any GUID...
                      You should never get two the same!
                      • brewskyB Offline
                        brewsky
                        That sounds great! When i saw the guid guidelines for IFC it looked like a difficult thing to get to work on both Mac and PC... There seems to be some kind of standard, made by "open group"?
                        http://buildingsmart-tech.org/implementation/get-started/ifc-guid
                        http://buildingsmart-tech.org/ifc/IFC2x4/alpha/html/ifcutilityresource/lexical/ifcgloballyuniqueid.htm
                        But if your method is equally random(and i don't really see the difference between one random string of characters and another) it should not be a high priority task to try and make an "official" guid...
                          My GUID example was a general one [as required for Revit .addin files etc] - a typical type of 'Standard' [DWF] GUID.
                          DWF GUID = 60f91daf-3dd7-4283-a86d-24137b720ed1
                          IFC GUID = 1W_HslFTT2WwXj91DxSWxH
                          The IFC GUID is 'identical' to the DWF GUID in Revit.
                          It is simply encoded in a different format to create a shorter text representation to save a few bytes in a text-based IFC file.
                          The simplest way of making a random compliant IFC GUID text string is this:
                          guid='';22.times{|i|guid<<'0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz_$'[rand(64)]}
                          giving you id's like
                          puts guid >>> O8lUvCXkuWi1_9ntMidtBk
                          or perhaps
                          Y25qn6yMgfCFj9yD$nPhgY 7FBtUWbd28V7Xn3D_20fCm _Rjg3mwn1Ev_PHtYfByEQh
                          etc
                          Note also how IFC uses _$ and not the expected +/ Base64 standard as the last two possible 'numerals'...
                          You can invent a way of translating between the two... BUT I can't see why you need to [at this stage] if the IFC format is the intended medium used to swap data - use the same code for both the SKP guid's and the IFC ones ? Comparing 'strings' is slower in Ruby than numbers, so converting a number SKP guid to an IFC one might be preferable ?
                          So convert the 16 digit integer [perhaps made from ((rand+Time.now.to_f)*1000000).to_i ?] [Bignum] SKP guid to a string, then an array, then pack it using 'm' to make it base64 [string], adjust non-compliant characters in it to suit IFC _$.
                          (eval):155
                          ` ifcguid=2223334441110009.to_s.to_a.pack('m')[0..21].gsub(/[^0-9A-Za-z]/,'_')
                          MjIyMzMzNDQ0MTExMDAwOQIn the other direction reverse adjust the IFC base64 string and then unpack that string again as 'm' back into an integer [Bignum]... skpguid='MjIyMzMzNDQ0MTExMDAwOQ'.unpack('m')[0].unpack('q*')[0].to_s[0..15].to_i
                          3761687883756483` finally adjusting it back to 16 didigts...
                          Or something along these lines ?
                          πŸ€“
                            d_e_x
                            This goes for every bim-plugin, but also for a basic common framework...But even if you just have 4 labels; "width=100", "length=6000", "height=3000", ifctype="IfcWallStandardcase" AND the default sketchup information of a group/component; "placement point" and "placement vector", can tell you a whole lot about the wall! The more "standard definitions" we as plugin builders can agree on, the better it gets. You could even agree on a basic Sketchup::Ifc module that contains a few classes for maybe ifc-export/import, generating globally unique id's(guid) and managing ifc-units...
                            @bigstick said:
                            The added value of the first approach, is that SU can be integrated into an existing (or new) BIM workflow. So users can use SU in conjunction with Revit, Microstation, Archicad, Vectorworks etc.
                            1. The solution is to associate "parametric modeling" with the "generic 3D modeling" offered in SketchUp. And then, maintaining a "behind-the-scene" analytical model with SketchUp's graphical model. In this case, the "parameters" associated with the SketchUp entities can be stored internally with the entity. When you change the entity, these parameters are adjusted automatically using entity observers etc. and visa-versa, the graphical output is adjusted if these parameters are changed.
                            2. Then, when you import/export IFC data into the SketchUp model, you can simply modify these internal parameters, hidden inside the SketchUp entities; which will consequently and automatically change the graphical model in SketchUp.
                            3. To me, changing adjacent entities is the next natural step in the development cycle. It is an enhancement to the above work-flow; but first, (1) and (2) need to be bolted in solid!
                            Dex
                            http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
                            • bigstickB Offline
                              bigstick
                              The problem with parametric modelling is that you are adding another layer of complexity, which may never have been part of the original plan. The big drawback to it, is that implementing complex features such as curved, tapered or sloping walls becomes almost impossible unless you create typologies for them, together with mechanisms to connect them. It's worth remembering that even Revit didn't have these things in the first couple of versions!
                              In addition, let's say you have even a simple shape as a rectangular room with a curved bay, it's easy to model the slab and ceiling, but making these both parametric and associative with the adjacent elements is a really huge undertaking. Much, much bigger than simply tagging geometry or building some tools to create appropriately tagged geometry.
                              There are so many examples of this kind of complexity (floors with holes for staircases are another example) that it is easy to see how the project could get bogged down with making a very complex plugin that can deal with associative geometry, but can only deal with the very simplest of building types! In that respect, it could have very little usability in real world situations. When I played around with version 2 of Revit, before Autodesk bought it out, I found that this was the case for me.
                              One could deal with some things (partition walls, doors, windows, arrays of joists and framing) with dynamic components, but other elements could be created by plugins, and others built from scratch and tagged. It seems to me to make sense to have more than one way to make geometry, for flexibility.
                              • brewskyB Offline
                                brewsky
                                Hi everyone,
                                I have made a small video that shows the current progress on my bim-tools plugin.
                                It shows basic ability to create "thick-faces"(filled with the needed BIM-data) from an existing SketchUp model.
                                http://youtu.be/ozci5OH8Rj0
                                I think the plugin now has a solid and extendable data-model, ready for the next steps!
                                A lot of work needs to be done but I would like some comments on things like:
                                • would anyone like to work in this way(draw a model as flat faces(shell) and when a design becomes somewhat "real", select faces that need to be converted to (exportable) BIM objects.
                                • do you think this is a good approach to BIM-modelling? The method differs somewhat from revit and the like
                                • can it be done this way? A lot of difficulties lie ahead(solving corners, conversion to IFC)
                                Please comment!
                                Cheers!
                                Jan
                                http://forums.sketchucation.com/viewtopic.php?t=34007
                                P.S. made the video on ubuntu Linux!
                                • pbacotP Offline
                                  @brewsky said:
                                  Hi everyone,
                                  Hi Brewsky,
                                  I don't understand exactly what the video is doing and its relation to BIM DATA, but I like the quick manipulation of shells that is apparent. I think the above statement is most impressive. Is the object a solid. or is the model just "solid", and what is the link to data? Are walls identifiable for further description or something like that?
                                  Great work! Thank you!
                                  Peter
                                  • brewskyB Offline
                                    brewsky
                                    Hi Peter,
                                    You are right, the video needs some clarification.
                                    The video shows the first visual part of the re-builded plugin: converting SketchUp faces to builing elements. What's still missing is an interface, and a way to show the created building data.
                                    The basic idea is to use pre-drawn sketchup elements(faces/edges) as source for the building elements. Apart from the source-face, a group holding the complete wall-geometry is created.
                                    These are linked through a new building-element-class. The source face remains the basis, and holds all attribute data. This way the geometry can always be re-created from the source.
                                    I have created a set of new classes parallel to the common sketchup elements, among others:
                                    • A project-class, that manages a separate library of building elements, and will take care of things like IFC-export.
                                    • A planar-class(for walls/floors/roofs, might be needed to add separate classes), linked to the source face and the created wall-geometry. And contains all object data, like width, height, material-properties.
                                    • A lineair-class(for columns and other profiles), linked to a source edge and the created geometry.
                                    Cheers,
                                    Jan
                                    • fionmacoolF Offline
                                      fionmacool
                                      The big benefits of SketchUp are its ease of use, affordability, massive user base and thriving community of developers.
                                      • Amen to that!
                                      @fionmacool - There doesn't seem to be a lot on your site right now. Are you familiar with Secom's IFC2SKP (http://www.ohyeahcad.com/ifc2skp/index.php) plugin?
                                      • Yes I forgot about that one- I have included it now thanks. In relation to the amount of content- I don't have a lot of time to put into it, but the site is just meant to be a means of directing people towards content.
                                      I'm a bit intrigued as to why you had such a negative reaction to what sound to me like very useful ideas. I'm reminded of the famous quote by Henry Ford, "If I had asked people what they wanted, they would have said faster horses."
                                      • I am reminded almost every time I mention something interesting that there are vast numbers of people who don't want interesting things to happen.
                                      @mitcorb - I think you have made some very valid points about the formalized input in Revit. It concerns me that the inflexibility of the tools might get in the way of elegant design. I do think SketchUp needs to evolve in terms of its geometry handling because working with large models can be painful, but I don't think any SU BIM solution need be anywhere near as complex as Revit. As far as I have seen, Autodesk buy applications that threaten their business model, then screw them up in an attempt to integrate and rationalise functionality with their existing products.
                                      • The business model of high cost software cannot survive. Unless legislation like #SOPA, #PIPA, or #ACTA get enacted and destroy the internet.
                                      Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                      • bigstickB Offline
                                        bigstick
                                        Try telling any of the major CAD/BIM vendors that! Despite the whole argument surrounding legality, it's often easier to get pirated software than legitimate stuff. I once ordered an AutoCAD upgrade that took 2 weeks to get an authorisation code for. I could have downloaded a pirate copy and installed it within a couple of hours!
                                        I'm not an apologist for software piracy by any means, but for some companies it actually enhances their market presence. I accept that this is an a controversial thing to say, but if you look at Photoshop, and the cost, and the number of users around the world, the fact that is is the market leader I suspect is down to piracy. Not many people can afford to pay for the full application, yet a disproportionately larger proportion have used it extensively.
                                        So - even in the content of internet piracy or 'copymism' (Google it) these companies still make a lot of money. I'm not advocating software theft (the term 'piracy' is a romanticised euphemism for theft) for a second, just highlighting how considering how prevalent it is, it won't kill high cost software any time soon.
                                        Sorry about that the original response just quoting your previous post! I must have had a timeout (our web access in the office is, let's call it 'variable') which meant that my actual reply didn't get posted when I resubmitted the page.
                                        • aadbuildA Offline
                                          aadbuild
                                          Large comercial drawing jobs require IFC... I say: Sketchup can handle residential work and all of the BIM information required.
                                          I have just finished a BIM seminar in Australia. To be honest I have not had a lot to do with IFC as I have always used Skethup to do my residential quantifying and scheduling (no need to export). I do see clear advantages in having an IFC exporter from Sketchup for IFC compatible programs and I would like to help with input. As far as parametric models go for BIM I have not heard that they were used in any package. I have exported IFC (parametric models) from Archicad and imported them into Revit with no success. A static model works fine but there is a lot more to consider when it comes to this type of information exchange... especially file size.
                                          Sure most who post on this topic have a handle on how to draw and attribute BIM models on the technical side but none of us know how it should be implemented in a cross platform international standard. It seams to me that this should be the priority.
                                          Sketchup is a simple and cost effective way for everyone to take advantage of what BIM has to offer for the: design, quantifying, building and maintenance industries. BIM should not be designed for people with a university degree to use, BIM should be designed for 95% of the population to use and benefit from.
                                          I agree we do need IFC export for software compatibility but I dont see why Sketchup can not be used as a stand alone, affordable complete BIM package.....? One thing that becamme clear at the seminar for BIM was that the current software that is available is some what expensive but the real costs came in when the contractor had to employ someone to use it. 😠
                                          I am actively committed to BIM for Sketchup yet I post very little. I like to build add ons, try them in real life and then rectify until I think I have it correct (a very slow process as a home can take me weeks to design & 6 months to build and there are hundreds of possible senarios). Once I am done (soon) I look forward to have you all comment on my work.
                                          I don't get a chance to check my PMs often so post comments here for all of us to see. I do have a gmail account that you can contact me on.... aadbuildATgmail.com
                                          I am glad to see that BIM is being considered and talked about for Sketchup and I hope one day it is a viable option for all.
                                          sorry 😳 for my spelling and grammar, I left school early πŸ˜• .
                                          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                          https://www.plusspec.com
                                          • utilerU Offline
                                            utiler
                                            Sounds interesting Andrew, I'm keen to see how things unfold! I'll gmail you.... πŸ‘
                                            Just Curious...
                                            • 2 / 3
