    [Plugin] ComponentReporter++ v1.2
    71 Posts 22 Posters 73.9k Views 22 Watching
      Here's a version that might do what you want or be adapted easily...TIG-exportDCs2csv.rb(c) TIG 2011
      Script:
      Type:
      TIG.exportDCs2csv
      in the Ruby Console to run it.
      Exports all DCs is the model with a Name,LenX,LenY,LenZ,Layer[s]...
      'CSV' file - in the model's folder and named after the model thus:
      ModelName.skp >>> ModelNameDCs.csv
      If a new model is unsaved the current directory receives the new file.
      All Layers used in the DC are listed by name and visible ones marked
      thus >>LayerName<<
      Edit sep="," if something other than separating comma is desired e.g. ';'
      Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
      It uses the current Model Units.
      Version:
      1.0 20111104 First issue.
      • N Offline
        notekm
        my dcHi, in my dynamic component is a custom attribute "DSP",how and where it is necessary to register the plugin, so it will write out me to required attributes?Sorry for the quality of language
          Notekm
          Here's a modified version of the draft .rb file, which now adds 'dsp' and 'kromka' as additional reported attributes in the CSV. [which I guess are 'Chipboard' and 'Edging'/'Lipping' thicknesses ?]
          To get ANY DC attribute you can use its key's name, as you have typed it in the 'Custom' attribute section of the dialog, BUT all in lowercase letters - i.e. 'dsp' NOT 'DSP'...TIG-exportDCs2csv.rbTo find a specific DC's attribute keys/values you can select it in the SKP, then paste this line of code into the Ruby Console +<enter>:
          Sketchup.active_model.selection[0].attribute_dictionaries["dynamic_attributes"].each_pair{|k,v|puts k+"="+v.to_s}
          This will give an output list something like this:
          _has_movetool_behaviors=0.0 _hasbehaviors=1.0 dsp=0.216 kromka=1.32 lenx=0.6299212598425197 leny=11.811023622047244 lenz=28.34645669291339
          Note that the attributes starting with '_' are added by the system and you can't/shouldn't normally need or edit these.
          The others attributes represent what you have added as keys/values in the dialog - e.g. 'dsp' and 0.216... etc...
          • N Offline
            notekm
            it works, and how to make a that would show the sum of attribute values ​​on the right key
              You can simply open it is Excel and sum the Column ?
              However currently the units have 'mm' etc so you'd need to change those...
              I've recast it to miss those off.
              To =SUM a column you can add a final line of formulae...
              See what I've done to the code... I actually summed ALL 'number columns' BUT you will probably want to sum just some...TIG-exportDCs2csv.rb
              • N Offline
                notekm
                TIG.exportDCs2csv
                Error: #<ArgumentError: C:/PROGRA~1/Google/GOOGLE~1/Plugins/TIG-exportDCs2csv.rb:50:in to_l': Cannot convert "0.6299212598425197" to Length> C:/PROGRA~1/Google/GOOGLE~1/Plugins/TIG-exportDCs2csv.rb:50 C:/PROGRA~1/Google/GOOGLE~1/Plugins/TIG-exportDCs2csv.rb:50:in exportDCs2csv'
                C:/PROGRA~1/Google/GOOGLE~1/Plugins/TIG-exportDCs2csv.rb:47:in each' C:/PROGRA~1/Google/GOOGLE~1/Plugins/TIG-exportDCs2csv.rb:47:in exportDCs2csv'
                (eval):50
                  I have NOT changed the way the ...lenx.to_l etc works in line#50 - I added some code after that to remove 'mm' and '~' but nothing else; it's failing on the .to_l ?
                  Are you muddling ',' and '.' as decimal separators perhaps ?
                  If you copy/paste this into the Ruby Console it works too:
                  "0.6299212598425197".to_l
                  Works for me on your sample SKP.
                  Have you changed the DCs in your test SKP ?
                  • N Offline
                    notekm
                    hi, I did not change, I just copied a component in the scene.
                    this task.
                    1.Select all the components in the scene
                    2. select the components of a key (such as "DSP")
                    2a. (can take the key values ​​from a separate file?)
                    3. display or save the file in the list of components (screen of what I would like to see)
                    Scene
                    • irwanwrI Offline
                      irwanwr
                      so many versions in one page? is this free and not to difficult to learn for beginners?
                      if i may ask. which one is good for beginners to download, please?
                        Get the first one [at start] - the others are to show how to make a simple DC attribute reader/reporter...
                          this task.
                          The XY [in mm] need to come from the two largest values of the 'panel' - because sometimes the Z is NOT the minimum [=thickness]. OR you could report all three XYZ and you then simply ignore the smallest one [thickness] ??
                          Counting the number of a a specific DC and reporting it is possible:
                          number = instance.definition.instances.length.
                          I now see that the 'DSP' is the area [in m2] of 'chipboard' used in that panel.
                          I'm not sure what the 'Kromka' is - probably linear 'm' of edging ?
                          You need to adjust the way the values of these 2 are handled - so NO .to_l step since that turns the value [assumed to be in inches] into a length in current units [mm] - perhaps leave them as the float that they are, made into a string [.to_s] ?
                          Totaling up specific columns is demonstrated in the example code I've given you - adjust it to sum just those you want.
                          The CSV format can be linked [or save_as] into a XLS file where you format it as you like...
                          • irwanwrI Offline
                            irwanwr
                            thank you very much TIG.
                            for Extrusion Tool Set, i've learnt and succeed using the EEbyRail 😄
                            it works great as if a wizard made it 😛
                            thank you
                            • U Offline
                              unearthed
                              Hi TIG, thanks for the great plugin, now I can count my plants easily and sum plant areas easily.
                              But would it be possible to add the ability to get length of curves (arcs and splines) and lines from components?
                              Often I have many hedges in my designs, and if I could get their length, I could send this out with the report to Excel and then divide hedge length by plants per metre. I accept I will probably have to have a curve length for the hedge in a separate component but that's fine, although maybe it could just be as a nested instance.
                              Growplan - People ∩ Plants ∩ Place
                              windows 7 64b, 4GB RAM, SU 8.0.16846
                              Gimp, QGIS, Vectorworks 12, Bricscad 11
                                This tool was really written as a demonstration of how you can extract information from the model into CSV files etc.
                                As you probably already know selected lines/curves report their total length in the Entity Info dialog.
                                It's easy enough to sum the lengths of edges and report it out.
                                If you give a 'little more flesh to your bones' I can perhaps guide you on how to do this...
                                • U Offline
                                  unearthed
                                  Well here's a very typical hedge arrangement, although 100's of metres in many pieces is also quite common.
                                  I've also put the hedge centrelines as a nested component within each component, although if there's a way of avoiding that I'm all ears.
                                  Would it be easier to export the values of dimensions to the .csv?
                                  hedge.lengths.skp
                                    IF you want to use the nested component containing the linear info then you can readily add extra code into another column in the CSV. OR make a separate CSV report on linear info.
                                    Here's how to do it separately.
                                    The tool runs***, its code finds all components in the model with instances having a name containing 'hedge' and thereby their nested component giving the linear info drawn as a line or curve.
                                    It takes all edges in this nested component and totals their length.
                                    It writes a CSV listing the instance-name [e.g. 'c.hedge'], instance's-layer, definition-name, linear total [in meters]
                                    Sorted in order, with a header line and a total of the minear-meterage.
                                    Copy/paste this whole set of code into a new file [Notepad.exe] that you make in the Plugins folder named ' TIG-hedgelengths.rb'
                                    require 'sketchup.rb'
                                    module TIG
                                     unless file_loaded?(File.basename(__FILE__))
                                       UI.menu("Plugins").add_item("Hedges Length CSV"){self.hedgelengths()}
                                     file_loaded(File.basename(__FILE__))
                                     def self.hedgelengths()
                                      model=Sketchup.active_model
                                      if model.path.empty?
                                        dir=Dir.pwd
                                    	tit="Untitled"
                                      else
                                        dir=File.dirname(model.path)
                                    	tit=model.title
                                      rows=[]
                                      model.definitions.each{|d|
                                        next if d.group? or d.image?
                                    	d.instances.each{|i|
                                    	  txt=""
                                    	  if i.name=~/[Hh]edge/
                                    		txt << i.name+","
                                    		txt << i.layer.name+","
                                    		txt << d.name+","
                                    		lin=0
                                    		d.entities.each{|c|
                                    		  if c.class==Sketchup;;ComponentInstance
                                    		    c.definition.entities.each{|e|
                                    			  if e.class==Sketchup;;Edge
                                    			    lin+=e.length
                                    		txt << sprintf("%.3f", lin.to_m) ### 3d.p.
                                    	  rows << txt
                                      rows.dup.each{|e| rows.delete(e) if e.empty? }
                                      rows.sort!
                                      ## add total
                                      rows=["INST-NAME,INST-LAYER,DEFN,LIN.METERS"]+rows
                                      tot=rows.length.to_s
                                      rows << "\n,,TOTAL,=SUM(D2;D#{tot})"
                                      csv=File.join(dir, tit+"_HedgesLength.csv").tr("\\","/")
                                      begin
                                         file=File.open(csv,"w")
                                      rescue### trap if open
                                         UI.messagebox("Report;\n\n  "+csv+"\n\nCannot be written - it's probably already open.\nClose it and try making the Report again...\n\nExiting...")
                                    	 return nil
                                      rows.each{|row| file.puts(row) }
                                      file.close
                                      UI.messagebox("Report;\n"+csv+"\nWritten.")
                                      UI.openURL("file;///"+csv)
                                    ***Usage: either type TIG.hedgelengths in the Ruby Console... OR more easily use the Plugins menu item...
                                    • U Offline
                                      unearthed
                                      Thanks TIG, that's simply amazing Elegant and simple.
                                      Now thanks to your plugins I've got the basis for a complete plant counter (areas, individual plants and hedges and shelterbelts - Sketchup has just become a LOT more useful), thanks again.
                                      output from TIG-hedge.lengths.rb
                                        samyell77
                                        Hi Tig,
                                        Great plugin - thanks. Ive used this on several jobs now and wonder if you can help me to make a few tweaks. I've been trying to use this to count components in a selection. I know that the plugin exports 3 csv documents and was wondering if you can help me to tailor the script to get the count Im after - Im afraid Im a total noob to Ruby but am more than happy to have a play with it if you can offer a little advice.
                                        Id like to be able to generate a count for eithera whole model or for a selection within the model. I know that the script already generates a count for a selection but I'd like to be able to summarize items with the same name -giving me a total number.
                                        I also wonder if its possible to only display the component name and the count and none of the other information (guid, description, material etc). Im trying to reduce the amount of work I need to do to tidy up the csv files that are generated.
                                        Ive been playing with this whenever I get some spare time but would love a little advice.
                                        Any help much appreciated.
                                        Sam
                                        SU Pro 2016
                                        Dell Precision M4800
                                        PC Windows 10
                                        Intel Core i7-4900MQ @ 2.80ghz
                                        Nvidia Quadro K2100M
                                        16gb RAM
                                          Here's v1.2 made MAC compatible... http://sketchucation.com/forums/viewtopic.php?p=147658#p147658
                                            sidpickle
                                            Thanks TIG seems to work OK. I'll have a play with it.
                                            Ted Robbens
                                            • 1 / 4
