    1001bit problem
    14 Posts 6 Posters 3.4k Views 6 Watching
      Do you have the Ruby Console open while trying to use it? It might show errors that could give a clue
      • voljankoV Offline
        voljanko
        Do you have a new M2 version of SketchUp?
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        • leedeeteeL Offline
          leedeetee
          Hi Rich, sure, Ruby output below:
          loading C;/Program Files/Google/Google SketchUp 8/Plugins/1001bit/paneldivide >> 0
          Error; #<NameError; undefined local variable or method `launch_1001bit_paneldivide' for main;Object>
          (eval);367;in `gh_mnu_paneldivide'
          (eval);899;in `load'
          I do. And after thinking about, that's the thing that's changed since it did work.
          Thanks.
          Lee
          • voljankoV Offline
            voljanko
            Welcome to my world πŸ˜„
            I have found some problems with the new Sketchup M2 version when reading options (in Ruby).
            It would be useful to know if this error is also about reading option or other.
            But this is the question for the 1001bit's author.
              leedeetee
              I've emailed the author, will repost any responses. Thanks for your replies.
                You have also the 1001bits forum πŸ˜‰
                • daleD Offline
                  dale
                  I had problems, after installing M2, as you described only with the roofing deck tools. I downloaded it, and re-installed, and it has worked flawlessly ever since.
                    leedeetee
                    I have downloaded the paneldivide.rbs with no luck. Did you re-install the whole 1001bit package?
                    • daleD Offline
                      dale
                      Yes, I re-installed the whole package, and I think it actually even works better. Sometimes the roof deck tools would balk at strange shaped roofs, but the model I was just working on had the strangest yet, and it never flinched.
                        leedeetee
                        Thanks dale, will give it a shot.
                        Lee
                          arch2021software
                          while installing the 1001 bit tool I got a message saying that it is not compatible with my operating system or my SketchUp version, what should I do?
                            arch2021software
                            looking for C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/staircase1.rb
                            looking for C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/staircase1.rbs
                            loading C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/staircase1.rbs
                            inside read
                            no language file. C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/language/staircase1.txt
                            default size
                            point stage 0 --> (473226.779936 mm, 353125.822346 mm, 0 mm)
                            point stage 1 --> (474955.678097 mm, 352979.100747 mm, 0 mm)
                            this is the error poping up while using the plugin and the other functions of the pluging are also not working. Can someone help?
                              arch2021software
                              looking for C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/wall1.rb
                              looking for C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/wall1.rbs
                              loading C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/wall1.rbs
                              inside read
                              no language file. C:/Users/arch2/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/1001bit_freeware/language/wall1.txt
                              setting dialog size
                              This is also one of the errors that shows up cant understand what the problem is.
                              pls need guidance
